- Wheel Fitment
- Spark Plug Replacement
- ECU replacement
- MHI2 and virtual dash for Maps
- Transmission issues (DL501)
- 2015 Audi A6Q TDI 3.0L - Location of bolts?
- About wheels?
- Trailer Hitch
- NEED HELP WITH UPGRADES
- BAD ECM OR ECM?
- LED Headlight retro-fit 2014 A6 to 2017 A6
- Audi A6 radio receiver fried what do I do
- Audi a6 c7 front camera calibration
- Gas / Fuel Cap Tether Strap Replacement
- 2015 A6 Advice
- Front bumper and grill replacement
- 2.0 TDI EGR Issue
- A6 / C7 Same? Potential new Audi owner!!7
- Need Help Identifying a sensor
- A6 s-line sport suspension replacement
- Install Carplay for A6 without any modification to original car?
- Drl switch off with engine running
- 2016 A6 Engine Replacement
- Music with bluetooth Spotify
- Supercharger pulley removal
- Android 13 Flip Out Touch Screen for Upgraded radios fit C7
- Apple carplay / AA
- Fuse and relay diagram under ecm/ecu?
- For AUDI A6 C7 Android 12 Multimedia IPS Screen with wireless Carplay AA
- Auto stop-start and oil
- Help identify this part
- Headlight moisture
- CEL and EPC on after PCV, Water Pump, Thermostat, Pipes, Belts replacement
- What the heck is this thing?
- Jb4 for C7.5 gen 2 3.0t
- Wheel spacers question!
- Replacement coolant hose -- 2018 A6 3.0T
- Punched in the face
- A6 headlight upgrade
- ACC break guard unavailable
- a6 coolant problem start stop deactivation and shudder
- Looking for RS6 Front bumper
- 3.0t low compression
- SE: Change blind spot elsawin
- Wind noise
- Exhaust upgrade
- Audi A6 C7 - NF Map on Cluster
- A6 c7 3.0 tfsi vibrating in acceleration after tires change
- Sound Issues
- Headlight
- Audi a6 c7 2014
- C10AC07 Steering Malfunction - Car drives fine
- GSP drive shaft Audi A6 C7 quality
- Coolant level (cold engine) ?
- UK: Audi a6 3.0t 2012 smoke
- HPFP housing gasket oil leak.
- LT: Audi A6 Avant 3.0 TDI quatro ECU reflash
- 2016 A6 C7/4G AC HVAC?
- AL: Audi A6 C7 series Multitronic concerns
- 2.0TFSI USA ZF8HP55 Quattro Problem
- UK: Multiple Oil Leaks ? High Crank Case Pressure, diesel
- Motor mount replacement by lowering steering rack?
- Should I buy?
- Electric seats in place of manual seats
- VCDS THROTTLE BODY QUESTION switch to direct: controlled over threshold value
- 2005 audi a6 4.2 v8 questions
- FIXED: AC issue. Sensor for refrigerant pressure and temp. lower limit not reached
- Scraping/rattling timing chain?
- 2016 A6 Noise Near Front Driver (Only When Turning Right)
- Need honest opinions.. To sell or not to sell?
- 2012 A6 Prestige Cooling Fan Short to Ground
- Trying to decide sell vs keep... what would you value this car at?
- 2012 Auci A6 Prestigue
- Audi A6 3.0BiTdi CGQB
- I'm considering buying my first Audi. What should I know?
- Fixed: Supercharger Bleeder Screws
- BG: A6 C7 BiTDI 320ps boost in Lap Timer at idle
- Inspection due ! indicator
- Help: Intake Manifold Runner Control Bank 1 & 2 Stuck Closed
- Fixed: 2012 A6 Rear Reverse Backup Camera Intermittently Working
- NOx sensor
- Reliability of 14 A6 TDI approaching 91k?
- c7 Avant 2014 Heat only on one side.
- Engine electronics and transmission electronics issues
- RO: Shifting delayed S mode on the hill DL 382 0CK
- Coolant leak… after just having water pump replaced
- C7 Carplay Module - Audio Issues
- UK: Are these compatible
- Issues with my a6 c7
- DL382 (0CK) clutch pressure
- Replace Air Suspension Thoughts
- Mmi issues
- 2014 A6 mmi issues
- 3.0T limp mode plz Help
- Navman upgrades?
- UK: Audi A6 2.0 TDI Quattro Oil Pressure Error
- Audi A6 2.0 TDI Quattro TPMS or Not
- Looking at an A6 (C7) TDI should i run away
- 3.0T Extreme Oil Consumption
- Steering won’t unlock
- LED half blinker Code Error 03847
- 2014 A6 C7 Battery died now no start and no crank.
- Transmission Malfunction: No reverse gear
- UK: Numerous Dashboard Warnings, No Reverse Gear
- 2015 Audi 3.0TDi 272PS S Tronic - Blue Smoke
- Water Pump Seeping Coolant
- 2016 Audi a6 mmi not working
- Weird code 161536 3.0T
- ‘14 2.0T - Oil burning in engine bay
- Audi A6 C7 side mirrors and seats
- 2016 A6 C7 quattro
- HELP Re-occurring P0303
- Larger display
- Name of this clip and where I can purchase it?
- R to P shake problem
- Power Steering Module replacement
- Oil change interval question
- Can faulty clock spring cause epc+check engine limp mode?
- AdBlue Pump Replacement
- How to remove phone creddle
- Steering Wheel Swap
- A6 Avant most comfortable suspension setup
- Misfire cyl 5 and 6
- Audi a6 c7 2012.
- Transsmission or Fuel pump or Anything else?
- Lock-up clutch solenoid AKP=>electromagnet-N110 P1761 00 [047] - short to ground
- Water front passenger footwell
- 20231223 knocking sound
- Audi Q5 gearbox mallfunction falut Code 18011
- A/C Condensor
- HELP Audi MMI/AMP problems
- Fuel smell in cabin
- A6 2016 2.0tdi coolant shut off valve
- Power Steering Control Module No Commumication
- APR stage 1
- Comfort module ?
- Audi A6 2012 Radio Module ?
- Audi C7 2012-2015 Wiring Info for Xenon Non AFS Lights(Help)
- Audi a6 2011 c7 trunk not opening
- High Beam assist not working on A6
- Oil pan gasket
- S-Tronic Gearbox fault
- 2014 2.0 - New CPS, slower start and P0322
- LT: oil level?
- engine mount sounds
- P204B & Diesel Exhaust Fluid Injector Location
- Major electrical issue
- Stupid question about engine oil, 3.0TDI
- 360 cam retofit and other retofits
- UK: 2012 Audi A6 2.0 TFSI
- A6 C7 2012 Avant Rear View Camera Upgrade
- Autohold button memory
- Just bought 3.0TDI and have some problems
- Brake rotor problem
- SI: Is this a normal healthy sound for a 3.0 diesel
- LEFT side headlight Not working fuses, bulbs, ballast all ok
- Looking for an expert on remote coding for ACC
- BLACK FRIDAY SALE / CYBER MONDAY ON NOW @ deAutoLED.com – bright error free LEDs
- BLACK FRIDAY SALE,, SuperSprint Italy
- No exitation voltage to altenator
- Audi A6/C7 3.0 bi turbo remap
- Crank polley broken
- A6 C7 avant halogen to LED conversion
- VCDS to unlock "Green Menu" and edit
- AL: Gearbox not handling 5 to 6 gear properly
- A6 C7 NFL 2013 - Key issues
- Side Mirror Maintenance or Lubrication
- A6 2016 c7.5 extra sub on bose
- UK: Air intake oil/debris - normal for a diesel?
- 2017 A6 C7 Avant maps upgrade
- ‘14 TDI A6 Catalytic Converter
- Audi a6 c7 sunroof problem
- A6 C7 Non facelift - Map on cluster
- Audi A6 C7 2013 - Carplay?
- Air intake connection
- Help ID these things missing in my trunk...
- 2016 A6 Purchase question
- DPF Regen done - strange data readings
- Fan turns on after locking door
- Audi a6 C7 headlight replacement.
- 2015 A6 Prestige front ACC camera removal help
- Trying to fing correct cv joint
- Help with 12v from my mirror for my radar?
- C7 A6 What's this bolt on my undertray?
- c7 automatic no gears advice no errors
- Mmi/radio not working
- The roof and roller shutter do not work
- Warbling/droning noise from rear above 40 MPH
- New or old S6??
- Airbag module repair after crash
- Audi a6 c7 2016 headlight range control system fault
- A6 Idle Sputtering
- Seat belt not tightened....
- MMI stuck down??
- Wiper switch E22
- Replaced all shocks with Bilstein B4s at 95k mi
- 2016 A6 drivers side matrix led problem
- Vibration while driving
- How to adjust panel gaps between fender and hood
- UK: Rear passenger footwell soaked
- Change oil filter with each oil change?
- Audi A6 C7 Key Not Detected after battery in trunk replaced
- Auxiliary heating wont start when engine not running
- brake pad change rear w/o VAG com
- Battery Replacement - DIY ?
- Brake Pedal Light followed by Brake red indicator
- A6 2017 2.0tdi ultra strange noise from the front of engine
- How bad is it? 2018 A6 66k miles 2.0T
- Looking for gutted cats!!
- NO: ABS problem
- All Warning lights on dashboard and vehicle shuts off immediately after starting
- A6 C7 Rattling noise
- Engine Computer trouble
- Misfires, rich codes, and unstable idle on closed loop after hpfp upgrade and e40
- APR Tuned - What's Next?
- Chrome delete?
- No heating just cold air
- Audi A6 C7 Multiple short to ground, circuit low, circuit open codes, epc and check e
- 2017 Audi A6 abs module
- Centre console/dash rattle (Centre) - help please
- New A6 face, fuel sistem error p0088/p087
- Rattle when accelerating
- 2013 A6 3.0T front rotor min thickness
- Coolant Leak HELP!
- 2015 A6 MMI update
- Oil type ?
- Instructions on removing headliner?
- C7 manual gearbox clutch problem juddering
- AL: Audi A6 USA headlights to EU headlights.
- Does a front strut bar makes a difference on A6 3.0T C7.5 sedan?
- i need help to locate air suspension relay! a6 allroad c7.5 3.0tdi
- Ticking sound when engine turns off (stop/start)
- Need some advice
- Updating OEM NAV maps?
- Does transmission solenoids needs coding?
- PL: Do I need to change anything about the headlights?
- 3.0t Coolant Reservoir
- Regarding Load through backrests
- Thinking about buy A6 (C7)
- Wheel fitment
- Battery over 10 y/o
- Panorama Sun Roof Manual Close - Possible?
- Device or sensor connects to wires that branch off from AC pressure sensor
- Engine not starting
- Radiator Air Shroud
- MAP sensor problem
- Coolant Flush Interval?
- 2014 A6 Prestige Aux radiator replacement difference
- Audi A6 3.0TDI 200kw Loss of Crankshaft Synchronization
