PDA
View Full Version : Audi A3 / S3 / RS 3 MKII
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18
  1. Anyone here had a white bagged '18 S3 in NJ that was stolen last year?
  2. Screen not working rs3
  3. Replaced mirror with Homelink one?
  4. Used A3 I bought has a steel skid plate. Should I replace with OEM plastic one?
  5. Android Auto without USB
  6. Audi A3 8V MMI Issue Up and Down - Help!
  7. audi a3 8v replace alternator
  8. Stalling
  9. 2015 A3 2.0T burning engine oil...
  10. 20% off our bright D1S / D2S / D3S LEDs! These are brighter than xenon bulbs!
  11. UK: Help needed to repair dipped bulb
  12. Audi RS3 Rear wiper starts automatically in heavy rain but is in off position?
  13. Apple car Play
  14. Coolant level
  15. Best CarPlay module for 2015 A3 in 2024? Tons of options.
  16. DIY Virtual Cockpit firmware update
  17. TCL, TPMS and other issues after tire change
  18. coolent issues
  19. DIY Audi MMI (MHI2) firmware update
  20. MMI display
  21. UK: S3 shock absorber?
  22. Rumbling/ Rattling noise
  23. Should (can) I push for a new battery with my new 2019 CPO A3?
  24. 2015 Audi A3 1.8 Premium - won't shift into second upon start
  25. RS steering wheel controls not working
  26. Map Upgrades
  27. Audi RS3 Sunroof Controls Acting Up
  28. tire pressure
  29. A3 E-tron parts cars
  30. 3dr & 5dr front end parts compatibility 2013-2016
  31. pistonsettlement.com may be worth a look for folks here
  32. BATTERY REPLACEMENT
  33. Lifting a3 e-tron with 2018 tiguan springs?
  34. A3 8V Wheel Fitment Advice
  35. UK: A3 Sportsback 2020 2.0 TFSI Quattro Tyre Pressure Help!
  36. 2019 A3 Scraping Sound at Low Speeds
  37. 2015 Audi s3 8V shifting issue
  38. iD Forged 17"- 20" Japanese Inspired 1pc Forged Wheels
  39. Stumped- P008700 2015 A3 8v
  40. Driver side window won’t roll up
  41. Dizzy from Lease Buyout
  42. Mileage and Issues ?
  43. Audi A3 8V Wheel Fitment
  44. Electrical System Limited Error 2022 A3
  45. 8V S3 Stalling when cornering with wheel slip
  46. Car shimmies under hard acceleration
  47. How to change a rear wheel bearing on an AUDI S3 8V
  48. New transmission recall/TCM update on A3?
  49. 2020 Audi A3 Oil Level system malfunction! Please contact service
  50. Reset Steering Angle Sensor
  51. Front registration plate stuck
  52. 2015 A3 Quattro EPC Misfire 4 mystery...
  53. Broken rear seat release cable A3 Cabriolet
  54. 2015 Audi A3 Quattro 2.0T EPC and Check Engine light on
  55. Connectivity Package
  56. Christmas Holiday Sale
  57. A3 Cab rearview Mirror repair.
  58. Power mirror trouble
  59. Navigation initializing stuck at 11%. Does anyone have an update file?
  60. 2023 Audi RS3 Evap Leak? Is this normal?
  61. Single beep every 30 seconds with the ignition off
  62. Help rs3 possible water flow issuise
  63. Steering and faults 2021 a3
  64. BLACK FRIDAY SALE,, SuperSprint Italy
  65. BLACK FRIDAY SALE / CYBER MONDAY ON NOW @ deAutoLED.com – bright error free LEDs
  66. Free RS3 Dynamic Package front wheel
  67. 2015 Audi A3 stalling
  68. 225/45/18 Will the rub?
  69. 2017 Audi s3 making knocking noise
  70. Missing Option for Tire Pressure Monitoring?
  71. Audi A3 E-Tron to RS3 body kit conversion/facelift
  72. Do 2020 RS3 and S3 Share Same Front Bumper?
  73. Audi RS3 8V (2018) latency at startup
  74. 2013 Audi a3 TDI rear right outer tail light not working
  75. 2016 A3 Rear view mirror bottom flip tab suddenly super stiff/clicking
  76. Weird sound after turn off the engine 2.0 TDI
  77. Will this part fit my A3
  78. 034 Motorsports Tune
  79. EPC and now Check engine
  80. Rebuilding rear differential gen 5
  81. NL: Audi A3 1.6 BSE, rough idle, catalyst error
  82. ARMASPEED Intake for my 2017 Audi A3 1.0 TFSI
  83. Audi A3 8V FL aftermarket stereo, no sound quality.
  84. 2006 A3 8p 2.0 TFSI Trouble Getting Into Gear
  85. HR: Audi S3 8v facelift 2017 LED headlights problem
  86. 1.6 TDI Cold Start Issue
  87. 2017 A3 - Audio System - Dealer or Independent?
  88. Transmission issue
  89. Issues with the Seat Heating in Audi A3 8p Model Year 2008
  90. 2016 vs 2018 RS3 (EU Spec)
  91. New Member – 2018 Audi A3 Seat Belt
  92. 2015 a3 2.0t whirring noise
  93. S3 2017 ERROR CODES
  94. Quiet Intake and Blowoff Valve
  95. Audi S3 Issue - Need Help Troubleshooting
  96. Should i Cash in on the current Value of My S3?
  97. P1443 EGR Fault.
  98. Audi A3 1.4TFSI 2011 Manual Cluster alternatives
  99. Bypass or spare key for a 2006 A3
  100. Cornering/Turn Signal Fog Light
  101. 02 sensor bank 1 Audi A3 8p 2.0tdi
  102. A3 Trunk Latch
  103. Questions about Audi Connect
  104. Camshaft intake timing is wrong need realignment
  105. Mk7 r vs audi s3 FL fixed suspension handling
  106. UK: FRONT END ROTATIONAL KNOCKING SOUND HELP ME!!
  107. Upgraded bushings, now the car doesn't align properly
  108. EPC and Check Engine Light on 2015 Audi A3 1.8T
  109. 2015 S3 Rear Brake Caliper Issues
  110. 2018 a3 mmi swivel wheel
  111. Hight Mileage S3's
  112. Rear Backup Camera Never Appears
  113. A3 suspension
  114. yet another post of troubleshooting ABS sensors/module for false low tire pressure
  115. OBD reader/maintenance reminder resetter advice
  116. 2018 S3 Wheel Specs?
  117. Gearbox Malfunction, no reverse gear
  118. PSA: Check your rear control arms
  119. Temp is high
  120. CZEA engine Still problematic?
  121. NZ: 2018 RS3 chain slip?
  122. Audi s3 cruise control unavailable hill hold assist unavailable and parking brake
  123. Audi MMI Compatability
  124. EPC + Check Engine light on - cylinders misfire
  125. The Audi A3 is better than the S3 (Hear Me Out)
  126. A3 2009 sportback
  127. A3 8V2 USB install - how to connect + and - ?
  128. Power windows not working & safe on cluster [A3 2004]
  129. 2015 s3 misfire after engine swap
  130. Audi RS3 2015 Start/Stop
  131. Have i fried the electronics?
  132. American message board members.....
  133. Emissions issue - O2 sensor values
  134. 2017 battery drain
  135. 2017 A3 Premium DRL question
  136. A3 8V Throttle Issue
  137. Mechatronic Valve Stuck Open
  138. Drivers side brake/tail light/ turn signal out no power
  139. CNTC Engine Replacement
  140. High Milage S3?
  141. Can someone please help me find my EGR valve
  142. Rear window drivers side will not open
  143. Greetings from SuperSprint Italy
  144. Will 2023 RS3 Wheels fit on a 2020 RS3?
  145. Goood Shop Near Danbury, CT?
  146. Activate High beam assist
  147. 2015 A3 Audi Pre Sense: system fault
  148. Audi r8 brakes on a 8v s3
  149. A3 8V Gets stuck in gear and fixes itself when restarting engine.
  150. Break Pad options for RS3
  151. rattling/clattering sound when warmed up
  152. 8V S3 Whistling noise from engine bay under hard acceleration
  153. 2015 A3 1.8L ODB2 errors will not pass inspection
  154. Noises after car is turned off!?
  155. A3 Etron EVAP system leak N80 purge valve location
  156. I think I broke my Haldex testing Launch Control on a stage 1 tune. What code should
  157. Audi A3 Brake System Specs
  158. A3 defrost actuator?
  159. A3 defrost actuator?
  160. Problem with puddle lights
  161. What is the wiring loom for
  162. CSF S3 radiator?
  163. 2015 Audi A3: No sounds from speakers (intermittent)
  164. back window will roll up but then get stuck and go back down
  165. AU: Wheel lock up when I exit a parking bay
  166. Bruised fingers trying to disconnect the door harness connector for speaker wire inst
  167. Will low brake pads through a sensor on the dash?
  168. Front Susp. Way too Harsh?
  169. A3 -15 1.6tdi S Tronic upshift problem
  170. 2017 S3 DRL Issues
  171. Distance Warning Unavailable + Presense Limited warnings [2017 A3 e-tron]
  172. OZ Superturismo Evoluzione 19" fitment?
  173. About that Resonator Sitting in Your Garage...
  174. Help Tranny swap!
  175. Engine swap
  176. Increasing aspect ratio on 19 inch wheels vs downsizing to 18 inch wheels
  177. oil consumption
  178. Transmission Oil Temperatur/Speed Sensor
  179. MX: 1.4t A3 8v; EPC light; no symptoms; car shuts down
  180. Window drops 20mm, but doesn't rise when the door is closed
  181. audi s3 8v knocking noise
  182. Oil leak after service
  183. Leak in front of rear wheel on driver side
  184. 8V - good location for Amplifier Remote-On wire tap in the trunk
  185. A3 2015 - - MMI stuck down. Possible to use app or hardwire?
  186. S3 bent valve.
  187. 2018 A3 E-Tron: Does not charge to Full 100% (stops at 7/8)
  188. Chirping Noise from Engine Bay After Shutoff - 2016 S3
  189. 2015 A3 2.0 Sedan Trunk Trim Removal
  190. UK: 1.6 tdi, rattling noise at idle, Audi a3 2014
  191. Gearbox speed sensor faulty
  192. License plate light issue
  193. Hate to do it but.....tires?
  194. Rear wiper motor failed
  195. Audi 2018 - maps update
  196. 2015 A3 Jerky Transmission
  197. Need electrical assistance 2018 A3
  198. Carbon ceramic discs REFURBISHMENT
  199. 2.0 TDI Fuel Pressure Low
  200. Questions about 2017 Audi A3
  201. Codes after Engine swap
  202. Oil specification for audi a3 2018?
  203. Audi A3 e-trons hitting market with buybacks
  204. S3 8v rear diff oil
  205. Boot stuck when changing spark plugs
  206. Audi A3 2020 8Y wireless carplay
  207. A3 40TFSI SLine upgrade
  208. 2019 RS3 Sedan Wheel Dispute with Original Rader
  209. Audi A3 8V - S-tronic problem?
  210. Pfl 8v rs3 PCV replace help
  211. Need advise before going to dealer about EV battery replacement
  212. Cylinder Order S3 8v
  213. Wiring problem S3 8V
  214. Several MMI buttons not working..
  215. S-Tronic DQ-250 (DSG) issue on Audi A3 TDI
  216. Fender Liner Splash Guard A3 2019
  217. Retrofits and CAN bus
  218. Help with Build Sheet A3 Cab
  219. Smog checks and drive cycles?
  220. What fuse is for the OBD port?
  221. A3 runs fine one day, next day will stall out
  222. Boost leak
  223. 20% off NEW D3S/D1S LEDs FOR 2023 –Bright - NO ERRORS - PLUG & PLAY - NO wires!
  224. Audi s3 08852 fault code
  225. 2009 2.0t with P0776, Transmission Solenoid B
  226. 2009 ABS pump compatibility
  227. A new member with few questions.
  228. Milltek Catback and ARM DP, will they fit each other?
  229. 2 Piece BC forged wheels with PS4s
  230. DS1 flex fuel works!
  231. S3 headlight switch wiring diagram
  232. Audi A3 8p 2010 center console trim
  233. 2003 1.9 pd130 cam & crank sensor cable problem.
  234. Audi A3 Front Grill
  235. Pedal Commander on an A3 2.0 TFSI?
  236. Locking chirp.
  237. Pair key to driver mode
  238. Rear wheel hard to turn
  239. New Forged Carbon Paddle Extensions
  240. Strange music....All speakers except 1 are silent
  241. A3 Cab Suspension Vibration
  242. Black Friday // Cyber Monday Sales on now – Bright error free LEDs @ the best prices!
  243. EPC Issue 2016 A3 2.0 Quattro - HELP!!
  244. Seeking indepedent shop for my RS3
  245. I need some feedback from the 2015-2020 Audi a3 2.0t Quattro owners
  246. Evap Hose and Filter Repair
  247. IL: I dont have Car Modes on my A3 Sedan
  248. Genuine "Quattro" Puddle Lights Are On Sale!
  249. Struts, Springs, and Spacers - Oh my!
  250. Fender
