- New 2024 RS% - creaking/clicking sound driver's side
- B9.5 Canadian Auto Performance Grille and ACC
- B9.5 Production Numbers
- IT: Cerchi Audi Sport 20 per RS5 2019
- USA: Has anyone been able to activate the blue headlight laser on their 2024 Audi?
- IE A2A IC Installation & Initial Impressions
- S5 MY2018 - Throttle Whistle / Squeal Problem
- A5(F5) 2019 Loker in the back arch hangs on one side in the air
- B9 RS5 Stage 1+ e85 034 launching
- Like finding money in the couch
- Tires
- 2022 A5 Low tire warning issue. Tires are inflated
- Emergency call malfunction; please contact service
- Valvetronic exhaust
- Audi F1 car...
- Sporadic beeping through MMI
- Redidue, substance coming from right side exhaust tip, any need for concern?
- Jack storage location in S5
- First service done, “rear diff seepage”
- Exploring High-Performance Daily Drivers/Depreciation
- Newbie Oil change question
- b9.5 non s-line to s-line grille
- Controller #53- parking brake- VAG-COM
- Recent break in - advice is welcome!
- Enabled Lap Timer in HUD; but how do I start/stop/zero it?
- Coil packs and plugs for 034 Motorsports Stage 3
- Current Software Versions for B9.5 cars
- EA888 Gen 3b - DEMA - Idle Misifre
- Today the myAudi App 4.24.0 added a home screen widget for...
- TR: can i code rs5 indicators for audi a5 2018
- Sticking gas filler door
- Sunroof ticking noise making me mental
- Brand new S5, disconnected MyAudi WTF
- New Owner
- Brake Pads
- 21 RS5 air conditioner dead for third time. Will Audi USA cover after factory expires
- Side assist fault
- New Owner - 2019 A5 Sportback S Line Premium
- New to me RS5 with bronze package
- Door handle sensor sensitivity
- PL: A5 2019 Disable TPMS
- good grief...
- Vapor Canister Purge Valve/N80 Location
- New Forgedlite TF Series 1pc Forged Monoblock - Custom Made for your Audi
- Dimensions, In Inches, Of A Current RS5 Sportback's Rear Storage? k's Rear Sto?
- Next Question anout my new 2024 S5
- Aftermarket subwoofer messes with remote key? (sportback)
- Not showing speed limit
- Item sticking out near driver foot rest?
- Your Thoughts On A 2919 RS5's Reliability And Does My Plan Make Sense?
- Purchased a '24 S5 Sportback
- MMX Wheels 1P 2P 3P & 4P Forged Aluminum Wheels Master Distributor Wheel Designers
- WB2 Package meaning. Do I have Advanced Key?
- UK: A5 B9 Quattro- Wheel speed sensors
- Gearbox/Exhaust problem?
- New member - new 2019 S5 SB
- S5 2017 Creaking Noises - TPI 2044902
- Cargo Nets
- Which RS model gets this key fob...
- Replacement plastic part for driver seat rails
- ES: Ruido en rotondas y al girar
- Coolant leak
- B9 LED Matrix main high beam defect
- 2019 S5, Drive system malfunction and some other little issues
- Audi RS5 B8.5 2013 loud mechanical ticking noise.
- Boost control solenoid leaking coolant
- Apple iOS 17.4 Update Releases Next Tuesday
- 2019 A5 Sportback SOS module location?
- Carbon Exterior Pack
- How can I make sure that Audi pretense is working?
- Radio reception
- B&O Subwoofer Upgrade on S5 Convertible
- Ohhhh NJ….
- Cause of this shifting event?
- A5 SB 2021 German Edition - Adaptive Cruise Control (ACC) adaptation
- Tires?
- Help Removing Trunk Panel
- Navigation System Not Working/Lagging
- Still finding oil around the cap after replacing PCV breather hose
- Progressive Red vs Tango Red Pics?
- Audi S5 B9 - Drive System Malfunction - P0243
- S5 rear brake pad wear sensors -audible?
- RS5 Turbo / Actuator Problem
- Rear Seat Phone/Tablet Holder
- Ambient Lighting Stopped Working
- 2021 A5 Engine rattle
- Audi Rings = Design Change
- Broken Rear Coil Springs
- 2022 RS5 Wheel Fit? - 19x9.5 ET50
- S5 Sportback to S5 Cabrio
- 21 Audi A5 Sportback Vibrates when starting while wheels turn
- Has anyone ever seen this before???
- 2019 S5 Repair guidance in Dallas DFW area
- 2018 A5 m/t need help figuring out clicking noise on clutch
- New Stance SF12 and SF13 in 19" and 20" Sizes - Wheel Designers
- Audi Extended Warranty, worth it ?
- MHI3 / No Data Connection
- ? Replace one tire only
- Put the RS5 Sportback on E85! Some first impressions
- Any firmware fixes for Android Auto bug, B9?
- RS5 - 2020 - B9.5 - Latest Firmware version
- Brake Pad Options
- Coolant Level Warning - False Negative ?
- Audi s5 4.2 knocking sound
- Wheels fitment
- Where can I find CCBs for my B9.5 RS5 Sportback?
- Carlinkit/Magic Link in 2024 RS5
- 2018 A5 Non S line front bumper cover
- What’s up with trans pan
- 2023 Audi S5 SB - Advice needed: steering wheel and gearbox issues
- FR: How to change drive unit for rear lid
- A5 B9 cabriolet 360 REAR CAM
- Keyless Entry retrofit - A5 Cabriolet
- Smell like burned oil
- Remote starter installer north of Boston.
- Rs5 B9 coupe locking issue
- New owner issue/question with wind deflector A5
- Tune-up Time!
- RS4/5 B9 Rocker Arm Failures... MUST SEE..New video!!!!
- A5, S5, RS5 B9.5 Matrix LED Headlight Activation Information...
- 2024 Audi S5 - Starting Issues
- Sold the RS5 - went over to the dark/beaver tooth side
- 2.0T Turbo Inlet Pipe
- Awesome Deal
- 2019 B9 A5 turbo upgrade?
- Missing cover on engine
- iD Forged 17"- 20" Japanese Inspired 1pc Forged Wheels
- 2018 A5 Cab Newbie questions
- Rejected warranty claim. Any ideas?
- Rotors and pads for 2018 S5 SB
- FS: BC Forged HBR10 wheels + Michelin Pilot Sport All Season 4
- New Vertini RFS2.2 RFS2.3 RFS2.4 19" and 20" Sizes
- WTB OEM competition wheels
- Underbody Shields Question / Help
- OEM 19” wheel size and offset 2023 A5 PP
- 2018 s5 boost incident
- Heated Steering Wheel- A5 Cabrio
- 2018 Audi A5 Cabrio
- Turbo identification on recently purchased S5
- Crankshaft Adapatation
- Steering wheel noise
- Knocking in Driver Door Card - help!!
- Trickle charger B9.5
- Anyone know what this wheel fits?
- 2017 Audi A5 sport back wishbone fastening.
- 2025 RS 5
- Anybody cross-shop S5 and A7?
- Cost to maintain between 3 and 5 years
- Brake pad change question
- Strange auto window movements
- 2021-2023 S5 Hatchback
- A5 F5 myAudi app - Remote auxilliary heater won't start
- Options for when dealer wrecks your car
- 1,000hp EA839 2.9TT build?
- PL: LOST VECHILE COD
- B9 3.0T/CWGD/EA839 Oil Filter Housing Replacement - Aluminum Upgrade
- Inlays
- Can I hardwire phone to MMI for CarPlay?
- 2014 Cabrio Sun Visor Clip reinstalling cover
- New Video: Unleash the turbo sounds! RS5 gets a full intake system
- Update B9 MMI, VC, Maps, and enable dual nav.
- A5 B9 Quattro - ABS pump for ACC retrofit.
- Michelin Pilot Sport All Season 4 or Cross-Climate 2?
- Remote start with app and I can't unlock doors
- Square Bottom Steering Wheel
- Audi A5 S line convertible 2024 spare tire install
- Tire Suggestions for A5 Sportback
- Tire Rotation
- Suggestion on All Season tires for 2024 S5 Coupe
- How long do I have?
- TSW Neptune Fitment Question
- B9.5 RS5 Fixed Suspension vs. DRC
- Control arm bushings blown at 65k miles
- MyAudi Marketplace - Nothing to Buy Other than AudiCare for my 2020 S5?
- B9.5 Head/tail light animations
- Antenna Torn Off A5
- Rattle from driver and passenger door. Going nuts.
- 2024 S5 coupe new owner
- GM Says It's Nixing CarPlay to Make Drivers Safer
- New Video: Installing a Tune on the RS5. Loud exhaust and heavy accelerations
- How to clear inspection notice? Using OBDII
- B&O Speaker Upgrade and Subwoofer Install
- Automatic headlights always on
- VOSSEN HF2 HYBRID FORGED
- CarPlay flips connection manager
- Audi Quattro vs.Telsa in the snow...
- RS5 post 2024
- Christmas Holiday Sale
- Michelin 275/30R20 Pilot Alpin PA4 97W
- Whooshing sound during Hard Acceleration 2023 S5
- 034Motorsport S34 CAI install video...
- 2018 A5 Sportback heater issues
- 2018 Audi A5 vs 2014 S5 Advice
- Audi Connect down
- Part Number/Replacement Assistance, Wastegate Bypass Regulator Valve N75
- Audi a5 DSG problem or ???
- License Plate Relocation
- Resonators on RS5
- Mmi Audi logo
- 2019 Audi A5 Drivetrain issue?
- bummer...some parts on nationwide backorder??
- Identify/Confirm Pipe Part # due to code P0299
- Check Coolant and shutoff engine warning.
- Turbo upgrade 2023 A5
- BLACK FRIDAY SALE / CYBER MONDAY ON NOW @ deAutoLED.com – bright error free LEDs
- BLACK FRIDAY SALE,, SuperSprint Italy
- 2.9 RS5 Unitronic ECU
- Dynamic suspension valve failure
- 17" winter wheels/tires
- 2025 Audi B10 A5 spotted
- Coolant Leak at Reservoir Connection
- What is with nationwide back order on 4 cal motor mounts?
- 2012 S5 Value Assistance
- NL: Tire pressure?
- Remote lock and unlock safe audi
- Price Negotiations on 2024 s5
- Engine motor mounts 2018 A5SB on back order?
- Worth buying a salvage title RS5?
- 2022 Audi RS5 Sportback Heated Steering Issue?
- Amazon to sell Hyundai vehicles online starting in 2024
- And now for something completely different
- RS5 Grill mounted camera question
- 2020 Audi S5 SOS/connectivity issues
- How To Black Out Center Lower Front Spoiler?
- Motor for rear right temperature flat - climate control
- A5 vs A4 vs A6 interior dimensions
- Lack of A5 45 MY21 or 22 on the market?
- Trying to Match Interior Carbon Fiber Wrap
- Chronos gray/Magma red S5 Sportback - Good color combo?
- NL: 4 wheels clutch oil?
- Forgedlite Wheels Black Friday Sale 11/6 to 11/27
- TTS Supercharged S5 misfire
- creaks and groans
- 2015 OEM battery
- Auto start stop / hill hold assist
- Confused about software/nav updates
- 2019 RS5 End of Warranty Checklist
- 2024 RS5 build option now available
- Stains on the back of Vincode window
- Non-B&O grills for 2023 A5 Sportback
- DK: Full equipment list - VIN
- S line suspension
- NL: Spark plugs?
- Restoring painted alloys to original
- P/N for front parking sensors?
- Code for comfort & sound pack
- UK: Getting loads of errors intermittently
- bit One install, B9.5 A5SB - brainstorming
- Need help identifying part. Coolant leak. B9 rs5.
