- Any one selling their C4?
- 1992 100CS Engine
- 1997 audi a6 quattro wagon engine swap?
- 1997 Audi C4 A6 Avant
- Leaking air or cooling problem
- Correct grease for front final drive ball bearing?
- Replaced ignition assembly but now the new key will not turn at all
- Front end and subframe reassembly order
- Need help with ma ball joints!!
- A6 ABS off
- 100 CS 5spd HELP
- S6 2.2 Turbo Quattro
- Floating Shifter assembly
- Lower Radiator Hose 1993 V6 Audi 100- H.E.L.P.
- Valve cover/crankcase breather hoses
- Splash shield
- Reversed trunk locking problem!!
- Please help. Audi A6 C4 sedan the trunk cannot be opened
- Need left camshaft for 1992 Audi 100
- 1996 Audi A6 - Timing Help
- Rear differential filler plug size
- Audi A6 Head lights issue.
- FI: Spring lenght?
- S6 AEC wont start
- 1998MY C4 A6 Avant production?
- dashboard warning lights
- 96 A6 Coolant temp warning
- 1996 A6 No Start
- HEAT/AC
- rear wheel speed sensor for 94 100 quattro
- DK: vacuum actuated heater valve
- Audi 2.3 5 cylinder BOSCH Fuel Pressure Regulator
- 1995 audi a6 3.6 v6 abc transmission problem pls help!!!!
- Removing doorpanel while door is closed
- Conversion 100 c4 fwd to quattro
- Audi 100 dashboard
- 96 A6 C4 front strut/episode/and Question
- FI: ECT Warning Light is on and can't find out why
- 2.5tdi turns over but doesn't start
- Audi a4 b5 climatronic to audi 100
- Rebuilding rear suspension, need help identifying bushings 1994 100CS
- A6 ECU Swap
- Transmission solenoid cleaning
- Brake carrier differences
- Electrical Issues
- 1992 Audi 100CS Seatbelt/Headlight Chime
- Fuel tank spitting back up gas / Engine stall when shifting
- EE: Audi A6 C4 no sound from speakers
- Opinions please
- V68 blend flap is stuck at 50%
- C4 Cam Position Sensor Oil Leak?
- Audi 100 (1985, 2.2l 85kw) vibrating when accelerating
- FI: Audi A6 C4 lowering springs?
- AUDI A6 C4 sedan 2.6 shocks and springs on 2.0 ABK
- A6 1996 A/C no power to A/C relays
- 1994 AUDI 100S sedan c4 won't start
- A6 1996 A/C control module "Need"
- 97 A6 2.8 Crankshaft position sensor location
- Audi A6-C4 rear muffler FS
- Any leads on a 12V A6?
- SOUTH AFRICAN BUILD MODELS
- C4 OEM floor mats?
- Rear seat bolts
- Oil in sump not circulating?
- Power steering hose
- CA: Steering wheel swap from C6
- Gearbox weirdness
- Timing Belt Tensioner Required? Audi 96 A6 Sedan
- C4 2nd speed fan relay?
- 96 A6 Reverse Light on Except in...
- AC problem
- UK: 1995 A6 2.0 SE All Four Windows Stopped Working
- A6 C4 seat compatibility
- SE: Audi 100 would not start?
- new user looking for resources
- 1995 Audi C4 S6 Avant Shakes at 3000 RPM
- Scan my 1995 A6 Quattro
- Audi a6 2000 c4 v6 vacuum problem
- 1994 AUDI 100S c4 EGR valve
- RIP, the old 12v.org website is dead
- Rear US tail lights
- Audi A6 Quattro 1996 engine vibration
- SE: Low oil pressure
- Oil Cooler Leaking
- Faulty Air Con Compressor ???
- Video: Replacing the alternator
- Audi 100 check engine light/loss of power
- 100s c4 steering wheel/airbag compatibility
- 95.5 A6q headliner drooping, how to remove?
- 100 A/C and Headlight
- 1995 A6 Intermittent electrics fault
- 1997 A6 Avant stalls and rough idles when warm
- airfilter before condensor
- A6 heater servo rebuild
- Both Avants dead most likely... it’s a sad day.
- Replace Turn Signal Flasher Relay?
- Audi 100 c4 clutch slave cylinder
- Serpentine for AC delete
- Farewell Old Girl! (C4 A6 Avant 2.8L)
- ZA: AUTO CHECK QUESTION
- '95.5 S6 Idler Pulley Assembly
- 1995 urS6 water under backseat cushion (driver side)
- Audi 100 2.2 1985 wiring problems with ignition?
- 1996 A6 Avant Quattro exhaust
- 1995 A6 Acting Up
- Trouble with power Windows and sunroof! Does not work
- Will not shift out of park
- Audi 100 Window regulator cable snapped
- How to disable airbag?
- 1994 Audi 100s sunroof headliner
- 2.6 ABC oil filter?
- New power steering pump.. Now car stalls and runs like crap!
- c4 gear box compatibiity
- Oil leak
- A6 c4 2.8 30v weird engine problem
- Problem after fixing heater box radiator
- 1996 Audi A6 Quattro Coolant issue
- A/C compressor only start working after 2k engine RPMs
- Rear bumper removal - Avant
- Air only coming from central and side vents
- AUDI Parts Motherload
- Charity rally in an A6 2.5 TDi - need input
- OBD1 VAG Scanner
- Windshield wiper not working
- 97 a6 Quattro avant hard shifts stuck in gear sometimes
- 1997 A6 battery draining when car is running + not charging
- Hi i need some help with a oil thirsty c4
- Audi S6 Plus Sedan 1996 Restoration Project
- no power steering assistance
- Would a tow bar from a 80 fit a C4 A6?
- Found my C4 Avant, now need some bits
- Audi 100 s4 4.2v8 -94 restauration
- Audi A6 C4 2.8l boiling
- instrument panel
- Front control arm bolt/subframe bolt unavailable
- looking for clean C4 Avant
- 100 URS4 repair manual available ?
- 93 100 s location fuel pump relay
- Audi A-6 2012
- door locks keep making sounds and flatting my battery
- Fuel gauge
- when i lock the car it beeps then stops repeatedly every 10sec!
- No start
- Horns Ebay the bad and the good
- 1994 A6 2.8 auto gearbox issue
- 1993 A6 2.8 auto gearbox issue
- 1992 audi quatro 100 wont shift
- Windows won't roll down
- 93 audio 100cs quattro
- Harmonic Balancer
- Starting Issues 94 2.6E C4
- SRS / airbag problem all ignitors to resistance
- Looking for some help.
- 1993 100S C4 Odometer dead.
- hard steering at idle
- secondary air injection cleaning
- Hi audi a6 c4 no air coming out of outer or central air vents in any position, but s
- parting out a black 97 A6qa beige interior
- 1993 100 quattro won't fire after had gasket swap
- where is the kick panel on a 1990 audi 100-
- car alarm won't set properly...help!
- 1994 a100 intake air valve
- need new tranny how do you pull the shell of the frame?
- 1996 A6 rear struts replacement - need advice
- '96 A6 Defa RF Remote Ordering Info
- 2001 audi A4 Symphony sound system
- Audi 100 Cabriolet Hardtop - Wiesmann Roof
- Audi A6 C4 Sedan V6-2.6L (ABC) (1996)
- Bentley Manual Needed Please
- SAFE MODE PROBLEM
- Hood latch won't release
- a6 quattro auto wont shift past first
- A6 beeping while driving -no warning light
- Alternator issue please help
- 1990 Audi 100 quattro turbo build
- C4 S6 4.2 V8 Parts Issue
- Timing out by about 45 degrees.
- 1993 Audi 100cs Q Oil alarm buzzer
- Video: Replacing the camshaft on the V6 engine
- 1990 Audi 100 Quattro Heater Issues
- Audi 100 overheats...
- Audi C4 tuning compilation video! Check 'em out!
- Stabilizer bar
- Heater Core replacement and a/c repair
- Vacuum line question w pics. Thx
- no compression in valves
- Which Bentley? And advance request for help re: vacuum line.
- Could someone tell me what this part is called?
- Anyone have any ideas about this? (Electrical)
- Slipping of gear.
- Connections on rear wiper motor '97 Avant
- Fuel filter
- 97 Avant weird coolant leak (2.8)
- Spark plugs
- Video: Repairing the intake manifold of the V6 engine
- Outer shaft
- Audi won't move
- Audi 100 c4 Quatro swap
- 1992 Audi 100 s 5 speed doesn't run fix or parts
- Rear ABS sensor's connectors do not match
- Engine not starting up
- Auto will not go into reverse gear until oil is warm
- 96 A6 Quattro 2.8L - rough shifting - need help :(
- judder/misfire emissions issue
- 100 1993 Power Windows issue...
- Differential or Transaxle 95 A6 Wagon?
- 1995 A6 Wagon AAMCO Warranty Differential
- New to me 1995 A6 a/c question
- central locking sometimes wont work until i re insert and remove ignition key
- litres of atf required by audi A6 1997
- Mystery no-crank 1991 Audi 100
- Rebuilding your old power ZF steering pump
- Final drive question
- updated replacement Audi cruise control module
- Audi 100 Quattro,Full stainless exhaust
- manual
- Starter 95 A6
- gear indicator in cluater
- Rear window sunshade
- Brake Lights Do Not Go Out
- Error in the instrument cluster
- Gearbox doesn't go into reverse, and 4th
- mechanic says I need a new engine
- 1992 100CS Engine swap
- 1993 audi 100cs brake light question
- Audi A6 C4 illuminated sun visors
- Henry
- i need radio code for audi audi a4 2008
- Jack Stand Location
- ho do I force tiptronic into failsafe mode...
- WTB 2 breather hoses for 1993 audi 100s
- 97 A4 factory alarm
- 1991 Audi 100 VSS
- Audi 100 1994 2.6E ABC wont start
- Coolant drain plug
- 4B0927156G Transmission Control Module
- 1994 Audi 100 just sent all of the water out of the cooling system
- Ignition problem 2007 Audi a4
- front Cigarette lighter plugs not working on my 2007 A6 quttro\
- Help needed! Audi A6 1995 Avant backseat removal
- Interesting issue nobody can figure out
- Cam belt change ++
- 95 S6 - opinions?
- Remote key fob
- 97 A6 trunk question
- 1993 100cs, Need underhood wiring info
