PDA
View Full Version : Audi 4000 / Coupe GT Discussion
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. NZ: Highbeam Toggle
  2. 1986 4000 Gear Issues
  3. 1982 4000 Diesel fuel neck leak mystery
  4. Wire from fuse box to fuel pump issue
  5. I got all the way to injector reinstallation before the plastic broke...
  6. Reimport this beautiful 4000 Quattro
  7. Turning signal stopped working
  8. 1986 4000 Trunk Issues
  9. 1981 Audi 4000 5+5
  10. How do yall install the exhaust over the rear axle?
  11. ECU reinstall ! Can’t remember how!
  12. 1984 4KQ rear power door locks
  13. Audi 4000 windshield wipers, power windows, heating fan stop working at the same time
  14. I was gonna build a roof rack...
  15. Windshield GT
  16. 87 4k cs q fuel pump issue
  17. Window weatherstrip
  18. Window micro switches
  19. Doing some tinkering, got some questions
  20. 2023 Spring Yard Sale; 1986 Coupe GT, 1993 90quattro and Interior Sets
  21. Potentially selling my coupe gt, looking for advice/ interest
  22. Seat bolster
  23. 86 Coupe GT Power Steering Hoses Set of 3 Group Buy
  24. Plastic side trim for Coupe GT
  25. 20vt head on JT?
  26. Fuel pump issues,
  27. Found some heads
  28. Father/Son Project car?
  29. My CGT's Future (maybe megathread?)
  30. H&R Lowering Springs Part Number?
  31. Driver side CV axle removal
  32. Sediment-mixed oil or factory rust prevention?
  33. 1983 4000S Part out or parts car
  34. Long crank after sitting for several weeks
  35. 1983 4000S Timing Cover?
  36. 1983 4000/80 Parts Diagram?
  37. Random unconnected plug
  38. 86 4K Q black
  39. 1983 Audi 4000
  40. ‘86 Coupé GT automatic
  41. Can't figure 4KQ fuel issue, crying here!
  42. CGT Special build for sale
  43. 84 Coupe GT- Performance Options
  44. 84 Coupe GT- Performance Options
  45. SoCal 5 Cylinder Service
  46. Door trim
  47. Pinstriping?
  48. Repair manual for 87 Coupe GT
  49. DM10 in Gilmore this Saturday, anybody going????
  50. Center differential connecting piece
  51. 4kq temp sensor kills engine
  52. WTB fuel tank for 4000 cs Quattro
  53. Sun visor clips + engine hood cable
  54. '85 GT: Need differntial and/or trans assembly - hydraulic clutch
  55. 87 4000 Quattro cs no start... help...
  56. Vacuum tube size?
  57. 1984 Audi 4000 Cranks, no start
  58. 85 Coupe Gt issue
  59. Seat lock
  60. Passenger front fender wanted
  61. 1987 4000s only driver's window works
  62. Adjusting speedometer
  63. Audi Coupé history
  64. Audi 4000 S quattro 20v
  65. Anyone know where to find passenger front bezel for 1985 GT?
  66. 1987 Audi Door Skin
  67. 1984 4000Q HELP needed fuel is dizzy
  68. Looking for a Coupe GT!
  69. Audi Coupe GT Fuel Sender Part # 857919051A
  70. FWD 4000 lowering?
  71. Window Motor Mounts
  72. Fuel tank sending unit for 1987 Coupe GT with 2.2L engine
  73. 85 4KQ headlight plug
  74. Thinking about selling in VT/NY ?
  75. Proportioning valve help, recommendations
  76. Trunk won’t open 86 4K
  77. Hood release latch broken
  78. Parts?? Help!
  79. Lighting for 4KQ
  80. Hello hello directions needed
  81. Fuel dizzy help
  82. 83/4 coupe gt floor pan
  83. #5 Relay Main Fuse Box Part Number
  84. Wanted rust free passenger door and windshield frame for '86 Coupe GT
  85. Distributor
  86. Audi 4000 Quattro Intake Manifold Removal
  87. Rear Window Louver
  88. Looking for windshield and other parts
  89. 1987 Audi 4000CS Quattro CIS Issues
  90. Power Steering hose solutions?
  91. 3b downpipe into a 86 4K Quattro / 115k 86 4000 Quattro for sale.
  92. Newbie with an 81coupe GT....
  93. !985 Audi Copue NYC
  94. Brock Yates Audi
  95. Door Seals Too Small for Doors. Solution?
  96. Vacuum line routing
  97. Fuel pump relay that primes - Part number?
  98. Looking for a San Diego area mechanic
  99. What Audi is it?
  100. 4000 intake preheater thingy
  101. Front reflector lens
  102. 1984 4000 S Quattro
  103. Harbor Freight Jack Stand Recall
  104. Fuel and Temp Gauge Failure
  105. ISO window motor - left front 4000
  106. 4000 died and wont start
  107. looking for Greg Haymann from AutoFirme
  108. Time to stop lurking (87.5 Coupe GT)
  109. loss of acceleration
  110. Changing engine mounts
  111. Coupe GT guidance PLEASE!
  112. Swapping 4K and 5K transmissions, rear diff too?
  113. Mirror Interchange
  114. '86 Coupe GT Cold Start Problems. Please Help!!!
  115. '87 4KQ Lighting Options
  116. How much is too much for a 10V 4KQ?
  117. Fuel pressure Regulator valve question
  118. 85 Audi 4000 Parts Car
  119. Bench bleed clutch master
  120. Too much pressure?
  121. ADDCO sway bars
  122. Audi Gt coupe/4000 repair manual
  123. FiTech to replace CIS
  124. 1987 Audi GT Coupe Starter Relay location?
  125. 1987 Audi GT Coupe ignition switch replacement
  126. Clutch slave roll pin dimenstions
  127. PCV location
  128. 1987 GT Coupe Starter replacement
  129. Wheel options for a 1985 CGT
  130. 1987 Audi 4000 Quattro Issues
  131. 1984 CGT issues
  132. 1986 coupe GT - Heater Core Flush
  133. Instrument cluster
  134. AUDI Parts Motherload
  135. Does 85 CGT have a knock sensor?
  136. Need new dashboard for 1983 Coupe
  137. 1981 Audi 4000 Odometer
  138. Headlight options
  139. I looking for fabrics for my Audi coupe 1986
  140. Cheater Turbo on 10V?
  141. What fluid for 5 speed manual?
  142. 1987 Audi 4000 CS Quattro - Parts Car for Sale
  143. Glass Sunroof
  144. Windows fuse
  145. My 4000 is dead in a parking lot!
  146. Chevy 4.3l swap
  147. 84 CGT Grill
  148. Transmission Options for my 4kq (Repair or Swap?)
  149. Audi 4KQ runs super rich
  150. upshift switch location
  151. Rough idle solved?
  152. New '86 CGT Owner
  153. 1986 coupe gt thermostat housing 034121121
  154. Shifter linkage bushings
  155. Thermostat change 1986 coupe gt.
  156. 1986 Audi 4000 Quattro
  157. Son just picked up a 1982 Coupe, lowering ?
  158. Shifter linkage issues? Can't find any gears stuck in 5th
  159. 1984 Audi Coupe GT performance ideas
  160. air intake hose
  161. Audi A4 1.8t B8, Water not rotating Air Lock?
  162. New member ‘85 GT
  163. Fueling issue on 1984 Audi coupe GT
  164. A3 2011 Fuel filter
  165. 1986 Audi 4000CS quattro Air flow meter
  166. In need of digital dash 4.5w bulb for my '86 GT
  167. For Sale: 1986 4000 CS Quattro w/ euro lights
  168. New Audi 4000 owner! Restoration thread
  169. Audi 90 typ85. Cylinder head conversion
  170. 4000Q starts rubs for 20 seconds and dies
  171. audi 4000 sunroof seal replace
  172. 84 coupe cv axle
  173. I Audi 80 Cabriolet service , upkeep - Garage?
  174. Flywheel advice
  175. Hesitation on starts
  176. Probably have to sell my CGT Special Build
  177. 84 Audi gt coupe parts availability
  178. Free Parts - Audi 4000S 4 Cylinder
  179. EEK,EEK from drivers door
  180. 84 4000s runs rich and misfires
  181. correct fuel pump relay part number
  182. 1985 4000S Quattro O2 sensor reset
  183. mass air senor
  184. Kudos..
  185. Quattro exhaust systems
  186. Keep blowing relays
  187. Recurring spongy pedal 4000 Quattro
  188. 1985 4000S Quattro Fuel sender location
  189. Coupe blowing relays
  190. Sources for used parts
  191. Best oil for noisy lifters on startup
  192. selling Audi4000 S Butterfly
  193. WTB: 1985 4000 S Fuel distributor
  194. 85 4000 S running very lean
  195. Fuel and brake lines
  196. 85 CGT warm starting & stalling Issue - Fuel
  197. 1985 Audi 4000S, Cranks but will not
  198. AUDI COUPE TAIL LIGHTS
  199. '85 CGT front subframe rear bushings
  200. Fuel System in 1981 5+5
  201. 1984 3 speed Automatic transmission
  202. Etch
  203. 86 4000 quattro fuel leak from airbox
  204. Replacement of vacuum advance for Coupe GT
  205. Headlight swap
  206. How to identify 85 CGT engine
  207. reverse light and brakes like
  208. Audi Fuel injection
  209. 1987 Audi 4000S
  210. 1984 4kq: Resurrection
  211. 1985 4000s wont keep running
  212. 1986 Audi coupe GT - Coolant lights comes up on acceleration
  213. Forum Rebirth
  214. Four spoke steering wheel
  215. Coupe GT - buyer
  216. help with headlights
  217. Audi 4000Q (been sitting for 4 years)
  218. H and R lowering springs and bilstein strut
  219. New owner - 1986 Coupé GT
  220. Brake line flare for 1986 Coupe GT
  221. Low beam headlights
  222. Will 17x8 et 43 wheels for on a coupe gt?
  223. Check out my 85 4000s
  224. 1986 Coupe GT Brake Lines from Brake Pressure Regulator to Master Cylinder
  225. Coupe GT shift finger
  226. 86 Audi4000cs quattro Gauge Cluster
  227. For Sale: 1987 Audi 4000 Engine, Fuel System and Exhaust
  228. looking for doors for an Audi 4000 w/vent-windows
  229. audi 4000 parts
  230. Performance Exhaust GT coupe 86 ?
  231. Engine wiring help!!
  232. Audi 4000 Door Handle Retrofit?
  233. FOR SALE: 1986 Audi Coupe GT
  234. Need advice guys
  235. Anyone selling coupe gt
  236. sell steerling wheel Audi GT Coupè
  237. 87 CGT coolant temp issues
  238. 4000cs quattro throttle issue
  239. CGT tstat housing stuck?
  240. 87.5 CGT SB rescue
  241. Black Friday/ Cyber Monday deals from Car Parts Discount
  242. New 4000 to me
  243. 4000s Quattro IAC Bad
  244. Audi Coupe GT floorpan vs Audi Coupe Quattro floorpan
  245. 87 Audi 4000 S Check Engine Light
  246. Quiet(er) Radiator Fan Suggestions
  247. WHAT NOW!?!
  248. Special promotion for Audi World Forum members
  249. Forum group buy with Car Parts Discount
  250. Bleeding brakes '87 4000s (FWD)
