PDA
View Full Version : S4 (B6 & B7 Platforms) Discussion
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213
  1. Would a 06 b7 rack fit into a 05.5 b7?
  2. Android 12 Car Radio With 8GB RAM 128GB ROM & wireless Carplay Android Auto
  3. 2004 Audi B6 V8 S4 Resonators Removed Borla Exhaust Startup Revs and Acceleration
  4. 04 S4 Top Can’t Go Inyo Trunk
  5. 20% off our bright D1S / D2S / D3S LEDs! These are brighter than xenon bulbs!
  6. B6 Power steering component replacement
  7. 4.2 bhf vs 4.2 abz for turbo applications
  8. Rewiring Secondary Air Pump (B7 S4) - Pulling Engine Wire Loom
  9. Dashboard warning light
  10. Jump in Transmission when coming to a stop ?
  11. Crank no start s4 b7
  12. color of wires of ecm power relay
  13. I just bought 2006 audi S4 Quattro
  14. I just bought 2006 audi S4 Quattro
  15. S4 B6 Automatic to Manual
  16. Christmas Holiday Sale
  17. Best Coilover Setup B6 S4
  18. B6 S4 Sunroof Problems
  19. Please help 2005 s4 b6 error code p0171 and p1579
  20. BLACK FRIDAY SALE / CYBER MONDAY ON NOW @ deAutoLED.com – bright error free LEDs
  21. BLACK FRIDAY SALE,, SuperSprint Italy
  22. Power Steering Vane Orientation Question
  23. Automatic trans control module location
  24. Audi A4 Avant semi automatic b6 model
  25. VIBRATION UNDER LOAD! (trying again)
  26. B6/B7 S4 Rear Mount Turbo Kit Dev
  27. B7 S4 clunk/rattle noise
  28. Hesitation after gear shift
  29. S4 B7 Engine Noise
  30. S4 B7 Engine Noise
  31. Avant Hatch/tailgate compatability with A4
  32. Clutch won't disengage
  33. B6 s4 - Fog Light Grille - HELP
  34. Look free led lights
  35. It's was not a good day yesterday !
  36. American message board members.....
  37. B6 vcds cam measurements
  38. Strange problem on S4 2004
  39. Please Help
  40. 2006 Audi S4 Help
  41. Greetings from SuperSprint Italy
  42. b6 s4 cabriolet seats
  43. seeking mechanic - long island, ny
  44. Battery Replacement -Sorry For Such a Noob Question!
  45. S4 Automatic Transmission Hose Supply Line Clip??
  46. Speed in each gear? Is top governed?
  47. B6 S4 Horsepower
  48. 4.2 power steering
  49. Motor mounts too ?
  50. No start
  51. Is this Oil in Coolant? B7 S4 - Oil Cooler? Head Gasket?
  52. Which module does this k line go to?
  53. What is this connector - engine bay left side
  54. B6 S4 how to get over 400HP
  55. Check Timing on B7 S4 Without Removing Engine?
  56. 20% off NEW D3S/D1S LEDs FOR 2023 –Bright - NO ERRORS - PLUG & PLAY - NO wires!
  57. B7 S4 won't start
  58. S4/B7 - Clutch Kit/Flywheel Recommendations
  59. Misfire or stumbling when warming up
  60. S4 BHF Spark Plug tube very rusty
  61. Left turn signal does not work on 2004 Audi s4 b6
  62. Black Friday // Cyber Monday Sales on now – Bright error free LEDs @ the best prices!
  63. Black Friday // Cyber Monday Sales on now – Bright error free LEDs @ the best prices!
  64. 2006 Audi S4 Codes
  65. S4 separating Auto-Gearbox from Engine
  66. Shop recommendations in Knoxville, TN?
  67. 2004 Audi S4 no crank, no start with ESC light.
  68. B6 4.2 BBK Ticking noise on idle (video)
  69. Headlight reflector
  70. BG: AUDI S4 B7 4.2 OIL IN COOLANT
  71. 2008 audi s4 cabriolet
  72. UK: S4 Complicated Radiator Fan Issue
  73. Accessory belt tensioner?
  74. Crank no start, water damage?
  75. B7 Audi S4 base sedan OEM badge replacement
  76. Can bus issue - won't connect to scan tool
  77. Lack of power?
  78. Battery dying over night - radio stays on
  79. Turn signal and brake warning light - both work
  80. Convertible issues
  81. Audi s4 b6 vvt solenoid
  82. Looking for some input on an 05 S4
  83. Abs,esp lights on
  84. Vacuum lines missing - routing help
  85. 2006 S4 p0343 p0358 p0444 p0308
  86. B7 current value?
  87. Bank 2 rich?
  88. Looking for a B6 or B7 Audi S4 in or around arizona
  89. B6 S4 needs Doctor or Lawyer or maybe Mommy
  90. Oil pressure relief valve issue
  91. Strange issue with convertible roof
  92. Looking for some advice on an 2004 S4
  93. high pressure pump
  94. Vacuum Line Placement on B6 S4
  95. Burning oil and running lean.
  96. S4 2022 19 inch summer tires
  97. Oil Pump Removal, shaft too long?
  98. 2007 S4 avant throttle body problems
  99. Will these wheels fit?
  100. Trunk only opens with the key
  101. Just curious, before I buy.
  102. 1/4mi WORLD RECORD: B6/B7 S4
  103. getAudiparts.com | Your 2021 Black Friday/Cyber Monday Savings are HERE!!!
  104. Build questions (new owner)
  105. 4.2L loss of power, high idle only at operating temp and engine stalsl when braking
  106. Is B7 S4 any more reliable than B6 (cam chain guides)?
  107. I need help pls
  108. talk me out of a B6 Cabrio please...
  109. PDF Owner and Service manuals for B6 Cabrio?
  110. ZF Gearbox Grind on Cold
  111. EGR / Combi Valve Removal in car?
  112. Missing part in my car
  113. 2004 S4 alternator blue wire
  114. Nice 06 S4 Looking for a new Home, DC Area
  115. S4 serpentine/accessory belt
  116. Value of a 2006 S4
  117. Transmission valve body
  118. Buying first audi, 2006 S4
  119. UK: Help required - A4 2005 diesel. Wont start
  120. S4 2005 Cab
  121. UK: Does anybody know this Silver S4 Cabriolet - Reg: C11 UDK / C11UD K
  122. DOOR UNLOCK CONTROLS-LONG STORY-NEED HELP
  123. Starting Problem
  124. Timing advance s4 b6
  125. Soft top issues
  126. ECM Coding?
  127. Radiator fan issue.
  128. Trans not shifting
  129. Cooling Fans
  130. Firewall Plug Identification
  131. GROUP BUY | Schwaben Professional Scan Tool 25% to 40% off | Closes April 1st, 2021
  132. Need help! B6 S4 loss power now won’t start
  133. I want to know the compatibility of coil springs.
  134. 25% off your Favorite brands during PERFORMANCE WEEK!
  135. 4.2 Longevity
  136. Does my key fob have to be programmed to my car to start it?
  137. Radio stays on after turning car off and removing key plus key fob questions
  138. Grille
  139. 2004 B6 AUDI S4, AUTOMATIC gearbox
  140. 2004 B6 AUDI S4, AUTOMATIC gearbox
  141. Oil pan gasket
  142. getAudiparts.com | Last Minute Holiday Savings Promo Code: HOLIDAY2020
  143. Prospective Audi S4 buyer looking for advice
  144. Not Starting After Changing relay 219 & 373
  145. Mystery Bolt Help
  146. P0101 Code
  147. S4 Avant B7 - bilstein coilovers??
  148. Water Inside - crazy issues
  149. deAutoLED Black Friday and Cyber Monday sales are LIVE NOW! Best prices of the year!!
  150. RS4 BNS MED 9.1 VSS signal
  151. 2.7T swap
  152. Wheel fitment
  153. Turbo or supercharger 2006 s4 4.2
  154. B6 S4 Scraping/bearing noise
  155. Unknown Hose
  156. Readiness code sequence 4.2 BHF engine 2004 S4
  157. Help with valve cover gaskets
  158. b7 s4 vs a4 same year
  159. 2006 Audi S4 Auto - Transmission failed???
  160. 2006 AUDI S4 - Advice Needed
  161. Symphony Radio connectors
  162. Need directions for restoring s4
  163. B6 S4 Wreck. Restore or salvage?
  164. B6 s4 diff shaking
  165. Got Beat By Stock 2015 Taurus Sho
  166. Got Beat By Stock 2015 Taurus Sho
  167. S4 4.2l won’t start
  168. S4 "soft top not secure" warning, now back passenger window only rolls up half way
  169. 06 S4 no crank, no fuel pump, no start..where do I start?
  170. Cruise control issue
  171. Timing Issues
  172. 2004 S4 question about engine
  173. Car won't start or crank after refueling.
  174. Lowering my S4 Avant b7 with springs
  175. How bulletproof are these engines (after timing chain fixed)?
  176. Should I drain & refill transmission at 135K?
  177. If you were me, would you buy this car?
  178. Oil leak in my Audi S4 B7
  179. European Car Stimulus SALE! Over 50 brands ON SALE
  180. Forum Noob Scared to buy 06 Audi S4 4.2 V8 6M- HALP!
  181. S4 CCM/Trunk Lid Problem
  182. Starting Problem (B7 S4 Cab)
  183. SSR AUTOBODY ♖ | SoCal's #1 Source for Quality European Collision Repair!
  184. Suspension problems
  185. My 2008 S4 Avant is gone
  186. Engine surge
  187. 2016 S4 - Let's talk tires!
  188. Misfire
  189. Suspension problems
  190. SAVE up to 15% of Service Kits at ECS Tuning!
  191. FI: Lights flickering/pulsing, help!
  192. Audi 2015 S4 Remote reprogram
  193. Sale TIME! Performance upgrades up to 15% off!
  194. 2008 Audi s4 for parts or projects (whole car) 3000$
  195. For Sale White B6 S4 Avant
  196. No crank
  197. P0011
  198. Just a click...wont start please help :(
  199. Oil pressure sensor
  200. Can’t find crank position sensor
  201. Do X pipes matter?
  202. Dennison/Playing music from iphone
  203. Audi S4 B7 2004 Key fob
  204. Omg...bought a second one in less than a month
  205. SALE ALERT|Genuine Volkswagen Audi and European Parts are ON SALE
  206. Anyone recognize this exhaust?
  207. Lights not turning off intermittant
  208. How to diagnose engine surge?
  209. Cyber Monday SALES EXTENDED!!!!!
  210. New to Us 2004 s4
  211. Swapped ecm plus ignition switch with matching key
  212. getAudiparts.com | Black Friday/Cyber Monday FREE SHIPPING + Promo Code!!!
  213. Over 90 Brand up to 50% off| ECS BLACK FRIDAY
  214. SORN in place ....time for noggy to hibernate ....tips for winter hibernation , Outsi
  215. Need help: Bank 1: Camshaft (Intake) - P0011- Retard Setpoint not Reached (Over-Advcd
  216. S4 Quattro Recommendations
  217. HELP: S4 B7 CRACKED Radiator. Need Solution
  218. side mirrors won't unfold
  219. Audi S4 B7 - Long cranking, no hot/cold starting, extended cranking; SOLVED!
  220. Instrument cluster dimming/flickering
  221. 07 S4 Sudden Misfire and Brake Failure
  222. 2003 Audi S4 Wont Start!
  223. obdeleven with S4/b6
  224. Electrical connector identification help
  225. 2005 s4 b6 head light issue
  226. Buying first s4
  227. Audi s4 b6 avant Will not start
  228. Need to re-pin fuel injector plugs.
  229. 2006 Audi s4
  230. Hole in my piston :( Please help!
  231. 2007 S4 (B7) Wont Start
  232. B6 S4 catalytic converter
  233. Should I sell my 2005.5 B7?
  234. Sudden increase in fuel consumption
  235. Left turn signal 04
  236. Need recommendation on Scanner and repair manual
  237. Missfire when press the gas padel. at Idle it looks ok?
  238. Shifting issue 2004 B6 S4 V8 CAB TIP
  239. Anyone 1/4 mile their S4?
  240. B6 engine mystery
  241. Interior Trim Pieces - 2007 S4 Cab
  242. fan
  243. Good Day at the Track
  244. ECU upgrade or chipping a naturally aspirated engine (4.2 lt) is it worth it?
  245. B6 S4 stalling out after 20-30 minutes of driving
  246. Compression test
  247. Audi S4 B7 (2006) - Cranking but WONT start
  248. s4 Convertible RS Grill
  249. s4 launch issues
  250. 2003 B6 S4 issue
