View Full Version : VAG-COM Discussion
- 2001 Audi S4 Blinkers, WIpers, Climate control not working
- rear wiper-servise position
- 2023 Q3 S-Line 45
- Turn signals not working
- Left headlight power output stage
- Subwoofer check?
- Confirmation needed on VCDS cable
- Inability to find #53- parking brake for RS5
- 2015 Q7 TDI Reverse Light Error Coding
- P201500 error after replacing manifold
- HighBeam assist issue (another one)
- Clima control panel change farenheit to celsius
- CAM Timing +5.0 on Module 93
- CAM Timing +5.0
- I purchased a VCDS, but because I don't know the "security access key", I can't do th
- Transmission control unit 004 No signal/communucation - intermittent
- PL: plik do parametryzacji B&O A5 Sportback
- 2016 Q7 heating issue
- comfort module error
- UK: VCDS scan help please
- UK: Bunch of errors out of nowhere
- 2015 A3 quattro has me stumped
- J500 Steering Module lost communication 2013 A6
- Q5 interior/reading light
- Erwin Portal Reprograming
- B1073 14 [137] - Open or Short to Ground
- Help identify this plug
- Engine (?) plugs
- UK: Crash repair A5 with MHEV battery problem
- Engine mount plug
- TR: A6 c5 interesting problem
- A6 c5 problem
- Does unlocking fsd void your warranty?
- “Audi side assist: system fault”
- Front camera problem??
- 2023 A6 Allroad Tech Not So Good
- Trailer detecting bypass?
- AUDI A4 B9 code fault after tow bar installation
- Need help with decoding LIN bus
- Clearing faults in OBD solves issues temporarily
- [BAP_OnlineFunctions_0x2A communication error bap_error_timeout heartbeat]
- VAG fault code 9735701 (PASSENGER PEDESTRIAN CRASH SENSOR)
- No ODB communication
- DPF reading query
- Audi 200 - Starter cable
- OBD2: Enable map panning while in motion
- My 2013 A6 prestige 3.0 cranks but no start 4 minutes later starts right up
- DK: HVAC control unit replacement (CP) A5/F5
- VAG 908 Mystery Cable?
- Q7 Audi MMi missing Data and rear camera doesn’t work
- Coding Used Transmisison
- Navigation not activated voice message when pressing mute multimedia button
- 00457 Fault
- NAV, Bluetooth, Telephone, Alarm Issues
- Is VAG-COM What I need? Airbag Replacement
- 00668 - Supply Voltage Terminal 30
- How to interpret valve timing data
- Pinout of the data bus block (gateway) AUDI A7 hybrid 2021
- Front Camera Won't Calibrate ADAS - Data Bus Error
- VAG COG Help with Parking Camera Code
- Bose sound update
- Audi A3 front airbag sensor issues.
- Audi 2015 A3 Quattro 2 liters EPC + Check Engine light with cylinder misfire issues
- Airbag
- D2 immobilizer issue after battery change.
- Audi A3 e tron P0498 P0449
- Can camera be Basic programmed with VCDS? 2012 A8L 4.2
- Denver area battery replacement
- VCDS upgrade, HEX-NET vs HEX-V2, is mobile worth it?
- Distance regulation in adaptive speed control A6 Allroad 2021
- Almost half my modules are getting Databus missing messages errors
- intermittent working MMI- VCDS scan results
- HELP! About to give up on 2013 A5 Conv
- Trans. Range Sensor - bad warm start
- Help Interpreting OBD Codes from Dealer
- Audi s5 b8 display on cluster stuck?
- Engine and sensor harness
- Help with MAP wiring 3.0t
- Fans not on after car turned off
- UK: Audi A6 1.9 TDI starting problems
- 5F-Info Elect. Module - Invalid Dataset, Software Version Management not compatable,
- Audi A6 C6 2.0 TDI fuel indicator not working
- Front impact sensors
- 06 quattro key problems
- RS: A6 C7 folding mirrors?
- IE: Audi a7 120 errors of lost communication
- Scanner VAG-COM, OBD11 ETC.
- 2012 A7 Multiple Fault help needed
- Replaced steering wheel * button programming
- 2018 SQ5 - Steering wheel angle sensor adjustment problem
- Audi A3 2020 8Y wireless carplay
- Surround View menu not showing up when the gear is in Reverse
- Module 10 Park/steer does not store new code
- Reversing Camera Help
- Audi Lane Assist Camera causes ACC + Audi Presense to disable
- RS: Audi A1 8X daytime running lights coding
- Audi A4B8 Electrical Fault
- Audi A6 taillights upgraded from 2014 to 2021 - NEED CODING US-EU!
- Ambient light activation
- Help coding heated steering wheel A8 D4
- 4M0907129HA Control Steering switch teardown anywone?
- NO: Do I need to code a new Steering wheel control module?
- [VCDS] How to activate Coasting mode in Audi from US
- OBD
- Audi long-term memory showing odd numbers
- Help. New user. Electrics problem.
- A3 8P 1.6 FAULT CODES. NEW USER HELP!!
- Q7 Vcds coding 07 control head rear view camera
- Power steering hard after clock spring replaced
- Audi a6 2.5 tdi v6 Weird Noise
- UK: 2016 AUDI A3 E TRON/ETRON 1.4 FAULT CODE POAA600 AND POE7400 HELP PLS
- 0E media player 1 location
- 2022 Launch Vagcom scan tool
- SE: Audi a8 aux heating stop working Webasto
- 2009 Audi A5 No Start - VagCom Scan
- Audi A3 ESC Malfunction
- UK: 13.1volts
- Q5: 5258753 code - Steering End Stops not learned
- Audi A4 Allroad B8 ACC wont work after replace
- Locked Pin on a charger.
- Homelink available in ACC mode
- Audin A7 2015 Headlamp not adjusting
- VCDS now wont read airbag controller after glovebox removal?
- 99 Audi A4 Quattro 2.8
- Audi a4 b8 mmi buttons not working
- UK: 0308 Local data bus 2 HVAC blower not working
- vag gateway problems help
- A4 cabrio B7 sync error rear window
- Parking Sensor Issue - A6 C7
- Audi Q8 Fuel level issue
- 00512 unknown code
- Anyone in Dallas have a VCDS or similar?
- New ECM problems
- 2017+ Audi R8 VAGCOM mods list
- RO: audi a6 4g confort
- 2012 A6(C7) ABS Module Vagcom security key?
- Throttle pedal re-calibration
- All (4) 12V Outlets Are Dead
- Interior & Exterior Light Fault
- Air conditioning faults
- Cheap and easy way to change idle rpm
- B10151b igniter for battery interrupt
- How to code out brake sensors with vcds
- A4 b8 electrical problems
- Audi adaptive light system fault
- 05 A6 3.2 electrical problems
- Multiple warning lights
- Fayetteville VCDS?
- Log of door opening or lock/unlock
- HELP limp mode Fault but perfect otherwise
- Enabling Matrix Lighting?
- CZ: Audi A6 C7...... I m idiot... bad coding
- VCDS cant connect to PDC block
- Audi A6 FL RVC canbus
- Speed Warning
- PL: audi q7 4m power steering after flash lost parametryzation
- MMI module locations for b8.5 s5???
- First scan help
- A4 Headlight Control Module Coding
- 4month delay in getting new gateway module…..so far.
- NO: Audi A4 B7 AFS headlight downgrade
- OBD wiring
- Wiring Diagrams
- UK: RS6 C7 STAGE 1. No COD?
- A6 4F CAN Separating connector
- A6 C5: Dedicated Gateway Module (2005) vs Instrument Cluster (Gateway?)2003
- Parking Brake Malfunction
- VCDS on Linux
- Anyone in South FL? 2014 2.0T Q5
- Pinouts
- IE: 2005 Audi B7 1.9 TDI Glow Plug Light / Engine Flashing & Limp Mode
- VCDS issues
- A4 B7 instrument cluster/immobiliser fault.
- 2010 A6 Prestige - Speaker Issue
- ECM Problem K-Line Code
- Faulty MMI (Switching On And Off)
- IE: Balance shaft delete rough idle ?
- Short Term Fuel Trim Jump with 17705
- Screwed around with the Green menu... how do I go back
- Coding the battery-how difficult can it be
- Audi TT mk2 VCDS enable lap timer red tacho lcd
- HELP! Menus unavailable after vagcom/green menu coding
- Which Diagnostic tool?
- Noob question about error code interpretation (Function Restriction...)
- Vagtacho or Vag Commander link?
- PL: AUDI S5 2014 taillights Canada to EU
- Seat Heater Plug Replacement
- Convenience Option won't work with Keys. Any suggestions?
- Stabilisation Program Fault w. TMPS alarm concurrent
- ODB-activating lane assist
- Any of the eBay diagnostic cables any good ??
- AU: Replace battery, no BEM code?
- UK: ULEZ
- EU coding of rear lights Audi Q7 2013 Prestige
- KR: I need help with 2014 Audi A7 C7 Fault Codes and warning lights
- Discharge the car battery when the car is closed
- Audi A3 Component Protection
- VCDS or OBDeleven?
- VAG-COM for sale, unlimited VINs
- How to disable auto headlights
- Car won`t start, display all black
- Sourcing a HEX-V2 (or help coding) in LA or SF
- Vag tool options
- Vag tool options
- MMI issue Audi A3
- HU: Audi A6 C5 Parking assist not working
- Audi navigation plus
- Battery draining caused by control unit 1 for vehicles electrical system fuse
- Airbag Light On - I'm sure I messed up!!
- P0101 P0104 faults. readings MAF.
- Back probe (MAP sensor) problem
- P 2002 Help Needed...
- P0600 on 04 audi allroad 2.7
- Battery Coding Failed
- disable auto lowering air suspension
- Single Gear Display
- Auto Stop/Start
- Audi TT MK1 Electrical Issues - Advice Please
- Readiness
- ACC Retrofit coding
- Blower / Fan Whistling Noise
- VAG-COM cable question
- Please help
- Audi TT 2011 center brake light warning
- Locate Exhaust Gas Temp Sensor
- Help with VAG Logs 2008 Audi S5 4.2l 6spd
- Audi A7 fuse change now get dashboard warnings
- Audi 4G C7.5 memorize of the tilt position of the right mirror when reversing
- Audi a7 a6 c7 ACC doesn't work
- 2017 S3 Interior Lighting and MMI Issue
- Audi 4G C7 invert of led of start stop button
- Audi Q7 2018 Ambient lightning problem
- Interface not found VCDS 21.3.0
- Airbag light illuminated, 2014 Audi A5, 3.0 tdi
- 0b5 S-tronic codes
- Help reading VCDS report
- Need help with battery coding
- URGENT HELP - A7 Broken Steering Rack
- Audi A6 Lane assist retrofit
- Audi ABS fuel pump code
- UK: Need help with audi a4 se ultra error codes
- New Q3 MIB3 Fatal Error?
- A6 c7 fault codes any help please
- P0651 Open Circuit Fault
- Connect backup cam to backup tailliht
- 2016 Audi A4 interior reading lights won't turn off
- 2015 Audi A5 Front Parking Sensors are on the wrong sides.
- Audi A1 2020
- 08 A6 4.2L - 01-Engine -- Status: Cannot be reached 1100
- Audi B8/B8.5 Injector Timing
