- WTB Nogaro Avant
- 20% off our bright D1S / D2S / D3S LEDs! These are brighter than xenon bulbs!
- Low Bass Volume
- i need some help protecting a newly decked block and head
- For Sale - B5 S4 Stage 3
- Timing Alignment (Camshaft driver v passenger)
- P0300 and cyl 3 & 4 misfire?
- Car Modified Without Knowledge
- Looking at B5 S4 Avant
- B4 S4 Long term fuel trims
- getAudiparts.com | Black Friday/Cyber Monday '23 Savings are Live!!!
- BLACK FRIDAY SALE / CYBER MONDAY ON NOW @ deAutoLED.com – bright error free LEDs
- BLACK FRIDAY SALE,, SuperSprint Italy
- S-tronic problem
- Car won't start and ECU not showing up on my vag-com
- Cabin leaking problem b5 s4 any suggestions would be a big help
- I need help with my 99 S4 Avant
- S4 dash issues
- MaD wAgOn is back on the Prowl in DFW
- Any threads here of b8.5 builds?
- MTM B5 S4 Chipped ECU
- No boost after motor is fully warmed up/heat soaked
- Turning Wheel all the way = Whine/Screech - Halp?
- S4 B5 01E gearbox output shaft bearing
- American message board members.....
- Trying to identify Bilstein coilovers
- Greetings from SuperSprint Italy
- UK: Audi A4 S4 Replica?
- b5s4 No speedometer, odometer doesn’t move, throws p0501 code
- How can I unplug the media cable?
- S4 tip tune,mod ideas and suggestions
- Wastegate actuator rod rattle
- Luft-Technik Intake System
- Audi s4 b5, wont crank,spark or start fuel pump
- 05.5 S4 Won’t rev past 5000Rpms…. Help
- Looking for a contact on oem body parts
- Black out emblems for b5 s4
- ReDisc - Carbon Ceramic brake disc refurbishment & repair
- Parking brake cable replacement
- Cold clunk
- Seat rail gliders
- Rarity of the B5 S4
- Odo "self re-set"
- Engine Won’t Turn over
- Upstream O2 sensors
- 20% off NEW D3S/D1S LEDs FOR 2023 –Bright - NO ERRORS - PLUG & PLAY - NO wires!
- stock 2.8 heads or 2.7 heads
- Help install nefmoto software?
- Winter Pics
- Engine Pics
- Misfires on Cyl 1 Resolved - 2 Faults
- Does anyone know who sells piggies now?
- Black Friday // Cyber Monday Sales on now – Bright error free LEDs @ the best prices!
- AU: AUDI Convertible
- 2019 S4 Extended Warranty
- remove brake calipers without removing bleeder
- Another “what is my car worth”?
- Engine mounts
- Engine Misfiring Badly
- Oil leak at filler cap
- Price Check for used OEM RS4 Turbos and Intercoolers
- 2000 Imola S4 finally getting new turbos at 225k
- Brand New OEM Audi B5 Widebody Conversion Kit on Bring A Trailer with No Reserve
- Heater core
- Injector leak/repair question
- Oil Pressure Light when at Operating Temp under 2k rpm!
- Replacing Crank Sensor
- Very Strange Whining Noise
- 2.7T loss of power/loss of boost?
- Engine installed, no crank
- Aux Water Pump Replacement
- 2000 S4 (Duh) No start, no codes
- Rebuilding an S4 2.7t engine. Is it worth it?
- 2000 S4- Doesn't run.
- Resetting exhaust flaps rs4 b9
- Need to swap head bolts....
- B5 s4 problems
- EVAP troubleshoot B5 S4
- Can anyone help with this please
- 2008 Audi S4 Interior Parts
- Audi s4 92 aan
- Audi s4 b5 manual swap ABS/EDS swap question(s)
- Upgrading 04 s4 4.2
- PCV celaning
- Checking Oil Level
- Cant decide: B5 S4 vs C5 A6 Allroad
- Got my instrument cluster fixed, do i just plug it back and go, or anything else need
- Switch-ability of the DSG7
- Installation and coding of used airbag control module
- Turn signal bulb suggestions?
- B5 S4 2.7T or B5 A4 1.8T?
- Rev Hang Sucks. Please help
- B5 S4 Bose Static Distortion
- Someone attempted to steal my 01 S4
- Errors after rns-e install
- Engine Rebuild Shop Recommendation in SF Bay Area?
- Trouble finding coolant leak on 2000 S4?
- 2001 s4 b5 ABP engine won't start weak spark from ignition coils
- Interest in buying built 2.7 engine
- Bodywork
- To sell or not to sell...
- Where can I buy 8D0807345 fog light grill?
- Stage 3 problems
- Best Shop to upgrade turbos and tuning?
- DOOR UNLOCK CONTROLS-LONG STORY-NEED HELP
- Transmission Questions
- Andover, MA Cars Coffee Tomorrow
- Should I get coilovers?
- Miss fire from cylinder 3 to the whole bank after changing them out
- Crankcase breather
- Audi s4 ( b5) headlight working only with car off ??
- HELP!!! Please
- S4 not boosting bogs out at 2krpm
- 2005 S4 radiator fan issue.
- Need bumper cover for B5 S4, where would you get it?
- Needing help, cant program new key fob
- NO POWER STEERING HELP!!!
- Help A Recovering Avant MT Driver Pick the Next Car
- RS4 B5 white smoke and oil smell
- Audi A4 b5 rns-e uppgrade
- getAudiparts.com | Last Minute Holiday Savings Promo Code: HOLIDAY2020
- ECU Flash Question - Flash erased?
- Front Bumper Grills
- deAutoLED Black Friday and Cyber Monday sales are LIVE NOW! Best prices of the year!!
- Selling T-Box ECU w/ GIAC X chip for B5 S4 + VAG-com cable
- Cam chain tensioner
- Black Friday Sale Starts Now 10% Discount
- Winter Tires for 2019 Audi S4
- Selling my 2001 Audi S4 and new rims
- Please help with Audi B5 S4 and Audi R8 Engine
- Headlight bulb upgrade - brighter?
- 2021 S4
- 2016 Audi S4 Back Seat Removal/Unlatch
- B5 S4 Avant on New Episode of Wheeler Dealers!
- Tell Us Your Apex of Performance, Win Yokohama's ADVAN APEX Tires!
- Laser Red Right Rear Door Skin
- rs4 b7 Leaking fuel pump
- Vossen 19 x 9.5 vfs1 on B5 RS4
- HELP! AC just quit working
- Stage 3 s4 b5 srm k24s Reliability
- RS4 study guide
- Part Number Help for subwoofer with Bose system
- S4 no start. Fuse 29 blown! LDP codes
- B5 S4 Auto --> Manual swap question. What trannys will fit
- 2000 Audi S4 Hibiscus
- S4 Avus wheels. Sf Bay Area. Free.
- What are some common issues to look for when inspecting a used b5 S4?
- S4 b5
- Requesting Help With New B5 S4 :)
- 2001 s4 no start condition
- SSR AUTOBODY ♖ | SoCal's #1 Source for Quality European Collision Repair!
- What to replace when doing timing belt
- Infestation and identification
- No heat, stuck open thermostat?
- Audi S-line Key
- Requesting help with new B5 S4
- WTB: B5 S4 OEM interior aluminum trim set
- WTB: complete owners manual and binder
- boost duty cycle issues
- Dash Light & Turn Signal Issues
- Overboost issues k24
- audi s4 b5 oil in coolant
- S4 B5 won't move
- Would these downpipes fit my s4??
- 2000 Audi RS4 B5 Parts availability?
- Play in front axle flange
- Driver side tail light wont work. Need suggestions.
- getAudiparts.com | Black Friday/Cyber Monday FREE SHIPPING + Promo Code!!!
- Audi S4 B5 Honeycomb bumper grilles
- Slave Cylinder Keeps Failing At the Hard line Coupling! Need Help!
- Brake Fluid Leak … from ABS pump/module?
- First ever (?) consumer driven ECU tuned 2018 Audi B9 S4 with bolt-ons.
- radiator support problem
- Problem resetting stereo code
- Washington DC: Porsche Audi Service-non dealer
- Carbon inlay options?
- 2.7T No Boost
- S4 no longer starts
- Possible newbie
- $50 off ECS Engine Street Shields + Free Shipping
- 18 Years Later I am Back with a 60k Mile Nogaro Blue S4
- B5 S4 Width Question
- BRAND NEW 2.7 ENGINE FOR SALE
- HELP! CRANK NO START NO CEL
- Brake light warning, all lights working, obnoxious beep
- HELP! B5s4 needs new head gasket/cylinder head?
- Misfires, check engine & shuddering under load
- Misfire under load
- 01E Transmission
- Multiple long crank times, rough start...
- 2015 S4 j500 Steering Rack
- Dials in Instrument Cluster Dead
- Check Engine Light - Knock Sensor 1 (G61) - Cold Weather
- Severe stumble driving under load
- S4 transmission
- Reverse lights
- Any experience with Vitro replacement windshields?
- B5 S4 2.7T Tip Radiator
- 2014 S4 Odd engine, possibly tranny noise.
- INTRO PRICE / Group Buy: *NEW* LED Fog technology: 1 LED 4 modes: WHITE/YELLOW/STROBE
- Need help tracking down owner near Sandy, UT
- getAudiparts.com | Black Friday - Cyber Monday: Lower Pricing + FREE Shipping!!!
- probable thrown rod - houston area - need advice.
- Fs: bbk ,bbs ,fender p/s, apakol, door frame , forge dirverter valves
- S4 died, cranks but no start! HELP!
- Audi A3 2000 airbag light staying on
- 🔥New Purchase Prospect🔥
- 2010 B8 S4 diddnt switch gears on launch
- getAudiparts.com | Genuine Audi Collection Key Rings!
- B5 purchasing questions:
- what could make my 99 a4 quattro not communicate with scanner?
- Control Unit Internal Altitude Sensor
- Found connector not connected.
- SQ 5
- KW Coilover Failure
- Battery dead
- ECS Labor Day OVERSTOCK Sale! Massive Savings!
- 40% on select Schwaben Tools while supplies last!
- ARP Performance Fasteners 10% off! FLASH SALE
- Audi a6 c5 2,7 biturbo. Stutters when holding steady speed. + boost efficiency
- Headlight wiring source?
- FLASH SALE! Street Shield Skid Plates 15% off + FREE SHIPPING
- No start 2001 s4 2.7 tt
- MTM A-box ECU for sale
- New Product Launch Blue, red or clean bright white FOOTWELL LEDs for all AUDI Models!
- JHM Rs6 turbos
- NEED HELP! Mis fires rough idle at start engine light on
- Interior door trim help
- TIPTRONIK MJENJAC
- audi a4 2013 misfiring
- APR Reset help needed
- 3rd brake light bulbs rs4 v6 b5
- 10% off 42 Draft Designs | Exhaust, Adapters, Intakes, Catch Cans, and More
- Flash SALE! Solo-Werks Coilovers 10% off + Free Shipping
- Issues after coilpack conversion.. again..
- up to 15% off Ignition Service Kits! | Sparklers!
- 10% off 034Motorsport parts at ECS Tuning
- Flash SALE Street Shield Aluminum Skid Plate | ON SALE + FREE Shipping
- New Alzor Wheel Styles! Starting at $499.95 a set!
- Intermittent rear engine bay squeak on '01 B5 S4
- genuine Audi parts ON SALE!!!
- ***WannabeRacer.com | Norcal/Bay Area Vinyl Wrapping Tour - July 30th - Aug 3rd 2018*
- Lane assist warning
- Please help me decide to buy a 2000 w a couple codes and some light maintenence
- Which post is grounded
- 2000 Audi S4 B5 Surging problems followed by stall
- Street Shields Skid Plates on Sale! Free Shipping + 15% off!@!@#@!
- Introducing ECS V4 Performance Brake Rotors | Free Shipping
- Best Tune for b5 S4 (Based on mods)
