- D3 S8 5.2l V10 Secondary Air Injection Pump
- Rough Idle and Low Fuel Pressure Issue
- A8 D2 TCU plug type/name?
- 2004 a8 rattle on startup
- P1534 - 001 - short to plus - MIL ON (N208)
- 07 A8 D3 Oil Control Valve Testing Ohms?
- 2009 S8
- Sound Cutting Out When Engine is Running
- High pressure fuel pump
- Adaptive Air Suspension
- Transmission service cost
- D3 headlight replacement -
- Audi A8 D3 ACC Retrofit
- Tapping deep within my dash
- PCV Retrofit
- P2181 coolong system
- Another update 06A8L as daily.
- Radiator Hose Issue
- Bumper/Grill options 2007 Audi A8
- doors and trunk wont unlock by key proximity...
- Hood latch alternate?
- Audi A8 D3 gear shift light fuse location
- Keyless Entry Fob Reprogramming
- Back suspension stuck in lift mode after being towed.
- Scrapping 2007 A8L--which parts to remove and sell?
- Licence plate bulb gremlin
- Turn signals will not cancel
- My NAV system is lost...is there a cure ?
- Audi A8 D3 oil leak
- OEM for Cam (VVT) Tensioners?
- HVAC weird problem HIGH fan speed on cold engine
- Air suspension won’t perform adaptation
- S8 D3 Milltek Exhaust to W12 D3 Advice Please
- Coyote, LT1, Buick v6 turbo conversion
- Air box vaccum line
- 07 a8 4.2 more power
- 2004 audi a8L engine and trans swap into a 2006 audi a8L chassis
- E box plenum removal
- EPC and hesitation during acceleration
- One fan not running overheats on highway
- D3 S8 - can adaptive headlights be used on...
- calling MP4.2+6.0
- Transmission randomly stopped working
- Would really appreciate some opinions, 07 S8 with "fried" ECM's...
- Audi D3 Suspension Leveling Sensor.
- Trunk Motor Sensor Gear
- Throttle Body Choices for S8?
- Audi A8L D3 shifter knob refurbishing
- Unique mmi issue need help
- Please, Somebody... I Miss The Days When There was Another New Thread Here Every Nigh
- Heater Core pump
- Hello AudiWorld!
- 07 A8L Coilover Suspension
- diagnosing blower motor resistor module ?
- MMI failure
- Possible Brake Servo Issue?
- Audi A8 D3 3.0 TDI 55 plate (UK). Jerky Shift
- Stumped! Please Help with Secondary Air Injection Error Codes P1423 and P1411
- Lower control arm next best thing?
- installed light weight front rotors now steering feels too light
- ABS Module Removal
- 2006 A8 4.2 MPI intermittent starting issue
- VIN check and trim level
- Please help 2006 a8 d3 4.2
- What Color is this Brown A8?
- Audi S8 D3 does not start
- Oil in coolant
- ABS pump / ecu 0265950145
- Audi A8 D3 slow started engine
- Audi A8 D3 3.0 TDI new navigation and new mmi 3G+
- Audi A8 D3 3.0 TDI ESP LIGHT
- Brake light doesnt work
- Reasonable Price for Brake Calipers etc.
- Running Rough and flashing check engine light
- Transmission malfunction/
- 2006 Audi A8L PLEASE HELP IM NEW TO AUDI
- A8 D3 4.2L Port Engine - Manifold flaps
- Im off
- Help please: Oil leak 4.2 passenger side not valve cover
- LA Area Suspension Work?
- WHERE IS THE INMO LOCATED?
- 2009 S8 Major Coolant leak
- 08 A8 start - no ignition - electrical issue
- A $300 radiator hose....OUCH !
- Audi alarm siren
- Coolant temperature sensor, WHERE IS IT!?!??
- Battery Drain 07 S8
- NO: Electrical nightmare after water intrusion (scan inside)
- Knock sensor
- Is My Transmission ruined?
- Jacking rear up to use JACK STANDS
- D3 Audi S8 5.2 V10 O2 Sensor Bank 2 Sensor 1 accessibility
- 2006 Audi A8 D3 left brake / signal on fender stuck on
- D3 Audi S8 5.2l V10 hesitation/loss of power/inconsistent throttle on cold start
- Key fob
- Wiper Transmission giveaway
- Ever had this problem with the Battery Monitor ?
- control arm question...
- A8 D3 Rough Idle, Oil Control Sensor
- Extreme cold suspension collapse
- Battery Management System question...
- Ignition Coil Wiring Harness Conduit
- Choppy/Laggy Throttle Response on 2007 Audi S8 5.2l V10.
- Camshaft end plugs and Crankshaft rear main seal
- D3 4E Audi A8 W12 Courtesy Notice--ELDOR OES IGNITION COILS ARE JUNK
- CarPlay/Android Auto - MMI 3G HNAV
- My car was stolen 2009 audi. A8 QUATTRO 4.2
- 4.2L V8 Timing Chain Change
- HVAC coolant control valve failed
- MMI bad or digital radio?
- Parking Aid module location
- Turbocharger
- Engine temperature & cabin heating problem
- UK: audi a8 w12 log
- Merry and Happy to all
- Merry Christmas to all of my fellow Audi nuts !
- Installed JHM light weight crank pulley - has anyone else?
- Help S8 no crank no dash lights with key or button
- audi a8 d3 steering column
- D3 Audi S8 Sunroof Detached while Driving. Audi will not honor recall.
- 2005 4.2 alternator change
- German engineering
- rear seat tables
- Rear Differential Project
- 2007 A8L: Best place to get parts?
- Audi exclusive glasses please help
- A8L W12
- alarm sometimes goes off when I open a door...
- Air strut stuck and can’t remove it.
- Need help identifying part
- Intermittent Air Suspension Problem
- VCDS OUTPUT
- Torsen 40:60 from RS6 4F
- how to remove 2004/2005 ctr trim ring from SW?
- Anyone change wiper arms?
- different gearbox codes in BFM engine?
- Rearview Mirror Re-Attachment
- Unexplained misfire, EPC light. I'm stumped.
- So cal audi help
- 2007 Audi S8 misfire 1-4 loud noise phasers?
- Audi breaks my car
- A8 2006 NON FSI BADGE SIZE
- BLACK FRIDAY SALE / CYBER MONDAY ON NOW @ deAutoLED.com – bright error free LEDs
- BLACK FRIDAY SALE,, SuperSprint Italy
- A8 facelift tail light lens cracked
- RS: A8 2007 3.0 TDI Tire sizes?
- A8 2007 Webasto
- Need audi a8 master in so cal
- Done the immobalizer delete now what?
- W12 intermittent misfires, slow crank
- Knock Sensor 2 1-g66 low fault but no Check engine light
- Front brake disc upgrade for S8 ?
- D3 Brake Upgrade Options - They're slim aren't they?
- P1857 error code / ABS-ESP fault?
- Worn sprocket on exhaust cam
- W12 injector problem HELP!!!!
- Esp fault 3.0tdi
- Possibly Battery issue
- A8 suspension problem.
- Audi A8 D3 2006 disable front (or front and rear) fog lights at the headlight switch
- 2007 s8 check engine codes - knock sensor 2 1-G66 low and evaporator emission system…
- W12 Over Pressurizing Expansion Tank/Overheating
- A8 Battery & MMI Troubles
- ISO S8 D3 Splash Shields
- Backup camera and 360 display missing
- How to R&R rear sunshade motor/mechanism ?
- How To Take Care of Air Suspension.
- Rear suspension collapsed & solution
- Overheating
- Corrosion on valve covers?
- What will be the reason?
- Camshaft timing adjuster solenoid - N205
- Outer cv keeps popping off
- Audi A8 3.0tdi faults
- car not level
- Audi A8 D3 2007 Multimedia - Options
- 08 A8L Rear AC Controll Panel Not Working !
- Question for experts
- Gear Ratio question
- PCV valve
- A8 D3 No communication with modules
- rear sun shade failure...little wheel fell off...
- Sunroof Mechanism Plastic Bits Broken
- S8 D3. How do I release the electric brake on my 2007 Audi S8?
- P0087 Fuel rail/System Pressure too low
- Kessy or steering Column
- My car is possessed!!
- auction fun with 2009 S8
- Front struts
- W12 coolant smell/expansion tank
- 2008 S8 for sale check market
- Buttons and lights on the door stopped working (Terminal 58s fault)
- Engine noise ??
- Car won’t start. S8/D3
- Rear Heated seats not working ( stage numbers don't go up )
- 2006 Audi A8 L 4.2 ABS Issue?
- Pre-facelift to Post-facelift D3 changes list help?
- Lost another one
- Engine Stops while driving / A8 L / 2008
- How to calibrate tire pressures sensor
- ES: find pneumatic tube same as original
- Fuel Pressure Regulator 2 Control Circuit High???
- 2005 A8L Quattro dead battery trunk problem
- Check injectors
- Electrical fault, low voltage? Whilst driving
- Make changing trunk motor MUCH easier w/this...
- Possible ABS Controller Failure
- Xs power headers
- Audi A8 front air strut won't fit
- New Audi owner looking for education
- Odd trunk motor issue remedy...
- Compressors keeps running and shutting off
- 2009 S8 battery positive wire getting really hot
- Fog light upgrade completed
- trunk motor issue I have never heard of before...
- Drivetrain mount testing - isolation
- 2008 A8 w/134k miles - Hello Everyone!
- Coolant Adaptor (Union) bypass
- Mmi amp and nav ground location?
- Coolant leak behind engine.
- A8 D3 No start, no communication after Kessy swap
- Is this windshield installed incorrectly ?
- Left rear strut keeps deflating
- Outside temperature problem
- 4.0TDI weird noise
- upgraded 06 W12 to facelift fogs, is there a way...
- new o2 sensors installed, same code
- NO: Shaking when using brake pedal
- D3 S8 18" winter wheel fitment question
- 2004 Audi A8L Body Control Module
- Would you run 235 width tires in winter? I have a chance at a free set
- problem with AMI
- made a mistake, please help
- Starter Problems
- Power failure
- Did Walmart tires department mess up my front suspension
- 2007 A8 headlight r/r
- Front end won’t air up!!!
- D4 4.2 Intake Manifold on D3?
- dvd update or carplay
- 2009 Audi A8L won't start, only cranks.
- Where is there is a facelift D3 being parted out ?
- Suspension Sensor questions
- Audi A8 w12 boot lid mechnism fail on driverside stuck.
- project car
- A/C rebuild 2006 LDH A8L D3 4.2L BGK - ice cold
- Can D3 fogs be coded to work as cornering lights ?
- mmi download software upgrade
- W12 09 limp mode timing other issues
- Intake Manifold Actuator/Diaphragm
