- Leak Detection Pump Missing
- 2007 a4 avant quattro 2.0t b7
- 2006 A4 Cabrio 3.0l V6 has a coolant leak at rear of engine
- UK: 2008 A4: Strange problem
- 2003 a4 wagon Quattro avant- need fuel relay location
- A4 passenger door problem
- Audi a4 b7 transmission
- 2007 Audi a4 2.0T B7 rpm fluctuation almost stalls and surges
- 07 Audi a4 B7 I have RPM fluctuation at idle, engine surges and have a video help
- Digital screen new warning(?) light
- Clutch and flywheel labour time
- Horn not working properly, PLEASE HELP
- 2008 a4 2.0 b7 not reading transmission
- Engine swap
- Knocking sound on the back of audi a4 2007
- Fog lights
- 2006 B7 Retrofitting electric seats
- Clutch disk springs
- Getting P0299 under boost code.
- 20% off our bright D1S / D2S / D3S LEDs! These are brighter than xenon bulbs!
- Car starts but doesnt stay running.
- A4 Avant Adaptive Xenon Headlight Replacement
- What is this? (Avant interior near grab handles)
- Remote Key and Seat Position Memory
- 2007 A4 Cabrio Stalls/Trouble Starting
- Opinions on PCV deletes?
- Bilstein suspension Kits.
- No warning alarms
- Random pipe
- Lights work but do not turn on.
- ZA: Auto light and rain senor
- 2006 B7 2.0T HELP!
- coolant leak, HELPPPPP
- Click when starting
- Help please 2008 A4
- MU: Issue with 1.6 litre rpm
- Loud grinding noise when trying to cold start? HELP
- R.I.P. Avant....open to suggestions
- Load reduction relay #
- Electrics
- Torsion values
- Need help anyone in sheffield or south yorkshire
- Plug in pvc inlet to turbo housing.
- Audi Concert Radio
- Sediment in coolant reservoir
- Steering control module fuse and wiring
- A4 B7 2.0 TDI manual - transmission problems
- Please help issue with steering control module and climate control
- Mystery Wires - RF kick panel
- Misfire, Rough idle, Backfire
- Fuel range
- Engine ticking noise diagnosis
- b7 AT hesitation
- Grill
- Wish me luck!
- FI: Clutch switch information
- N205 06F109257C Valve resistance reading needed
- Check engine light
- blow off
- A4 B7 strange wheels
- Oil filter housing leak
- New to me B7 Avant 6MT
- SRS Side Impact Sensor - Needs Programmed?
- Will a b8 2.0t fit into a b7 2.0t?
- Unknown connector in engine has oil in it
- Advice needed, a4 b7 2.0tdi pd170 brd injector fault
- Is this ticking or knocking sound normal for B7 Audi A4
- Replace clutch? How hard? What to do?
- Help Help, I think I did something wrong!
- Throttle problem
- B7 S4 Recaro Pinout
- Best Digital Touchscreen Head Unit in 2008 A4
- My cam follower technique
- 2007 B7 Auto Headlights?
- A4 - sline - 2.5 dti v6 8e2
- Hard start problem
- Xenon headlight level sensor noise
- Audi a4 b7 2.5 tdi problem
- No heat inside cabin, been chasing my tail. Help!
- 2.0t fsi Camshaft Adjuster Info needed
- Carbon cleaning intake valves - your opinion matters
- Which lights to replace
- Problem with 3.0TDI ASB. Engine revs on its own.
- Front bumper options?
- Audi navigation
- getAudiparts.com | Black Friday/Cyber Monday '23 Savings are Live!!!
- BLACK FRIDAY SALE,, SuperSprint Italy
- BLACK FRIDAY SALE / CYBER MONDAY ON NOW @ deAutoLED.com – bright error free LEDs
- Misfire and ticking noise 2.0t fsi
- Clicking from rear quarter panel.
- A4 B7 Electronic engine mount decode vcds
- Fuel Line/Pump Issue
- WHAT is this connector called!!!
- Stuck at 1.5k RPM, Burning Oil and Stutterring?
- Several interior lights staying on.
- A4 B7 2005. ABS rear sensor modul voltage needed.
- Transmission output seal. Help. Can't find any tech info. Second post.
- 2.0t fsi Camshaft Adjuster Unit Camshaft phase regulator
- Code p2294 2006 a4 2.0L
- Dealership Issues
- UK: 2.0T FSI Phase position bank 1 intake -13.00KW?
- HELP PLEASE CAR DIED AT RED LIGHT
- instrument cluster pin code for replacement
- Rough cold starts
- Oil sensor location
- Code p2108
- [HELP] Cylinder - Misfire
- Help identifying part
- Help needed A4 2.0T 2007 multiple random misfire
- Pcv valve... replace or delete?
- HPFP cam follower story
- Headlight chimes
- Audi A4 2.0T 2006 flashing check engine light
- PRNDS all lit up :(
- Help needed. Can't get center diff tailpiece off.
- Extra help, lean air, short to ground, etc
- Oil pan sequence
- Car shakes around 2000rpms
- Soft Top not secure
- Car starts then stalls
- UK: Please, can someone identify this part?
- Transmission Replacment Coding/Programming
- Engine sounds under load
- Guys I just got the error codes from my audi a4 2.0 b7 and howly ****!
- PL: Answering a call without the multifunction steering wheel?
- New Audi A4 2.0T driver, issues (Key fob, noise, oil leak)
- Transmission mount help
- TPMS light keeps coming back, I give up
- Hard one: 3.2 FSI - calculations.
- Ordered parts from FCP Euro and taking 3 weeks to get.
- New to me 2007 A4 2.0t Quattro - first steps?
- P2002 Error
- Headlight bulb loose inside headlight assembly.
- Need wiring assistance replacing RNS-E Nav with aftermarket Andriod Auto head unit.
- 2003 A4 Quattro massive electrical draw with car off and key out
- a/c diagnosis help please
- Diesel lock motor
- 06 A4 B7 idle problem
- Normal B7 2.0T Engine Noise or Issues
- SE: Bad idle when installing LED light
- No internal lights and no number plate light working
- B7 Audi Vibration Issues CVT 2.0T
- Having idle issuses
- Error codes need some help
- Advice on Potential A4 Purchase?
- ZA: 2.0 TDI went dead but has power
- Cabrio top motor issues
- ecm issue?
- A4 Cabrio key fob stopped working as did central locking button, alarm won't set
- AMI port behind iPob dock?
- Audi a4 b7 2.0t loud ticking whine from engine
- Fuel pump relay location?
- Highest "Distance to Empty" range I've ever seen
- Gas Strut ends issue !!!
- P3102 - still safe to drive?
- 2007 A4 2.0L Quattro Help
- Fog light issue
- Intermittent Crank no start
- Reversing Light failure
- UK: 2.0 diesel starting issues
- B7 2.0tdi BRD starting issues
- Navigation unit in the trunk = RNS-E?
- SK: Cyliner compression Advice please A4 B7 2.5 TDI
- UK: Tunning [sic]
- MAF Sensor Connector.
- Control Arms Kit
- Multiple Misfires, car seems to go in and out of Limp Mode
- Wondering about wheel fitment for my Audi A4 B7
- Does steering control module need to be programmed.
- Help find part on A4 B7.
- Automation lamp level harness differences
- Random AC shut offs
- Audi A4 Issues Climate control, horn, other not working
- PD Injectors to Bosch Conversion
- Drain plugs
- Looking for back seat cover part dont know what to call it
- Audi A4 2.0 fsi 2005 multitronic problem.
- Intro and any advice pulling a 3.2 motor?
- Expansion tank question
- American message board members.....
- Help with CVT 'Hiccups/ jumps'
- Joined the forum with a 2006 B7 2.0TDI !!!
- B7 A4 top issues and no comm with bcm
- A4 2.0 Quattro Automatic Transmission won't fill
- Turbo Help
- Best A 4
- A4 B7 P0456 + Gas leak
- Urgent
- Starts but instantly dies
- Central Locking Issue
- Constantly on - Brake lights
- Engine pulsating at idle and low oil pressure
- AU: Obd11 17700 reading
- Anything I can do
- Greetings from SuperSprint Italy
- 8E0959126 ac pressure sensor
- AIRCON EXPERT HELP NEEDED PLEASE
- Filled up windshield washer reservoir but nothing is happening...
- Help
- Can't figure out fuel issue
- Please help. Won't start. Sounds like no compression
- ZA: AUDI a4 b7 gone haywire
- A4 white smoke from engine
- Oil filter housing 5mm bolt stripped
- Headlight assembly
- the third reich is haunting my engine (knocking sound)
- This will interest you, 2006 Audi a4 b7 1.8t shorting ECM
- Low injection quantity .. injector problem ???
- cam position DTC
- B8 swap into B7
- Help with a warning light
- Car sounds terrible… any ideas?
- HELP PLEASE!!! 07 a4 b7 2.0 rebuilt head
- fuel pressure regulator info
- AL: Audi multitronic gearbox
- Temp gauge rising a little around 60 degree
- Stereo
- Replacing ATF with newer version
- Understanding A/C VCDS readings | A/C not working
- 2007 A4 2.0T Quattro NO CRANK
- Doors won't open, not even mechanically.
- Do these exist
- Weird boost issue 2.7 v6 tdi
- P0299 turbo underboost (VCDS graph)
- Cylinder Head removal question
- Convertible top replacement
- A4 Lack of power
- So....what do we do with an old Audi?
- Thudding Noise From Intake Manifold Area
- No crank no start 2.0T 6 Speed
- Oil pan is secured via magical force?
- Audi A4 2007 cabriolet - center rear brake light-
- A7 2007 Cabriolet - Paint Code -
- Audi 2007 cabriolet - roof trimming -
- Audi 2007 cabriolet - wiper position ?
- Harmonic Balancer Removal 2.0T?
- Fault codes help??
- no crank and press clutch for automatic
- Intermittent no start
- audi a4 b7 usa style lights
- Audi A4 B7 2007 does not turn off
- Help with fault codes
- Higher Millage Maintenance Intervals
- 06 A4 2.0t Quattro non-interference or interference engine?
- Airbag Control Module fault with Parking Brake light
- Coolant temp sensor connector
- Misfire cylinder 2
- PT: Engine number?
- Bought a lowered A4, want stock suspension back.
