- Constant noise when accelerating.
- how to access radiator fan control module
- 2013 a6 electrical issues
- Racing suits advice?
- Need some help quick. No trans fluid!
- Spare engine bracket and or oil pan? Yeah I hit something:/
- Limp mode finally fixed
- Help with replacing gearbox mounts.
- Starting problem with 01 A6
- Early 2002 C5 upper grille?
- Turbo boost
- A6 C5 Interesting Transmission Problem
- A6 C5 Auto (TipTronic) Allroad Jerking Issue
- Steering wheel issues
- 2015 Audi Apple Carplay
- 2014 Audi, A6 2.0 T.
- A/C Compressor Replacement in A6 2.7T C5
- Radio not working but still power to cables
- Double din radio
- Coolant leak in A6 2.7T manual quattro year 2000
- Fuel Pump Replacement Leak
- Good exhaust system
- a6 tcm
- AC Fan wire connection
- Part Compatibility / Project Car
- Audi A6 2.5TDI BAU engine front wheel drive replacement gearbox question
- 4.2 tdi engine swap to '04 a6 c5
- C5 S6 shock options
- White wire tailight harness
- 04 a6 lighting and door lock issues. Need help.
- Unsurpassed Сasual Dating Legitimate Girls
- Factory headlight bulbs
- Audi 2.7t bigger MAF
- 1999 Audi A6 Avant TDI - Clutch master cylinder question
- trunk wont open 03 s6
- Engine swap 01 a6 Avant 2.8L
- MK: A6 c5 avant oil temperature issue
- A6 tcm repklacement
- Acceleration Issue
- Vacuum leak
- Door Ajar Chime on intermittently
- Rear diffuser
- Esp light on help please
- '03 Audi AllRoad Electical issues VCDS dianosis help
- Audi a6 c5 2.8 power steering problem
- 2.8 Aftermarket Parts?
- FRONT RIGHT WHEEL BRAKE LOCKS UP AND BRAKE PEDAL HARD AND
- 1997 C4 A6 Avant
- UK: 1995 2.5 litre v6 audi a4 estate
- Wipers
- HELP- A6 Fuel Issues
- Audi a6 c5 2.5 tdi 132kw ake no start
- A6 c5 interesting problem
- A6 c5 2.8 automatic problem
- ABS and traction control light
- EPC light
- Vacuum leak
- Front Wheel Locked
- UK: Cabin air exit in A6 Avant
- What is this black stuff coming from under the hood?
- ECM issues
- EPC issues
- OBDeleven
- A6 V6T Quattro Automatic. Reverse gear slips on gas.
- 07 A6 4.2 fsi
- BLACK FRIDAY SALE / CYBER MONDAY ON NOW @ deAutoLED.com – bright error free LEDs
- BLACK FRIDAY SALE,, SuperSprint Italy
- Load Cover? Still can find?
- Blue A6 4.2 in Port Orchard, WA
- Does A6 V6T Quattro have reverse lights?
- What’s your diagnosis?!
- Audi 2021 A6 AC issue
- 2002 A6 2.7T Braking issue
- 1998 A6 noise pinging or exhaust leak?
- 01 A6 what is this?
- 2002 A6 3.0 Quattro
- AU: Car smokes and won't run
- 205 Audi A6, Quattro
- Broken fiber optic cable
- 3 faulty suction pump possible pcv alternative cause. Intake manifold flap?
- Audi A6 C5 2004
- ABS Wheel Spped Sensor - Rear - 4B0927807 Where to order?
- New Jersey Audi/VW Repair facility?
- I fixed my valve cover leak!…oh wait no I didn’t.
- All Warning lights on dashboard and vehicle shuts off immediately after starting
- Oil cooler line replacement
- VCDS codes
- VCDS coding new used parts
- OEM-Looking Rear View Camera
- Speaker replacement harness — anyone know?
- Quick question. Issue reinstalling 2.7t motor
- What happens when Audi stops carrying crucial parts for our cars?
- S6 timing belt too loose (last replaced in 2017)?
- Climate control code question
- Little issues I would like to get fixed, need some help
- Electric Fan w/ 2.7tt
- Is there a difference on the A6?
- loss of transmission
- Fuel pump
- 2.5TDI 110kw power problems
- DK: Please help, can't place broken electric plug
- Need help with center support bearing middle bolt to split drive shaft
- Unknown coolant leak from rear of the engine
- No crank when warm?
- Good Evening All
- 2004 A6 exhaust help
- C5 4.2 timing belt question
- V6 2.4 and 2.7T block differences
- 2002 S6 headbolt torque?
- Instrument cluster replacement/upgrade
- 99 avant not starting
- 2.4L timing belt
- 2004 A6 2.7L Battery Replacement
- UK: 2003 A6 A pillar trim removal (no airbag badge hole0
- ECU differences A6 4.2 and S6 ??? Its almost same engine….
- Clicking noise when turning
- ZA: Audi A6 Tiptronic - Brake Pedal Sensor
- More issues... Fire and oil leak this time....
- Bad supercharger clutch
- Fluid in engine
- Trunk only opens with key in slot
- Audi c5 a6 all dash lights on/misfires w new fuel pump & plugs
- A6 Avant car camping advice
- Car starts, then shuts off
- NEW OWNER OF 2003 RS6
- Tranny Fluid Question (no jokes)
- 03 rs6
- A6 C5 beginning modding
- Issue installing upgraded power wire and alternator. 2004 a6 2.7
- EE: S6 not shifting after gearbox swap
- 02 A6 quattro abs
- 2005 allroad back glass replacement - ooops!
- Fish out of the water on this car
- Stalling issue -2004 A6 Quattro
- Relay access - A bit of advice
- Door lock problems and solutions
- 2003 4.2L CKP connector location
- Adjusting xenon headlights
- S6 Need Help with finding a solution to a new clutch.
- Help! Camshaft needed
- A6 C5 2001 Allroad Driver Door Lock
- A6 C5 2003 starting issue
- ABS AND Dreaded Triangle
- Change 312mm calipers/rotors to 288mm
- Carplay with a 2018 A6
- Strange Climate fault
- WTB C5 Allroad ride height controller
- 2003 Audi C5 S6 Avant 4.2 TCM needed
- American message board members.....
- A/C not working
- Front brakes from C5 to C4. Will they fit?
- 2001 audi a6 quttro 2.7t need help
- 1997 AUDI A6 Clutch problem
- Fuel pumps Audi A6 2.5tdi 1999
- Took both engine mounts off at same time. How bad is it?
- A4 B5/B6 / A6 C5 1.8t / 2.7t
- Need to know what part I broke and where to find one.
- 6 speed swap and now ECS and ABS lights on
- Struts H&R compatible
- 02 A6 Quattro issues
- Driver seat problems
- 5HP24 differences?
- Audi A6 revs up when stopping, ESC light on
- Greetings from SuperSprint Italy
- Headlight replacement
- I got a question about the ignition lock cylinder housing...
- A6 Avant lift
- AUDI A6 C5 2.5 TDI VP44 PUMP
- New owner with new to me 02 A6
- This means I need new engine mounts? A6 2.8 c5 AHA
- Audi A6 C5 locking issues
- Oil Level Sensor 2.8l 30v v6 mfi dohc
- 2004 A6 Bi-turbo Random Engine Shut down question
- Clunking noise
- Grease on the outside of my wheels.
- its my birthday
- 2003 A6 2.7T O2 Sensor Nightmare?
- AUDI A6 C5 Avant 2.4 BDV - Coding of the multitronic gearbox controller
- Wire parking sensor noise from engine
- New-to-me '01 A6 Quattro 2.7T
- Sat Nav
- 2001 a6 2.7 rear knuckle search
- A6 3.0 all light malfunction
- VAG Logs, Smoke Test, Next step for warm rough idle
- 2.5 TDI lift pump problem
- Front wheel bearing/drive bearing issues
- A6 3.2l Timing
- Hard Ride
- 2003 4.2L windscreen cowel replacement
- 17 "short to ground" fault codes
- 4.2 timing belt job? 2000 A6
- Damaging camshafts by cleaning them.
- Heater blower problem
- Misfire in multiple cylinders, need advice.
- Alternator replacement
- Audi a6 c5 2.5 tri afb socket
- Audi a6 c5 2.5 tdi water pump problem AFB
- Audi a6 c5 2.5 TDI timing
- 01e swap into 3.0L questions
- Wood Grain interior
- 2004 A6 2.7l engine bay ground locations?
- No start. No ECM communications?
- C5 pre-facelift struggle with airbag codes 01222 and 01221
- Removing cabin filter frame 2000 A6
- MAF and misfires oh my
- How to drain the coolant from an S-line
- Parts to pull and sell before taking it to the junk yard
- Metal Dragging Sound
- 3.0t swap question
- best vendor to buy cooling hoses?
- Check timing on obdeleven
- late shift
- Faint soft knock at idle and driving. Changes with RPMs
- trans fluid level on C5?
- Secret code to a specific no start.
- SCAM Alert
- Trunk struts A6 C5 Sedan
- Bank 2 Random Mis all cylinders.
- Silly question
- A6 C5 2.7t shifer adjustments
- Audi a6 Quattro won’t run.
- PCV options
- 2.7 a6 broken timing belt
- Donut spare size damage Quattro?
- 2012 Audi A6 showing do not drive vehicle steering defective, it does not start
- 2003 A6 C5 2.8L
- Repair Cam Chain Tensioner/ Variable Valve Solenoids
- Sensor Issue?
- Timing belt?
- 2016 Audi A6 3.0T Premium Plus/Black Optic package rebuilt.
- Crazy Issue after setting for 30 minutes
- This cant be an accurate step in the how to for this car
- Audi A6 C5 4.2 buzzing sound from engine bay
- 2.7T Cams Seal Removal...Help!!!
- Valve cover casket replacement 4.2
- How do I remove the rear output shaft flange on the oe1 transmission
- Car won’t start!!
- 2002 (C5) A6 4.2L cooling air purge screw locations
- Cylinder misfire 2.8 l, us version
- free '01-04' Euro style (red) rear taillights (R&L)
- A6 C5 Saloon boot doesn't open
- Car started smooth as butter simultaneously rattle/knock
- Generator Failure
- 2000 a6 2.7 turbo oil line leak
- Got used cam tensioner and chain. Reuse my old cams or these?
- A6 C5 compatible parts
- See anything abnormal with my valve stems?
- Buying Audi A6 2.7BiTurbo
- Got new Boroscope!! How do my valves and pistons look?
- No 12v to rear electric windows
