View Full Version : TT (Mk1) Discussion
- Fuel pump 03 Quattro roadster
- Audi TT 1,8 T quattro Coupe 132kW worth buying in 2024?
- Codes won't clear
- Wrench for k03 housing bolts?
- Will Planned Larger Wheels/Tires Fit ?
- TT CLUB CANADA
- 6 speed trans/clutch replacement
- Radio broke while in SAFE MODE bose system
- 2004 Audi TT 3.2l DSG Shifter MK4
- Driver window doesn't drop down
- Front Bumper Cover(2000 Audi TT Quattro)
- ABS Anti Lock Brake Actuator Motor
- Intermittent ECM Failure
- Mint condition 01 with 2L/BT build and much more (360+ hp)
- TT (MK1) Battery Slow Drain
- N75 issues
- Help identify hose
- ECU problems?
- Sign up now for TT West 2024 September 23-27
- Air Conditioning Diagnosis. 2002 1.8L TT
- Audi TT MK1 Roadster - Hardtop
- Air Intake Part number 06A133382P connecting pipe
- UK: Fuel issue
- 2003 TT Quattro checking manual transmission fluid level
- Audi TT Mk1 Clock Groundhog Day
- Audi TT Mirrors Don't Adjust In Completely
- Strong smell of fuel inside cabin and outside of vehicle
- Early parking brake cables?
- Audi TT 3.2 noise
- Turbo Question
- instrument cluster class action, recall?
- New TT quattro 3.2 owner
- Mk1 fwd downpipe
- Set Clock 2004 Audi TT Quattro Roadster
- Parting Out 2001 TT Quattro
- 18 inch wheels - Advice needed
- 2001 Roadster Been sitting for a few years, issues?
- New TTS coupe owner, general Qs
- Lower dash strange color
- Front bumper swap
- A lot of APR items
- MK1 for sale
- V6 Quattro is it a good buy?
- Trunk privacy shelf
- Top closed light blinks, question about other microswitch
- Need help pricing a 2001 TT Quattro with high end extras
- Secondary air injection hoses problem
- Center speaker in roadster
- 2004 3.2 secondary air injection question
- Broken paddle on a door lock 2001 audi tt
- Help needed with radio install
- 2002 TT: STARTER TO FLYWHEEL ENGAGEMENT?
- Difficult to search problem.. electrical?
- Can't Find Replacement Turbo Inlet Hose For My 2001 Audi TT Quattro!
- silicone coolant hose replacement
- How to repair drooping headliner?
- Broke the little plastic tab on windshield switch cabriolet
- Broken rear spring 2 silver dots 2001 TT quattro
- How attach metal audi logo?
- new product , replacement lift screw set for wind deflector )
- OBDLink Boost vs Boost Gauge.
- Rear tires have too much camber. not original springs
- TT 225 gt2871r .64 what am I missing?
- Upgrade TT225 front rotors to 3.2?
- 20 years later I've bought another TT
- 2003 roadster transmission drain plug tool
- ABS Control Unit-G251 sensor
- Replace front axle
- Brighter Fog lights
- External wastegate
- Shop Ruined my Engine ?
- audi tt front end removal
- YouTube channel
- Need help 2002 Audi tt quattro power brake booster
- Can just the rubber be replaced on the rear exhaust hanger?
- Been out of commission for over 2 years
- WTB 05 Mk1 Headlights and Front Bumper
- Amu engine in a bea car
- BLACK FRIDAY SALE / CYBER MONDAY ON NOW @ deAutoLED.com – bright error free LEDs
- 2006 Audi TT Door Lock problems **SOS**
- Need to replace fuse block above battery
- Locking pin visual difference between the 5 and 6 speed transmissions
- Clutch master cylinder mystery, my head is about to blow
- brake. gas, and clutch pedals
- Tail light refresh
- Can you manually lift up the door window?
- Help with the driver side latching mechanism
- Wind deflector lead screw availability
- Any other way to remove ccm from 2001 roadster?
- door windows work sometimes
- power top goes down but not up and that micro switch
- MK1 18z swap
- Wiper blades?
- electtrical problem with my TT coupe from 2000
- TT mk1 wrong temperature gauge
- G40 sensor problem
- Clearmount Magsafe Holder
- What’s wrong with my TT today?
- Speedometer doesn't work on 2003 Audi TT Coupe 3.2 Quattro DSG (US market)
- TT Running Cold
- 2001 to 2000 TT MK1 Factory Heated Seats Conversion
- Wanted: MK1 2001 TT Coupe OEM Roofbars
- 2000 audi tt crank no start
- TT 5-speed, replacing shifter bushings…missing lever?
- Mk1 tt
- Need help blew my transmission on 03 mk1 tt Quattro
- Need help blew tranny in my mk1 tt Quattro
- Mk1 TT
- Wire connecting to sensor on valve cover
- New TT 225 Coupe in the garage
- 2002 TT CCM Clicking
- 6MT Notchy Shifting
- New Mk1 owner
- I am BACK - after 20 years
- 2004 Audi TT transmission leaking from top when warm
- Airbag light
- 2002 Audi TT 1.8T sheered motor mount bolt
- Strange Electrical Problems with '01 TT
- location of pcv valve 225hp audi tt
- 2002 TT Roadster CCM License Lights Related?
- Disable convertible top hydraulic pump/motor
- 2002 Audi TT 1.8T Timing Belt and Questions
- OEM roof racks on eBay
- Selling My TT
- 05 tt 1.8 auromatic cooling system
- Gear grinding?
- Hard Boost pipe
- Driver side radiator fan not works, weird temp gauge
- How reliable is an Audi TT?
- will this wheel fit?
- Looking forward to a new project for the TT- replacement of the entire AC system
- help on identifying a part
- Tachometer suddenly reads incorrect.
- TT mk1 exhaust
- Audi TT MK1 Engine Removal
- 2000 Audi tt Octane, New owner.
- NEW TT OWNER HERE! but with a quick vaccum line question before the excitement!
- Wrong ABS - ESP, Audi TT, MK1, 8N, 2000
- Audi TT Mk1 FWD Brake Upgrade
- First Startup of the day idling rough till warms up then fine.
- Seat Suggestions
- Door wedge
- Audi tt misfire issue
- Low rpm idle starts sputtering a 2k rpm when I step on it kicks in than dies
- CCM Working Funky - 2006 Roadster SE
- So I figured I would try to login again and..
- KONI STR.T front shock
- Prebuy, 01 TT with no keys, but odo is illuminated??
- She has ZERO keys!! Help!
- Drivers window
- How to find Wideband and Turbo Info
- Interior length: Trunk to dashboard- will xc skis fit?
- 2001 Audi TT MK1 225 - New Owner
- Climate Control +/- knob remove/replace?
- Sourcing a new-ish Audi w/ 100K in my pocket
- Vacuum Check valve replacement
- interior fan
- Radiator fan turning on and off while driving when up to temperature
- new 3.2 owner, again
- What's hanging from my TT, and how do I fix it?
- Electronics Maintenance
- car stereo recommendation
- "While you are in there" Maintenance
- Fuel gauge issues
- engine surge while driving
- OBD Stopped Working
- TT rear right running light.
- Best tune for MK1's ?
- My K-Line experience
- TT in garage for 6 years
- AC Not Blowing Cold Question
- Don't Leave Your Keys In The Car!!!!
- Door locks and dachshunds
- Repair Manual For Audi TT Mk1 Type 8N
- How Too Change A Diffuser On Audi TT MK1
- Swap 225 quattro motor into 180 fwd car.
- I Bought a Disaster / Project Car
- 01 TT MK1 FWD - Right Axle Rubbing Sound?
- Rear End is catching
- Greetings from SuperSprint Italy
- 2 din stereo to control cd changer
- Seat height adjustment
- I made this for a bit of fun😂🤣
- oil leak driver side (US) top of engine
- 2002 tt ac not blowing cold
- TT: Dead for Good??
- All gauges stopped working
- Drivers window switch issue
- Audi TT 8n shift gate r8
- Comfort module (8N7962267D) , 1.8; 150km, convertible
- Most Common Reason Why Your Battery Light Is On!!!
- Cam sensor code.
- can't find reverse
- Nürburgring Road Trip 2023 (part 1)
- 2005 TT ESP now always on with 810 and 813 Audi specific codes
- Audi TT mk1 climate control doesn't work.
- Audi TT?
- Radio SAFE unlock
- Transmission Problem- '04 225Q 6sp
- mystery cable
- CA Failed Smog Test
- 1.8t k04-k03 Compound Turbo Setup
- The Best Exhaust Audi TT 3.2
- Whining sound between 50-90kph
- Engine Covers
- looking for clip for hose into slave cylinder
- Fk Coilovers
- Check engine light, cannot read code?
- Need Radio update
- I may have ruined my engine..suggestions
- '04 MK1 (Concert) CD/Changer: adding bluetooth
- ABS HELP!
- Which Mk1 to buy?
- N75 Assembly Rigid Vacuum line to Vacuum Reservoir Part Source
- Airbag System, Inc. repair
- Crankshaft Position Sensor Replacement
- Unexplained Overboost?
- Clutch Slipping in a Mk1
- 02 TT Quattro Mk1 225, AMU, Expansion Tank Lower Hose Assembly
- I just got TT225
- Audi TT MK1 Project Inlet Manifold And Injectors Refresh + More (PART 2)
- COMPLETE NGP Tuning Unitronic: Built motor, Big Turbo kit
- DSG - Flashing Numbers on Display Screen
- Console Switches
- Audi TT MK1 Project 1.8T 20V Inlet Manifold Painted And Injectors Refresh + More (par
- 2001 225 w/80k miles - restoration or nah?
- HEADLIGHTS be DAMNED
- DAMN HEADLIGHTS
- Last day to register for TT West is Sunday March 19
- First post - maintenance on 140k mike car
- How To Replace Engine Mount (DogBone Mount) Bushings On Audi TT MK1 S3 8L And MK4 Pla
- Resistance to hot-wiring
- Just bought my 2003 TT quattro mk1 225
- Audi TT MK1 Top Mount Replacement The QUICK EASY Way
- Replacing OEM AC Compressor w/ GPD AC Compressor wiring question
- Audi TT roadster boost broblem
- Aftermarket Headlight Assembly Replacement
- Steering Angle Sensor
- Help Help where does this go to
- AUDI TT MK1 BOOST GAUGE INSTALL
- Selling my 2002 TT roadster's original tonneau
- Intermittent Fuel Guage -- And just joining with my New 2001 Mk1
- Haldex Oil And Filter Change DIY Guide For Mk1 Audi TT
- Power Steering Pump Leak
- 2014 tts quattro "Service Due" reset
- Back in the TT fold, again...and immediately broke something.
- Tips for removing the hatch?
- 2004 TTS Airbag Light Reset?
- Won't strat
- TT 225 Quattro - Expected Performance
