View Full Version : 1.8T Discussion
Pages :
1]
- Turbo noob - is this turbo toasted?
- Problem with the start 1.8T AEB
- Lots of cranking - 16725 - Camshaft Position Sensor (G40) P0341 - 35-00 - Implausible
- -10.9% (out of spec) partial fuel trim
- High idle (P0507 - stat & P1136 - stat)
- Wastegate actuator/spring cranking opening pressure... ?
- RO: Audi A4 1.8 TFSI (2014) - Low Oil Pressure and EPC
- Can I swap A4 tranny w TT?
- 1.8T Engine Rebuilders (short block)?
- 2008 Audi 1.8T has thrown 2 codes P0411 and p0101
- 2003 1.8t endurance race blown head gasket
- Transmission issue after exhaust gasket went bad.
- Half the injector is melted away.
- Strange hole spitting oil on bell housing
- Will this 2016 1.8L work in my 2015 A3?
- Transmission will not mate with engine after ra4 clutch PLEASE HELP !!!!
- EGR system
- Boost leak?
- 2002 TT idle reset
- Overheating
- New Project Car Reveal + Upcoming TT vs G35 Race
- Ardeca Engine Oil
- Catch Can or Simplified Recirc?
- Audi a4 2002 1.8t questions
- Fault P164B 00 [032] audi a5 2012 1.8
- Anyone in the SF Bay Area with a cherry picker?
- INTERMITTENT ROUGH IDLE AND POWER DELIVERY
- BUNRT OIL SMELL COMING IN FROM VENTS
- K03 turbo question about inlets and outlets
- Automatic trans shifter differences
- 2003 A4 engine swap help
- Blowing boost pipe
- S3 BAM alternator replacement noise after
- New to the audi
- 01 TT 225 / code 1296
- Fuel pump issue
- 1.8T engine BYT Timing Chain jumped
- Control Valve Problem
- 2001 Audi A4 1.8t crank no start
- 1.8T, trying to get the turbo to stall
- Audi s3 1.8T, transmission issue, help
- 1.8 tfsi pcv failure
- Overheating and blowing cold
- Loud clunk on acceleration. 1.8t 225 audi tt
- Bored vs Bored and Stroked?
- A3 intermittent whine on deceleration
- 2002 audi a4 1.8t rough idle, misfire,
- 1,8T idling, Code 0507 and sent of hot oil....
- Bad automatic transmission issue.
- New Starter ... Starts and Runs but makes dinging sound
- Stupmed 1.8t swap
- 1.8t agu, strange sound
- Engine ID
- Made for European market, sold in USA
- Very hard starting engine
- Engine swap
- Cam/Crank timing out
- 2010 Audi a4 1.8 TFIS B8 rebuild
- Transmission problem A4 1.8 Quattro
- Blown Cylinder head
- Audi A5 2008 1,8TFSI lost power after chain replacement
- Boost Issues (N75?)
- Coolant system problems A4 1.8q
- 2004 TT Tiptronic gearbob
- Short to ground codes and blowing fuse #9
- CEL P1296 code ?
- Codes Issue and costs
- B8 Timing Belt/ chain
- 2005 Audi 1.8t 20v misfire problems
- Audi a4 b5wont start but clicks?
- 1.8 tfsi, interruptions on idle and cold engine
- Engine swap
- Clutch
- 2001 audi a4 1.8t rodknock on start up
- 1.8t crank sprocket gear
- Audi A3 8L 1.8T Quattro Boost isues
- 1.8t swap into 2.8
- 02 A4 Overheating
- Problem with finding part KO3
- When engine is hot and a/c is of rough idle
- Stater runs but doesn't turn engine over
- ECM and code reader won't talk
- 1.8 tfsi cdhb
- 2003 TT Roadster - Spluttering badly, very jumpy
- 1.8 TSFI
- Epc light and check engine on
- 2003 A4 1.8T 20 V AMB engine
- A3 1998 1.8 transmission sensor location?
- wastegates
- Wastegate is not sealing properly when closed causing underboost condition
- AEB use of VVT
- 1.8T AMB Cracked Cylinder Head swap! NOWWW, Rough Idle/Misfiring??!!
- p0010 and p0012
- 2004 1.8L Turbo spools on Start Up
- 2001 audi a3, 1.8 petrol miss firing
- Odd valve cover issue
- Blown piston
- Tandem pump problem - anyone with experience
- Engine light flashing
- 2003 A4 hytronic V30
- Audi TT Quattro 2002 new motor.
- Audi A4 1.8T running rough
- Diagnosis
- Intermittent start
- Audi a4 water leak and steam sound from drops
- GTRS on TT225 not spooling - test for Turbo INNTERNAL leak or defects?
- 1.8T MAF
- Will an intake made for a mk4 VW Golf GTI 1.8t fit on my 2002 Audi?
- Need help, fuel consumption very high. (Fault codes included)
- Where does this go? (Audi TT 1.8T)
- Vacuum line help
- golf iv gti 1.8t (150hk)
- Vacuum question
- Turbo swap
- Very high engine vacuum, rough idle/hunting, stalling, negative fuel trims
- 04 A4 1.8t ECU set up with a stinger 4424v4 ECU. I need help bad
- water in oil after head swap
- Please help!!
- Idle jumps between 1500 and 2000 rpms
- 1,8T AGU swap
- vacuum from the turbo
- Check Engine Light never comes on
- NO BOOST
- Oil in turbo intercooler circuit
- Help. possible total engine failure !!!!!
- Help, see my valves and spark plugs PICS
- I have 2005 Audi A4 1.8 that won't start
- Engine oil indication on MMI
- PRND432 LIGHTS NOT SHOWING
- Ok...what's missing? 2004 A4 1.8T Quattro
- Repeated water pump failure
- audi boosting at 0.3
- HELP 2001 A4 1.8T 142k mi coolant ++ issues
- Loss of coolant
- Valve train noise help,ty!
- 2012 Audi A4 - Sputtering at low idle
- 98 Audi A4 Quattro engine swap
- audi a5 1.8 tfsi 2012
- Need to find out what part this is
- Chasing a System too Lean Code
- Audi A4 1.8t Quattro clutch problem
- Help!
- Starting and limp mode problem
- AUDI A4 B6 1.8 T multronic
- different between audi tt mk1 engine the 185 hp and 225
- Where is the speed sensor Located!? 2003 Audi A4 1.8t Quattro? Pls help
- Cam selection
- 2000 Audi TT 52K Miles strange start
- MANIFOLD GASKETS
- Running badly on low revs
- blow by???
- A4 1.8T B6 P301 & P0507 CODE
- Head gasket
- Can someone please tell me what this means before i rip my hair out.
- Trim Rich + Boost issue + EPC = Wtf?
- My Audi wont shift.
- voltage fluctuating... white smoke under hood
- Engine codes
- 2001 Audi A4 smoke problem
- 2004 audi a4
- oil sensor lights on my audi a4 2001
- 2002 1.8t quattro cooling fan on all the time
- 1999 A4 No start no fuel no spark
- Where to smoke / pressure test the vacuum lines
- Coolant Warning Light - New Owner, Need Help
- amb awm engine swap
- Min Oil Warning
- Turbo questions
- 2003 A4 1.8t Timing belt broke
- Help! Overheating and no heat problem!
- Coolant litteraly spitting out of my exhaust!
- Whining noise from motor/wheel
- 2000 a4 1.8t atw rough while driving
- 02 audi a4 stalled while going 80 mph
- Audi A4- Issue starting/accelerating
- Audi A6 1.8t -03 starting trouble.
- cracked oil pan...thoughts
- To much boost
- 1.8T AEB INTAKE MANIFOLD SWAP
- Audi a4 1.8t p0011
- Audi A4 2003 weird sound
- Moteur qui tourne pas rond sur audi tt roadster quattro 225 APX
- Code 17698
- 2002 A4 1.8 T knock sensor location
- 1.8t awm - stroking with vw 2.0 crankshaft
- GTS Tuning
- Help on oil change
- Audi a4 wierd noice *video link*
- 2000 A4 1.8t (Auto) engine cut out now wont start
- Multiple codes 2003 A4 avant
- 2001 1.8t quattro a4 can't find PCV valve
- Cold air intake question Audi A6 1.8 turbo
- Misfire! b6 1.8t avant
- Trip and partial odo keep resetting themselves
- 2003 a4 1.8 t missing
- Turbo problem
- Chicago rebuilt engines sources
- 05 A4 broken timing belt & possibly toast engine
- AC noise
- Installed new motor car starts but wont move
- Torque Converter or Something Else??
- 01 a4 quattro
- 01 a4 avant quattro 1.8t grinding noise 1st threw 3rd
- Maximum machinable head warp
- Intermittent whistling noise coming from engine
- Bipolar boost, sMell of raw fuel horrible gas milage
- Measured ZERO Voltage: bad Regulator?
- Please help audi a4 1.8 violently jerking in all gears
- Coolant loss.
- temp gauge running 1 line over norm
- '2002 Audi A4
- 2004 A4 1.8t quattro starting issues
- 99 a4 b5 fuel issues
- Check Engine-Thermostat
- Oil light.
- A4 B5 1.8t Quattro losing lots of coolant
- breather tube broken, could it cause misfires ?
- 02 a4 1.8t a lot of codes coming up idk where to start
- Water Pump and Timing Belt
- 04 A4 1.8 Qt
- 03 a4 avant 1.8t camshaft position sensor
- 2015 A3 1.8T EPC Light On
- Cam position sensor ??
- 1.8 engine sound Normal ? VIDEO
- Oil Leaking Everywhere
- 2001 Audi A4 1.8 Turbo White Smoke From Exhaust
- 2001 Audi TT 1.8T warm idle engine noise
- Unusual fan motor noise after engine shut off 2001 audi tt
- 1998 Audi A4 1.8T, Timing Belt
- Blown 1.8l Turbo
- Heat Question
- doubling head gasket question
- 2003 Audi a4 1.8t quattro no crank, no start, no fuel pressure
- Hard top for Mk1 TT roadster
- Audi A6 C5 1.8T problems
- 03 audi a4 b6 1.8t oil help ??
- Audi mk1 TT boost problems
- Rough idle and misfire on all cyl at idle, and above 60mph
- Intermittent boost
- Mk1 tt overheating at idle
- a4 petrol turbo problem
- Blow off valve
- Overheating issue
- Affordable Performance help!
- 2001 audi a4 awd turbo rough idle but smooth above 100rpms?
- 05 A4 avant overheating issue
- 1999 Audi A4
- 03 A4 1.8t issues with oil pressure sensor
