2.5TDI Starting problems...
Car will start immidiately when left overnight.
Car will start immidiately when car is hot.
Car can be a pain when left for 3-4hrs. it can
take up to 8-10 seconds of engine turning before start. Anyone else experiance this ?
2004 Audi Allroad. 52000 Klms...
just speculations... but glow plugs not working as they should?
When hot the plugs aren't needed, when cold the plugs come on as they should, but when temperature is somewhere in between the system telling the plugs to come on isn't working? Does this sound reasonable?
Maybe some temperature sensor giving bad readings?
Never had that problem myself, so I'm really just speculating.
Re: just speculations... but glow plugs not working as they should?
Believe it or not the plugs only come on under 5°C. I have been thinking about trying a different ECU to see if it makes a difference... If only Q5 was out the Allroad would be gone. New Allroad still too expensive "Det veit du val"
Cheers
Cheers
I didn't know that... why does the glow plug symbol light up at higher temps for me then?
Is there some other system that helps with cold starts and also causes the glow symbol to show? Or is it only the newer 180 hp that does without glow plugs over 5º?
New Allroad starts at around £56' for the 2.7TDI, I take it the price is much lower in the UK?
The light comes on irregardless but I am told by Audi ( Moller ) that
over 5°C there is no preheating of the diesel. Mine is 2004 don't think there is much difference between earlier models apart from the camshafts on early 2.5 TDI's had excessive wear. A change in 2003 fixed that I'm told. 2.7TDI Quattro Tip is 800,000 NOK for a properly speced one.
gear box problem
HELLO EVERYBODY,
I HAVE BOUGHT MY AUDI ALLROAD 2.5TDI STEPTRONIC GEARBOX SINCE I YEAR AND IM GETTING A LOT OF TROUBLES WITH THE CAR. A COUPLE OF WEEKS BEFORE, IVE JUST CHANGED THE WATER PUMP. SOME MONTHS AGO I HAD A SEVERE BREAKDOWN WITH MY GEARBOX AND HAD TO OPEN CHANGE THE PUMP INSIDE AND COST SO MANY $$$$. NOW THE CAR IS LACKING POWER - I HAVE TO ACCELERATE A LOT TO GET IT MOVING, I REALLY DONT KNOW WHAT IS HAPPENING. THE MECHANICAL GUY WHO HAD REPAIRED THE GEARBOX LAST TIME IS TELLING ME WE HAVE TO OPEN GEATRBOX AGAIN AND CHANGE ALL THE DISCS. ONE THINK IM NOT UNDERSTANDING - SHOULD ONE SPEED NOT WORKING - IF WE PUSH TO MANUAL MODE ON 2 SPEED WE SHOULD BE ABLE TO DRIVE IT ANYWAY.. NEED YOUR ADVISE GUYS... PLS HELP ME FIND A SOLUTION CAUSE IM DESPERATE.
THANKING GUYS IN ADVANCE.
NOORE
NOORE
All road 2.5tdi 2004 poor hot start
Hello i have exactly the same problem with my allroad 2004 90k miles bau engine auto, did you ever sort this problem any advice greatly appreciated thanks john
If compression values will be more than 27 bar - you need check revolution's of starter during starting. Stator of starter have a permanent magnets which can lose technical properties, especially when engine heated.
If it is true - you have two way.
1st - renew starter or stator of starter.
2nd - forget about it.
mendfred
A4 (B7 Platform) Discussion
01-15-2017 03:05 PM
HACK THS
13
02-18-2005 05:16 PM
SCd_Walter
01-07-2004 03:49 PM
