2.5Tdi: Turning a 150hp into a 180hp
Old 03-15-2007, 12:16 PM
New Member
Henka_E's Avatar
Default 2.5Tdi: Turning a 150hp into a 180hp
The A6Q was sold with a 180hp TDi engine and the FWD version had 150hp. Has anyone here converted their 150hp itno a 180hp? I was wondering because the 180hp version can be chipped to 215hk and the 150hp version will only get 185hp. So, wanting over 200hp in a A4Q, seems I have to convert to 180håp spec first. These are the parts that differ:
Air mass meter
Injectors
High pressure fuel pump
Vacuum pump
Turbo
Exh elbow and cats
Unfortunantly, the fuel pump is very expensive... Anyone have ideas on how to do it on the cheap-o??
Old 03-16-2007, 05:29 AM
Feuerstein's Avatar
Default have a 2.5TDI 150 that was chipped to 185, not a good thing...
tiptronic transmission didn't like the added power at all, upshifts at high rpm were noisy and rough. Even after returning to stock 150 hp setting I've had the car go into emergency mode several times, where it won't go over 2800 rpm and 70 km/h.
You have a manual 6-speed transmission?
My best guess for cheap HP fuel pump is to search wreckers online, but I guess there are rather few usable 2.5TDI 180hp cars at the wreckers (I guess you'd want one that doesn't have front collision damage). Also, do you really want to put in a fuel pump that may have covered 200' km in another car already? Same goes for turbo.
Hej då! (Jeg er norsk)
Old 03-16-2007, 07:04 AM
New Member
badgerh's Avatar
Default Re: 2.5Tdi: Turning a 150hp into a 180hp
You would probably have lower total cost of change by selling your car and buying a 180. The engines were very different and there are plenty of 180s around.
I certainly would never consider going to 180 and then chipping it to 215 - a recipe for some very expensive pops!
Old 08-06-2007, 07:12 PM
RMN
Member
RMN's Avatar
huh...what sort of torque figures does the chip give you?
Old 12-21-2007, 05:54 PM
Feuerstein's Avatar
I think it was 380 NM, original was 310
hos79
17
10-04-2020 10:02 AM
UrS4boy
Audi Original "S" Cars
10
11-28-2007 08:56 PM
Extremesport3
2.0T FSI Discussion
10-22-2007 07:02 PM
jd2
13
02-27-2006 08:39 PM
The Librarian
08-12-2004 09:46 PM
Quick Reply: 2.5Tdi: Turning a 150hp into a 180hp
