Telematics Discussion
Sponsored by:
Sponsored by:
Parrot CK3100 volume issue with Bose Symphony
Old 04-18-2007, 07:32 AM
New Member
TedKM3's Avatar
Default Parrot CK3100 volume issue with Bose Symphony
Hi folks, I have a '03 AR with Bose/Symphony head unit. It has OnStar, but I don't have a subscription. I just had a Parrot CK3100 installed and it works fine in terms of pairing, but the volume is VERY low once the engine is running. It sounds reasonably fine with the engine off, but as soon as it's running the volume drops to an unacceptable level.
Can anyone help? No one seems to know what to do (installer and Parrott). Got the Parrot brain replaced, the HU replaced and a different ground wire and nothing helped. Even the Audi tech took a look at the VAG settings (that he knew of) and couldn't help.
Any advice?
Old 04-29-2007, 09:00 PM
New Member
PillPu$her's Avatar
Default Re: Parrot CK3100 volume issue with Bose Symphony
I just installed mine today. Same problem. Do you have the newest firmware (4.16)? I'm going to try that to see if it helps?
rob_chitown
Audi 100 / A6 (C4 Platform)
9
10-12-2007 06:45 AM
TedKM3
04-20-2007 07:12 PM
TedKM3
Audi allroad
04-20-2007 03:52 PM
gazza65
04-06-2003 10:54 PM
kkii9
01-06-2002 11:40 PM
Quick Reply: Parrot CK3100 volume issue with Bose Symphony
