** GruvenParts.com Adjustable Rear Control Arms, Swaybar End Links and More for TT !!
#11
TT/R32 Rear Adjustable Control Arms
Click on the picture to visit our product page for up to date pricing info.
CHOOSE POLY-BUSHINGS OR SPHERICAL ROD ENDS !!
Got a lowered TT or R32 ? Then you already know how the camber and toe become completely out of sorts, causing poor handling and expensive tire wear the more its lowered.
The GruvenParts adjustable control arms allow for complete rear wheel alignment and feature the following :
Choose from a zero deflection high radial load PTFE lined inboard spherical joint with protective dust boots preinstalled over specially machined bushings. The fit of the boot over the spherical joint and bushings is nearly water tight!
OR
A poly bushing inboard end made from heat treated 4340 forged chromoly housing, thread in grease fitting, zinc plated steel protective sleeves, and race grade greaseable black polyurethane bushings from Energy Suspension.
You decide which set up you want ! The zero deflection spherical joints are suited for serious track abuse while the poly bushing ends are better suited for daily drivers.
All GruvenParts control arms feature the following :
Super strong, heat treated 4340 aircraft grade chromoly rod and ¼” thick U-Joints with machined, internally lubricated (molybdenum disulfide) threads. No weak aluminum is used for these parts (aluminum threads wont hold up).
Distinct proper wrench adjustment flats machined into the bars which allow for 2” of length adjustment while on the car. There is no knurled hand adjustment nonsense here, ours are simple to adjust.
Thick, durable powder coat finish (and zinc plating on the poly bushing ends) in your choice of high gloss black or Bilstein jazz blue.
Made right here in Atlanta, Georgia by our FAA approved commercial aviation machine shop working on state of the art CNC mills and lathes. You wont find many shops working at our level, and you wont find higher quality anywhere !
We know the economy is tough right now, so we are offering these at prices well under our competition. Buy 2 sets and save !!!
This product fits Audi TT (2001-2006), Audi A3/S3, VW R32 (2004), VW Golf 4motion and 4motion Variant, VW Bora 4motion and 4motion Variant and replaces P/N 1J0-505-323L (1J0505323L) and 1J0-505-323N (1J0505323N).
***Save Big $ when buying these in conjunction with our Adjustable Rear Swaybar End Links and our Adjustable Front Swaybar End Links
...And finally...
TT/R32 Rear Adjustable Control Arm Hardware
Need to buy 1 off’s for a project? Want new/longer fasteners? Look below for the parts to get the job done!
- High radial load GENUINE FK JMX Series PTFE lined heim joint kits
- Custom 4340 Forged, Heat Treated poly bushing ends with Rolled Threads
- Racing Grade protective rubber dust boots for ¾” heim joints
- Longer bolt kits - 80mm in length, grade 8.8, zinc plated
- Headlight Leveling System Bracket
GruvenParts Billet R32/TT Adjustable Front Swaybar Endlinks !
GruvenParts.com is happy to release these Billet Front Adjustable Swaybar End Link sets for the Audi TT MK1 and VW MK4 R32.
We start with a center body made from 6061-T651 aircraft grade Aluminum hex to replace the flimsy non-adjustable OEM spaghetti links. We then add super strong 6,000 lbs radial load capacity sealed ball joints on either end to provide many years of noise free operation. Our ball joints have a built in dust boots to seal out the elements and do not require any maintenance. If they ever do need to be replaced, they can bought seperately on our site. These linkages will not deflect under the hardest track corners and will provide the most accurate handling.
All center sections are powder coated with a thick layer of either Gloss Black or Bilstein Jazz Blue - please choose during check out.
Our design allows simple and quick adjustment on the car. Simply loosen the jam nuts at either end and spin the center body portion to lengthen or shorten, then retighten the jam nuts.
This adjustable design will provide +/- 1 inch of adjustment on the car, which is enough to handle all lowered (or raised) set ups. You want the stabilizer bar end links to be as vertical as possible, perpendicular to the swaybar itself to avoid any loading in the fwd/aft direction.
Applications :
This product comes as a set of 2 endlinks and replaces OEM P/N's 1J0-411-315D (1J0411315D) and 1J0-411-316D (1J0411316D) found on the following vehicles and possibly other makes, please verify your OEM part numbers match these listed :
[b]1999-2006 Audi TT MK1 (all)
2004 VW R32 (all)
GruvenParts Billet R32/TT Adjustable Rear Swaybar Endlinks !
Got a lowered TT MK1 or R32 MKIV ? Then you need to be able to adjust your rear stabilizer bar end links to ensure the linkages ride perpendicular to the sway bar and correct the less than ideal handling typical of lowered set ups. The factory set up does not provide any adjustability in the sway bar end links but GruvenParts.com has you covered!
We’re proud to release these adjustable rear stabilizer bar end links with FORGED high strength steel lower bushing ends with rolled (not cut!) threads, and high strength fully sealed upper tie rod ends. The center bodies are custom machined from STAINLESS hex in house and then powder coated beautiful gloss black or Bilstein jazz blue to match our Adjustable Rear Control Arms and our Adjustable Front Sway Bar End Links.
These come ready to install and are pre-greased with special polyurethane grease and include a new lock nut on the top joint. Please re-use your existing lower OEM bolt when installing these adjustable units.
These are sold in sets of 2, enough for 1 vehicle.
This product fits Audi TT (2001-2006), Audi A3/S3, VW MKIV R32 (2004), Golf 4motion and 4motion Variant, VW Bora 4motion and 4motion Variant and replaces OEM linkage P/N 1J0505466B.
Save Big $ when buying these in conjunction with our Adjustable Rear Control Arms and our Adjustable Front Swaybar End Links
#12
Billet / Carbon Fiber / "VeeChain"
Pay homage to the unique VR6 engine design with this accurate CNC keychain minature. Measuring about 2 inches in length by 1 inch width, its an instant conversation starter with the girls at the parties who are constantly wondering about your 15 degree cylinder offset. This is an Oichan original design (Corrado - Oichan's Volkswagen Corrado VR6) sold under his permission. Beware of the rip off versions out there which are made using water jet process and have ragged edges and poor quality. Ours are made on a 3 axis CNC 1 at a time and are literally perfect replications of the unique VR6 engine.
Available in machine polished billet aluminum or genuine 3K weave carbon fiber plate.
#13
Billet VR6 Crack Pipes for ALL VR6 Engines Corrado thru R32!
MACHINED FROM 6061-T651 ALUMINUM TO EXACTLY MATCH OEM PIPE DIMENSIONS - OURS DOES NOT COME WITH CHEAP THIN WALLED TAPPED FITTINGS LIKE OTHER LESSER PIPES !!
12V and 24V VR6 Coolant Pipes aka Crack Pipes
GruvenParts.com was the 1st to build this part and it’s what started us off! We manufacture this pipe EXACTLY to match the OEM part shape so there is NEVER a fitment issue. Be careful when considering other billet pipes which do not match the exact shape of the OEM pipe. The fitment of this part is tricky and the shape MUST BE IDENTICAL to the OEM part to ensure correct alignment between the water pump and thermo housing.
If you have a billet crack pipe in your VR6, chances are it was made by us. Hand crafted in our Aerospace shop using O-rings from the Boeing 777, proven by many hours of track time, it's the highest quality crack pipe you can buy. It's on all of our track cars and has withstood countless hours of track abuse! Our pipe has a modular design which allows you to plug the oil cooler feed line with a ¼ NPT plug if installing an external oil cooler. Ours can also be ordered with a chrome plated drain valve for quick and clean coolant flushes. The pipe can also be ordered with a brilliant chrome finish for those seeking the ultimate engine bay bling!
If you dont want to do this job again, buy the LIFETIME WARRANTED GruvenParts.com billet CrackPipe !
Make sure to see our website for the complete installation DIY
The 12V version replaces OEM p/n 021-121-050C (021121050C) found in 12V VR6 : VW Corrado, Golf, Jetta, Passat, and Eurovan.
The 24V version replaces OEM p/n 022-121-050 (022121050) found in 24V VR6 : VW R32, Golf, Jetta, Eurovan, EOS, Audi : 3.2L V6 TT and A3
#14
Introducing the GruvenParts.com Upgraded MKIV VR6 Intake Manifold Trifecta -- A SURE Bet !
These parts replace the cheap plastic parts associated with the following intake manifold drive units -
021-133-653 (021133653) on 2.8L 12V VR6 engines - 1999-2006 Golf, Jetta, Jetta Wagon, Vanagon
022-133-653 (022133653) on 2.8L 24V VR6 engines - 2002 on Golf, Jetta, Jetta Wagon, Vanagon
022-133-653B (022133653B) on 3.2L 24V VR6 engines - Touareg, R32, Eos
MKIV VR6 Intake Manifold Bushings - 12V and 24V VR6 Engines - Click the Pic !
Unbeatable Tite-Loc bushings are made to precisely mate with your intake manifold and prevent rattles and expensive damage to the manifold bore. Replace the cheap VW/Audi rod bushings with these BEFORE rattling begins to save your upper intake manifold !
MKIV VR6 Intake Manifold Drive Ball - All VR6 Engines - Click the Pic !
A 6061-T651 billet version of the flimsy plastic drive ball which is crucial to your VR6 variable intake manifold system. Don't spend more on a plastic part than the lifetime billet version !
MKIV VR6 Intake Manifold Drive Linkage - All VR6 Engines - Click the Pic !
A 6061-T651 billet version of the flimsy plastic drive link which is crucial to your VR6 variable intake manifold system. Don't spend more on a plastic part than our lifetime billet version !
#15
Click Here for the GruvenParts 1.8T Billet Dipstick Funnel Combo !
GruvenParts is proud to re-release these beautiful 1.8T dipstick handles with billet funnels. You can now choose from our high polished or as machined finish ! These parts are precision CNC'd from aerospace grade 6061-T651 aluminum right here in the good ole USA. Don't fall for a Chinese knock off, buy direct from the source.
Our billet dipstick handle is available in traditional round or retro square designs and will take the place of your existing fugly orange dipstick handle while retaining the stamped steel rigid OEM dipstick wire. Braided wires just don't work as they bend in the tube and can provide incorrect oil level readings. Why not re-use your existing OEM wire AND get rid of the construction cone orange handle ? This is truly the best of both worlds.
Please CLICK HERE for the DIY on how to easily install our billet dipstick handle onto your existing OEM dipstick.
Choose from highly polished (shown on left) or as machined (shown on right) to suit your tastes. The highly polished version looks nearly chrome and will really set apart your vehicle at the shows (while never breaking again!). You could also anodize or paint these in whatever color you wish.
Finally, a bulletproof replacement for the OEM plastic dipstick handle and funnel found on 1.8T VW and Audi!
This version fits in place of OEM P/N 06A-103-663B (06A103663B) dipstick funnel found on 1.8T Audi TT, MKIV Golf, Jetta, and New Beetle.
Please make sure to check your specific vehicle, as VW and Audi have both produced several plastic orange versions.
Got another dipstick not shown on our product page ? Check out our universal billet dipstick handles ! Now you can easily convert almost any dipstick to a billet handle !
Click Here for GruvenParts Billet Universal Dipstick Handles
#16
#17
Billet VW/Audi 24V 2.8/3.2/3.6L Oil Filter Housing Caps !
Modular Billet Aluminum Oil Filter Housings For VW And Audi 24V 2.8/3.2/3.6L Engines ! (shown with optional filter/o-ring installed)
This product is intended to replace VW/Audi Part Number 071-115-433 (071115433). Please check the OEM part number of your oil filter housing cap before ordering. You can do this easily by calling your dealer and giving them your VIN # and asking them to tell you the part number for your oil filter housing cap.
#18
GruvenParts.com builds bulletproof Hardware for your VW/Audi !!
Click Here to Visit GruvenParts.com !
#19
#20
