01 TT AWD ABS PROBLEMS
Old 02-23-2017, 07:29 AM
BADINC's Avatar
Default 01 TT AWD ABS PROBLEMS
I HAVE A 01 AUDI TT I HAVE A ESE LIGHT ON AND CANT FIX IT I PUT A NEW ABS CONTROL HERE IS WHAT IM GETTING ANY HELP WOUL BE COOL
Wednesday,22,February,2017,19:17:25:25522
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.1.1.0 (x64)
Data version: 20170106 DS267.0
Ross-Tech: Home
Dealer/Shop Name: christensen performance
Chassis Type: 8N - Audi TT (1999 > 2007)
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
Mileage: 114150km-70929miles
Address 01: Engine Labels: 06A-906-032-AMU.lbl
Part No: 8N0 906 018 T
Component: 1.8L R4/5VT G 0001
Coding: 06610
Shop #: WSC 01236
VCID: 428B2A394EEC635183-5140
1 Fault Found:
18057 - Powertrain Data Bus
P1649 - 35-00 - Missing Message from ABS Controller
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 8N0-907-379-MK20-E.lbl
Part No: 8N0 907 379 E
Component: ESP 20 CAN V005
Coding: 18446
Shop #: WSC 12345
VCID: 3E735EC93A1407B1E7-4B1A
3 Faults Found:
01314 - Engine Control Module
49-00 - No Communications
01324 - Control Module for All Wheel Drive (J492)
00778 - Steering Angle Sensor (G85)
Address 08: Auto HVAC Labels: 8N0-820-043.lbl
Part No: 8N0 820 043 A
Component: TT-KLIMAVOLLAUTOMAT D03
Coding: 00140
Shop #: WSC 01236
VCID: 285F9891C890A901BD-2580
No fault code found.
Address 15: Airbags Labels: 8N8-909-601.lbl
Part No: 8N8 909 601
Component: Airbag Front+Seite 1005
Coding: 10102
Shop #: WSC 01236
VCID: 77FD8BED55AEF6F9E4-515E
Address 17: Instruments Labels: 8Nx-920-xxx-17.lbl
Part No: 8N1 920 930 E
Component: KOMBI+WEGFAHRS. M73 D09
Coding: 07244
Shop #: WSC 42281
VCID: 33657FFD0156DAD918-4B00
Address 22: AWD Labels: 02D-900-554.lbl
Part No: 02D 900 554 C
Component: HALDEX LSC ECC 0010
VCID: 204F80B1A0A05141F5-4B1A
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 35: Centr. Locks Labels: 8Nx-962-267.lbl
Part No: 8N7 962 267 A
Component: Central Lock/Alarm D04
Coding: 15900
Shop #: WSC 01236
VCID: 3E735EC93A1407B1E7-4ECE
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8N7 951 177
Component: Innenraumueberw. D13
Coding: 00001
Shop #: WSC 00000
VCID: 7BF597DD6986D29980-522E
Address 55: Headlight Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00010
Shop #: WSC 01236
VCID: 65C1D1A5FF02746946-5198
End-------------------------(Elapsed Time: 09:49)--------------------------
Old 02-25-2017, 12:19 PM
Walpole5's Avatar
If you go into the Ross-Tech Wiki, it will explain the codes. The result for code 01314 is:
01314 - Engine Control Module: No Communications
Possible Causes
  • CAN-Databus Wiring/Connectors from/to Engine Control Module faulty
  • Fault(s) stored in Engine Control Module
  • Engine Control Module recently flashed or re-mapped
Possible Solutions
  • Check CAN-Databus Wiring/Connectors from/to Engine Control Module
  • Check Measuring Value Blocks (MVB)
    • Usually Measuring Value Blocks (MVB) 125+ show the current Communication Status
Special Notes
  • When found in a 2005 through 2007 2.5L NAR (North American Region) (1K) Jetta check the T121/62 (Red/Black) traced power wire to the ECM. If power is missing or a voltage drop is present that wire may be damaged anywhere between 6" and 18" from the connector itself. This will result in no communication in addition to a no-start.
Old 02-25-2017, 02:50 PM
Mister Bally's Avatar
Use standard automotive electrical system troubleshooting techniques to define and repair those communication errors.
dubdaz
05-11-2010 10:28 PM
Da'sTTand
VAG-COM Discussion
08-28-2009 07:10 AM
terry425
06-30-2008 01:05 PM
LHWskier
05-29-2008 10:40 AM
AudiTT225CT
09-24-2005 04:50 AM
Quick Reply: 01 TT AWD ABS PROBLEMS
