2000 tt fuel pump shut down
2000 TT, the fuel pump shuts down when the fans turn on at normal operating range, same time every time, pump and relay check out, no codes, must be ECM shutting it off but why? Anyone have any Idea's
If no CEL (Check Engine Light) illuminated; I'm going with a massive Ground fault between the battery, fans, engine and fuel pump. Or to the fuel pump relay.
Standard Automotive Electrical Troubleshooting techniques apply here.
If you do have the CEL illuminated; use VCDS (not a cheap hand-held scan tool) to read fault codes. Repair as needed.
