2001 TT convertible
2001 TT convertible
I have a 2001 Audi TT convertible with 25,500kms. When I adjusted my stearing column the signal lights, AC fan and windshield wipers stopped working. I moved the column back and everything started working again. I have had the occasional issue with the signal lights off and on after I have been driving for a while but I never noticed if everything else was not working.
Does anyone have any idea what it could be? Could it be the load reduction switch or the ignition switch or a loose wire?
Thanks for your help
Sounds like a short, possible loose connector in the steering column wiring harness to me from what you describe.
I think its possible to just open the column covers, I did so when I removed my instrument cluster. Should be able to get a visual on the harness at least as a starting point.
Audi TT (2000-2006) Instrument Cluster Rebuild | ModuleMaster
removal instructions here, might help. just read stuff about instrument column
FLaudiguy69
08-20-2018 01:04 PM
