2002 225 overheating and no AC
To any TT genius,
Guys, I ahve an 02 225 coupe that 2 things have happened in last few days....
1) I'm overheating at idle.
2) my AC blows hot air.
I noticed the temp going up when I rec'd the alarm...I had AC on in hopes that it would start blowing cold again.
I turned off AC and soon my temp guage came back to dead center and alarm cleared.
I checked my low side AC port to try to add R134, but had tons of pressure.
Any thoughts before I go to the stealer? I have 95K miles on her.
My hopes that its a problem common to both issues related to a simple temperature switch somewhere.
I also noted that my fan hasn't been coming on.(or at least I didn't notice it)
Thanks tons for any advice.
wyaTT
wyaTT
Re: are your fans working?
Nope.
Another message states to remove battery and clean terminals beneath it. I can do this as I have those skills....as long as I dont have to remove half of the car to do this. Is the terminal connection immediately beneath the battery?
Thanks man,
wyaTT
Thanks man,
wyaTT
Re: Check fuses on top of battery.
I already did. They look healthy (I presume you are talking of the 3 fuses on top, 30A each). I was thinking about just replacing them anyway, but didnt see any melted fuses or obvious problems. Thanks though.
Re: could be a defective fan relay/switch...they are known to go bad at times...
I'd change that right now if I knew where it was. I live about 300 yards from the stealer. Is it an easy evolution?
