2002 225 overheating and no AC
Old 05-31-2007, 05:22 PM
  #21
MaxHedrm's Avatar
Default Zap!
<ul><li><a href="https://forums.audiworld.com/tt/msgs/1648531.phtml">Zap!</a></li></ul>
Old 09-26-2009, 03:20 PM
  #22
jgTT01's Avatar
Hey wyaTT, Did you ever get this figured out? When I saw your pics I thought you had taken a picture of my fuse panel! The description of your problem is exactly the same as mine.
jgTT01
Old 09-28-2009, 08:22 AM
  #23
wyaTT's Avatar
jgTT01
As a matter of fact I did. But now I have a new fan problem...no fans at all, no fried fuses, fan controller looks fine, and I have no AC (blows warm). I smelled electrical cooking just before AC went out.
Old 09-28-2009, 07:57 PM
  #24
gaber6's Avatar
Default I'm going through same thing. REPLACED everything
except the fans now..
New green sensor..
New fan switch in driver side of radiator..
New fan relay box under battery..
New after run pump..
Thermostat switched out..
No AC.. After run pump doesn't run.. and fans don't turn on at all even with AC on. Fuses are good.
UGH. I have an interview tomorrow, so I have to take the car instead of the motorcycle and risk some overheating.
Old 09-29-2009, 09:10 PM
  #25
gaber6's Avatar
Drove with only a slight bit of overheating in the 108 degree phoenix heat with no fans functioning, so I'm guessing the thermostat and water pump were working well. I guess it'll be new fans for me.
Old 10-05-2009, 07:25 AM
  #26
jgTT01's Avatar
Yikes!!! I hope that is not a foreshadowing of my future. So far so good with mine. It's getting to be cool weather here in the midwest though, so I haven't been running the air.
Old 10-05-2009, 07:27 AM
  #27
jgTT01's Avatar
Hope that does it for you gaber6. Good luck!
Old 10-07-2009, 08:50 AM
  #28
VARATEK's Avatar
""""" I guess it'll be new fans for me. """""""
chances of both fans dead is slim. Apply 12 volts directly to the connector to one fan and see if it runs. Then do the other fan.
Old 10-14-2009, 11:11 PM
  #29
gaber6's Avatar
Well I'll wait on the fans until I get my instrument cluster rebuild back. Saw one on Ebay for $350 with all good reviews.. If that doesn't fix anything, I'll get the fans, and at least keep the temp consistent.
Old 10-15-2009, 03:40 AM
  #30
AudiWorld Awesome User
InTTruder's Avatar
Fan Control Module fail- common problem.
Quick Reply: 2002 225 overheating and no AC
