2004 TT Roadster radio issue:
I recent bought a 2004 'base' FWD TT Roadster with the Bose 'concert' AM/FM CD player. I think that my antenna is the issue. The radio works fine within 20 miles of a radio station but doesn't work outside of that range. The stubby antenna is located on the left rear fender. Does this system have a signal amplifier? Is it in the mast? Is it in the antenna base? Or is it located in the wiring somewhere? Bentley only explains how to remove the radio or antenna from the system.
This car only has about 10 of the 'normal' problems and your forum covers most of them. Thanks for your help!
Similar Issue
I just bought a 2002 225 coupe, and all hear is static, also I don't know if the "antenna" being built into the rear window has anything to do with it. PLEASE HELP US!!
-D. Parker
-D. Parker
The radio antenna is integrated into the rear window defroster
The stub is exclusively for telephone. For years I thought the stub was FM and the defroster was AM but that is not the case. If your rear window has an aftermarket metallic tint, it will totally kill AM reception and reduce FM reception. If that is not your problem, there is a static bypass capacitor that fails but in that case static should relate to RPM.
Mine is not a COUPE. The Bentley manual says that the radio antenna for the roadster has a 12" connector at each end and a section of antenna wire between them. One of the 12" sections terminates at the antenna 'base'. The 'mast' threads into the base. Is there an signal amplifier in the Roadster model?
The information I provided is the same for coupes and roadsters
Aarontrieu
06-12-2010 07:13 AM
TT4XNYR
TT (Mk2) Discussion
9
02-09-2009 05:53 PM
christruelove
01-06-2001 02:56 AM
