Blinker relay replacement... Piece of cake
Old 01-12-2005, 03:00 AM
  #11
MarTT's Avatar
Wow - great write up. Thanks.
Old 01-12-2005, 03:33 AM
  #12
CrazyTT's Avatar
Well done and documented, did you see what the tools, used to release the radio looked like?
Old 01-12-2005, 05:03 AM
  #13
TT twister's Avatar
Great and text/pics!! The dealer fixed mine after saying twice they couldn't reproduce the problem.
Old 01-12-2005, 06:02 AM
  #14
Elder Member
kodeTT's Avatar
Default Excellent. Makes me want to change mine that's going wacky. Where did you
get the relay from? and how much? TIA.
Old 01-12-2005, 06:10 AM
  #15
SparTTan's Avatar
Default Yeah, they were these flat metal sticks, tapered at the ends with a notch about 1/2" from the end
and a ring on the other end to pull the radio out. They fit exactly into the two slots at the bottom of the radio head unit, and when inserted, pull in the springy metal strips that hold in the radio. They are common tools that many radios use. I think Mercedes uses the exact same shape.
There is a diagram of the "official" VAG radio removal tools in the Bentley repair manual, if you have one.
Old 01-12-2005, 06:12 AM
  #16
SparTTan's Avatar
Default Impex, 46 bucks
<ul><li><a href="http://www.worldimpex.com/search_by_partno.html?searchmode=partno&amp;partno =8N0+941+509+A&amp;x=18&amp;y=8">Hazard relay @ Impex</a></li></ul>
Old 01-12-2005, 06:28 AM
  #17
YosemyTT's Avatar
Default Good job!
I changed one of my seat heater buttons and it is not quite as easy to pull them out as you made it sound :-)
Old 01-12-2005, 06:31 AM
  #18
Elder Member
kodeTT's Avatar
Thanks! nice discount.
Old 01-12-2005, 06:32 AM
  #19
Elder Member
kodeTT's Avatar
Default I thought the TT had 4 clips to remove...2 at top and 2 at the bottom?
didn't know it was just 2.
Old 01-12-2005, 06:35 AM
  #20
Audiboy's Avatar
Great write up! I have radio tools, I'm curious to see if I have that special duct tape strip now
Quick Reply: Blinker relay replacement... Piece of cake
