Getting Adj Control Arms, Anyone Install These?
Old 05-06-2013, 10:42 AM
AudiNut87's Avatar
Default Getting Adj Control Arms, Anyone Install These?
i only bought 1 set, should i install in upper or lower position, or does it really matter? cant wait to get camber back in and stop wearing out my rear tires!
TT/R32 Rear Adjustable Control Arms
JDM
Old 05-06-2013, 03:32 PM
zer0star's Avatar
JDM
Very nice! I'm looking at doing the same soon, so please post and let us know how it turns out!!
That's just for the rears? Is it essentially all we need for a proper camber alignment?
Old 05-07-2013, 05:18 AM
AudiNut87's Avatar
yep its for rears. i was told 1 set for drops up to 3/4", 2 sets for drops more than that. something about alignment of camber and toe for big drops. mine is right at 3/4" drop so they said 1 should be OK. I received them yesterday, man these are stout, not light. each arm probably weighs 4 lbs but they look like they could go through hell and back. i guess you want your suspension parts to be strong rather than weak! love the jazz blue powder coating, too. these will look better than any other mod on the car once i get them installed. just have to figure out if i should put the 1 set on top position or bottom. prob should of just gotten 2 sets.
Old 05-07-2013, 07:53 PM
Former Vendor
MikekiM@PureMS's Avatar
Might I recommend a look at our Stern adjustable arms. They're a great option to consider.
This is the ONLY way to fix your camber in the rear. You need 2 arms for moderate lowering and adjustments, 4 arms if you have a very low car.
Stern Adjustable Control Arms
Old 05-08-2013, 05:35 AM
nilreb's Avatar
http://www.mcpii.com/MadMaxControlArm.html
the best TT control arms around
Old 05-13-2013, 05:16 AM
AudiNut87's Avatar
I have already bought them from www.GruvenParts.com. Very satisfied too.
I did speak with them regarding the parts and they gave me clear instructions on how to install and how many sets are needed.
I got them installed this weekend, alignment perfect now! Couldnt be happier !!
JDM
JDM
Old 05-21-2013, 12:45 PM
AudiNut87's Avatar
Wow these things handle great. Will definitely be ordering more parts from GruvenParts.com
Im also going to grab a set of the adjustable swaybar end links. Once I get more time, glad I found their site.
JDM
Old 06-25-2013, 12:27 PM
AudiNut87's Avatar
So who here auto-x there car? What do you set camber at beforehand?
Old 07-09-2013, 01:26 PM
AudiNut87's Avatar
what camber settings do you guys use for track and auto-x ?
Old 07-10-2013, 10:24 AM
J. Patterson's Avatar
I run - 2.5 degrees front, - 2 degrees rear.
You have to have adjustable camber bushings at the front strut towers in order to get that much though.
Quick Reply: Getting Adj Control Arms, Anyone Install These?
