BREATHER filter fitting for AUDI TT/S3 225bhp BLOCK
If anyone could help me i would appreciate this alot as i have been getting a bit confused.
I Have an Audi S3 which has the Same 1.8T 225bhp Block as the audi TT and i just fitted a new air induction kit to it. However i dont have a clue where the Breather filter connects to!!!
If anyone knows it would help me alot..
Most aftermarket systems....>>
Don't have a connection for the cold start line. You can use a mini-breather if you can find one in a 25mmID, or a Microphone sock. It's pretty non critical....You just need something to keep the bugs out!
<img src="http://images7.fotki.com/v143/photos/7/7305/210318/Coldstartfilter-vi.jpg">
Re: Most aftermarket systems....>>
I see how you have fitted the breather there but thats not the 225bhp block. that looks like the 180bhp where the original airbox has the other tube going in to it where you can fit the breather.
The 225 block does'nt have that. the air box only connects to the Turbo inlet pipe, where the pressure regulator valve for the breather hose also connects!!
?? In the US, they're both the same...
I guess I'm not understanding the question..
The above pic showed a breather filter connected to the hose that comes off the OEM airbox. It's an emissions thing here.
Do you mean this crankcase regulator?
<img src="http://images14.fotki.com/v209/photos/7/7305/2320193/DSC03913-vi.jpg">
Re: ?? In the US, they're both the same...
Yes that the regulator. see in Europe we dont have emission problems. Also if the car has ESP it wouldnt be in the style you have. Thats the old 225 block whcih is also the same as the 210bhp block. that regulator valve is to do with the breather pipe...am i right?
Yes......It is..>>
a Crankcase and PCV breather/regulator that plugs into a port on the Turbo Inlet pipe. All after market Samco or SFS TIP pipes sold here have this fitting port....
ramair induction kit audi 225
Hiya I have recently fitted a ram air induction kit but there is nowhere to put the 25mm breather filter can someone please help its really confusing me .
Regards
Simon
Regards
Simon
Also is it safe just to install the ram air induction kit without tuning the engine ?
So basically I havebtook the old air box out and just connected the induction kit I just thought you needed a breather filter so I brought one but I don't no where to put it ?
RoadsterRandy
TT (Mk2) Discussion
04-02-2008 12:33 PM
Ms TT
11-07-2000 10:43 PM
ObsessTT
02-22-2000 01:56 AM
