Cluster
Spring of 2014 I sent mine to BBA Reman for a rebuild. They did an excellent job.
BBA reman. ABS, ecu's, throttle bodies, air mass meters, MFD and catalytic converters Tel. 1-866-573-2740
I have had two clusters rebuilt by Module Masters this past year, one for my son's 01 A4 and recently for my TT same year. Both fast service and shipping, reliable workmanship. I know there are others out there that will do the same. I chose MM because they are closer to Colorado than some of the others. Previous poster said do a google search, exactly what you should do.
Remove Caliper and carrier. If you see a Phillips Head screw between two of the wheel bolt holes, remove/break it off. Rotor should come right off in a perfect world. If not heat the surface surrounding the wheel bolt holes with a torch for a few minutes and using a 5 or 10# sledge hammer, pound it off. I assume yu are replacing them anyway.
If not, I once had to beat one of the rotors with a sledge and reused it. It showed no marks from the 10# hammer I used on it.
TT will not stay cranked
I replaced the LED screen in the cluster and the Rack and Pinion on it. Now it will role over twice, crank, then turn off. I did this about 6 times. I cannot get it to stay running, I drove it in the shop "No Problems" NEED HELP
