Driver's side door won't open from inside
Old 03-25-2017, 07:51 AM
oj_cee's Avatar
Default Driver's side door won't open from inside
I have a weird thing happening on my 2001 TT Coupe. If the temperature drops below 50-55 degrees the inside door handle doesn't open the door. I have to roll the window down and open it from outside. If I park in the sun or the temp is warmer I have no issues. Any thoughts would be appreciated.
Old 03-26-2017, 05:26 AM
AudiTTinAZ's Avatar
I just took off door panel to replace the door pull. I would simply take off the panel to see if everything is connected correctly. There is a wire to the latch of the door. See if it is working properly. Sounds like the latch in the door is failing. You can find replacements for under $200.
Not sure why temp outside would make much difference - but once you get in there you will know.
PS make sure you take pic of wiring before you disconnect it (I am trying to figure out alarm issue right now - because I didn't take pic of wires in the lower door harness.)
Old 03-26-2017, 05:49 AM
AudiTTinAZ's Avatar
Here is video to remove the door panel.
chancebuttars
01-02-2012 02:34 PM
SCarGo02
13
08-19-2003 01:26 PM
Hip Rider
03-27-2002 02:24 AM
adriangriffin
01-24-2002 01:17 PM
msquared
08-22-2001 05:49 PM
Quick Reply: Driver's side door won't open from inside
