First mod on the 3.2: trunk release button - AudiWorld Forums
Old 10-08-2003, 12:49 AM   #1
New Member
Default First mod on the 3.2: trunk release button
When you put the DSG lever on "Park", the trunk release button (on the right) is much harder to reach than the fuel flap one.
Annoying, when I use the trunk button ten times more than the fuel one. So I swapped them. I know it sounds like a silly mod, but it needed to be done, IMHO.
Plus I have the feeling it added 10 HP and 20 N/m....
Herve is offline   Reply With Quote
Old 10-08-2003, 01:46 AM   #2
now you can call it a 3.Deuce
Horch it is offline   Reply With Quote
Old 10-08-2003, 06:21 AM   #3
Actually...thats practical...
TTinCT is offline   Reply With Quote
Old 10-08-2003, 06:42 AM   #4
New Member
good mod very good mod
Audi Frank is offline   Reply With Quote
Old 10-08-2003, 08:27 AM   #5
Careful that sounds like a warranty voider ;-)
bluwaggen is offline   Reply With Quote
Old 10-08-2003, 11:46 AM   #6
Nice! Any pics or list of procedures?
Marc3.2TT is offline   Reply With Quote
Old 10-09-2003, 01:30 AM   #7
New Member
Default Did not take pics, thought the mod would raise sarcasm not interest :-)
However:
Each button is made of two parts. The "mechanical" and the electrical. Both are clipped and held independently, so you do not end up with 20 different plastic bits.
1) lift up the buttons holder, it is only clipped on the console.
2) Unplug the three connectors. They are all different, so you cannot plug it back the wrong way.
3) First take away the contact mechanism on one button. Gently pry it open with a small flat screwdriver. There is no need to squeeze its four retaining tabs, just a moderate leverage would do the job. Should the electrical contact jump out, not problem since there is only one way to put it back. Repeat for the other button
You now have a button still fitted to the buttons holder, without its electrical parts.
4) The button itself comes out on the other side (upwards if the buttons where still on the center console). Press both its retaining clips on its sides with two flat screwdrivers, then gently push the white rod that comes out, the button will slide out of its cage. Do not loose the spring. Wash, rinse, repeat for the other button.
5) Swap buttons and their respective electrical bits, remember the connectors are different.
Now concentrate and be careful not to put back the same button at the same location. Sounds silly ? I did it, doooh.
Hervé
Old 10-09-2003, 09:00 AM   #8
Default Wow, thanks a lot for the detailed procedure!!!
and don't worry about sarcasm on this forum, just take pictures in your next project ;-)
Merci bcp!
-Marc
Thread Thread Starter Forum Replies Last Post
My trunk is stuck! ChulaaSoYUM Audi 90 / 80 / Coupe quattro / Cabriolet 8 10-27-2015 10:00 AM
2nd round of Mods TSHong A8 / S8 (D3 Platform) Discussion 20 09-22-2015 07:45 PM
Help I'm Trapped And Can't Get Out Irish1004 Audi allroad 2 09-16-2015 04:38 AM
New Member and Fan/Trunk Question raiderrider A8 / S8 (D3 Platform) Discussion 12 09-08-2015 06:46 AM
95 Cabriolet Power Roof Fix. stormchaser1967 Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 0 09-02-2015 10:26 AM
Tags
01, 2002, 2003, 2004, a6, audi, botton, button, cap, gas, part, release, switch, trunk, tt
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
