Fog Lights Always On?
Hi,
I purchased my TT used last summer and it has been my daily driver ever since. When I bought the car, I thought the car didn't have fog lights and the fog switch was unused, because pulling and pushing had no effect on the lights. I decided to do more research, and I found that the TT *does* have fog lights; mine were just always on. The fog lights are on whenever the low beams are:
(Yes, my right parking light is also out. It has nothing to do with this problem.)
and the pull/push switch makes no difference. The fogs go out when I put on the high beams, and they are not on when I have just the parking lights. Pulling out the fog light switch when operating on just parking lights does not turn the fog lights on. Any ideas what might be causing this?
I have the Bentley Publishers manual, and I've been trying to trace my way through the wiring diagrams. I have no idea what part might be suspect, though. Has anything like this happened to any of you?
Thanks,
Nick
Thanks,
Nick
I don't know if this would be your issue, but I had the same problem some time ago. It was due to the under dash being re-installed improperly. As I would turn the headlight switch to on, it was at such an angle that it would pull just enough to turn on the fogs. You may want to remove the cover that covers the light switch and steering column, and test it then to troubleshoot your problem... my 2cents
Hope everything works out for you!
Thanks, I'll check that! (Though that wouldn't prevent the fogs from lighting if I pulled the switch out when the parking lights were on, would it?)
lite switch
Canadian cars have DRL (daytime run lites) while USA cars do not. Sounds like you have a USA switch. There was a Fokti about switch modification at mcphill/audi_stuff/lighting_systems/"foglight switch mod".
...not sure what that has to do with this problem. And where might I find that mod?
Hi,
Thanks,
Nick
Thanks,
Nick
Audi Other FS: 2007 Audi RS4 black/black CCW
ilikeit
01-09-2016 09:24 AM
Audi A8 2005 Audi A8L
Jan_PL_S6
12
11-27-2015 07:27 AM
carl viking
09-05-2015 05:31 AM
