Headlight not working.
Hi. I got a bulb warning light come on. Changed the D2S xenon bulb and still nothing. Swapped over the bulb from the other side and still no go. Has anyone come across this fault before and maybe found a solution?? Many thanks.
It's either wiring or the ballast. Have to inspect and if you see no obvious wiring issue, swap the ballasts side to side and see if that solves. Some pictures of the assemblies in the link below showing where the ballasts are.
https://www.audiworld.com/forums/tt-...light-2897403/
Ta. Is the ballast the metal box attached to the headlight unit with the lightning sticker. Also, i assume i have to remove the car's front panel?? Appreciate your help.
I then noticed the insulation on the wires internal to the headlight assembly were cracked and missing in places. In order to make sure there were no internal shorts I baked the housings to open them up and wrapped all of the damaged wires in electrical tape. Now all of the lights behave. Hope you find an easier fix!
Thanks for your help guys. It all went swimmingly until i discovered the last two screws holding the front panel on. They were between the outer wing and the inner so a small gap.Very corroded and would not shift. Ended cutting the heads off with a hacksaw blade held with a rag. Took over an hour to get them both!!. Swapped ballasts but no go. I was thinking of way to get into the headlight unit and even contemplated cutting an inspection hole in it's base with a hole saw. Decided against incase i made matters worse! I noticed if i played about with the 2 wires coming from the bulb holder it would work so, obviously a bad connection. I loosened them from the metal clip that holds them and pulled them tight and clipped them in again like that. That was 2 weeks ago and still working fine. Time will tell!! Not a job for the faint hearted but not really difficult either. I'm intrigued about "baking" the units open rriicckk?? Again, thank you guys for your hints and help. Always much appreciated.
Gettysburg
08-30-2006 11:14 AM
