HELP!! Gas tank cover won't pop open and I'm almost out of fuel!!!
Old 01-24-2003, 06:35 AM
Sue EsponTTe's Avatar
Default HELP!! Gas tank cover won't pop open and I'm almost out of fuel!!!
I can hear the mechanism move when I depress the release button, and I've tried popping it open manually through the trunk but neither operation has worked!
Any thoughts? It's so cold that I think something may have frozen it shut, and I've been working so much lately that I haven't had a chance to deal with the problem during the day. Do you think warm water might do the trick?
I hope everyone here is doing well!
-Eric
Old 01-24-2003, 06:37 AM
Junior Member
JaminTT's Avatar
Blow dryer/heat gun next to the catch? If your in the cold snap area I would stay away from water
Old 01-24-2003, 06:38 AM
RoninTT's Avatar
HOT water will probably do it. A hairdrier might also work.
Old 01-24-2003, 06:43 AM
AkRascal's Avatar
Default They do freeze shut, if you have de-icer trickle a little along the seam being careful to wipe off
paint. Dryer is a good idea if available.
Old 01-24-2003, 06:52 AM
Elder Member
Larrytt's Avatar
I always just punched the lid with a gloved hand and it opened every time.
Old 01-24-2003, 07:06 AM
Elder Member
Lone Starr (Ivan)'s Avatar
Be careful with hot water as if the ambient temp is very low it will just freeze, too.
Old 01-24-2003, 07:11 AM
Elder Member
GuilTTy's Avatar
Ask Kim to sit on it. He's very hot.
Old 01-24-2003, 07:13 AM
42N8 TT's Avatar
Default Single malt scotch.
Pour a little around the edge of the cap and voila! Open cap.
Of course, you can't drive for an hour after that 'cause your TT is "under the influence," but it's a small price to pay.
Other high-alcoholic content beverages will work, but personally, if I won't drink it, the car doesn't drink it
Old 01-24-2003, 07:26 AM
Default Yeah, I realized that a few seconds after I typed it...
It might loosen the lock but then it would probably just refreeze it. Hey, at this point I just want to get a full tank of gas in the car.
-Eric
Old 01-24-2003, 07:27 AM
Elder Member
I think this or 70%+rubbing alcohol are good ideas.
Quick Reply: HELP!! Gas tank cover won't pop open and I'm almost out of fuel!!!
