How much should it cost to replace a front lower control arm bushing?
Bushing? You should probably replace all 4
I'd suspect a couple hours per side.....
<img src="http://img.photobucket.com/albums/v323/type89q/bushings/bush6.jpg"><ul><li><a href="http://photobucket.com/albums/v323/type89q/bushings/">http://photobucket.com/albums/v323/type89q/bushings/</a</li></ul>
Stealer tech buddy once told me they get....
3.5 hours PER SIDE on an A4/A6 to do upper control arms. I can do BOTH sides in 2 hours total without really pressing myself. As I'm sure he can... but doesn't change the fact they bill out 7 hours. I'm obviously in the wrong line of work.
Depends on how they take it apart...>
Even unbolting the 3 lower ball joint bolts it could be put back in the previous spot.....But I think if I had my arms removed by some dealer hackers I'd want that to be checked/corrected on re-assembly..
