Mk1 TT door Panel upper edge Repair?
Hi folks, my name is Dirk and have had my '01 TT roadster since 2005. Having moved to FL 3 years ago , the door panel upper edges started peeling up along the windows. This is due to the vinyl shrinking in the heat and pulling on the underlying plastic inner panel. The inner panel plastic is cracked to pieces along the upper edge. Has anyone attempted to repair this with say strips of aluminum and epoxy or any other practical way? Cannot find anything anywhere using search. Upholsterers won't touch it and Audi no longer makes these since 2012. Interior is baseball amber.
about those door panel edges...
Dr Dave
Wow, what a PITA. I just went through this. There are plastic “rails” for lack of a better term that are under the top edge of the door panel, where the black vinyl (at least in my case black) wraps over the edge of the door panel. The vinyl is glued to the rails. But the rails are what came loose to allow the vinyl to begin dragging on the window. I had to remove the door panels from the car, re-glue what vinyl had come loose back down, clean off ALL of the old glue from the rails and door, and use Gorilla Glue and clamps to glue the rails back into position on the door panels. I did this about two months ago and so far they’re still holding. You’ll want to take your time with this and do it right. It bears repeating, be sure and clean off ALL of the old glue between the rails and door panel. The rails have to sit flush against the door panel in the proper position or you’ll have gaps that the glue won’t fill and not have full contact with both the rail and door panel. I found out the hard way if you half a$$ this part of the deal you’ll end up doing it again.
Garrett Roberts (06-10-2020)
possible soultion
The following 5 users liked this post by RussellRR:
cazanova (05-11-2021),
das2.7t (06-10-2023),
Garrett Roberts (06-10-2020),
jjt1234 (01-10-2021),
SARASOTA TT (08-20-2021)
Thank You! Elegant Solution
Every TT will eventually have this problem. The easiest and cheapest solution that will take about 1-2 hours is the following. What I did was remove the door panel and separate that plastic strip at the top of the panel that slides over the door frame. It is likely not in good shape - cracked, pieces missing etc. Use a tiny screwdriver and scrape ALL the GLUE out of it. Use acetone to continue to get the glue out until there is NON left. Like I said about an hour. Be sure to clean the door panel side as well. Next buy black door guards. They are plastic strips that go on the door edge that prevents your door edge from chipping. Do an Amazon search on "car door trim guard" they are 11$. On the door panel use the door guard strip to press over the edge at the top and hold the panel vinyl cover in place. It might be hard to use a single piece of the door guard to do this the whole way - if so use pieces of it. put it all back together - it will look good, hold forever, not be seen and no more glue - easy and cheep solution. Good luck
BarbaraSteele (06-16-2020)
I registered on this forum just so I could say THANK YOU!!!!!
I have searched forever for a solution for this issue!
My husband wanted to give up and get another door panel, but I reminded him that the same issue would occur on another panel,
so it was best to fix the one we have. (We have had several VAG vehicles over the years, so we have had to get a bit crafty sometimes!)
It is in very nice shape besides the top trim and all the goo leaking out!
Fixing this will make a nice Father’s Day surprise.
May your kindness in sharing your hack come back to you tenfold!
It's trash. I screwed with this crap for like two years, then I just bought a new set of door cards, painted them and they look great now. You can't fix it. I tried for years to do it and failed.
You mean this problem?! On my to-do list this week.
Can anyone recommend which trim guard works for them? I did the Amazon search and got 8,000 products. Obviously I can filter that down a lot, but in general some are extruded rubber/plastic, some are molded over a metal core, some have an adhesive strip to hold them in place, there are a variety of heights and widths, etc. Some example pics:
