MY RADIATOR FAN WONT TURN ON HELP ?? MK1 2000 TT - AudiWorld Forums
Old 03-21-2014, 10:30 PM   #1
Default MY RADIATOR FAN WONT TURN ON HELP ?? MK1 2000 TT
Hey guys i need some help, i just put a brand new radiator fan into my car but i was really dissapointed when i found out it wasn't coming on ? has anyone had this problem before . Why doenst my fan come on please help ?
fabian5367 is offline   Reply With Quote
Old 03-23-2014, 05:26 AM   #2
Mister Bally's Avatar
Quote:
Did your old fans also not come on or are you replacing because they are were out of balance or making noise? If the old ones spun, your new ones are defective or the wrong part. Many times aftermarket ones are procured that are low in cost which means low quality or not compatible. If connectors were the ame (not hard wired, return to the supplier and buy a used one from a junkyard or new from a dealer (It's gonna cost you).
If the old ones didn't work and neither do the new ones, The control relay(s) may be bad or a fusible link above the battery or a wire junction may be bad. A wiring diagram from the Bentley CDRom and general automotive troubleshooting techniques are required.
There are two ways to get the fans to run.
1. hot motor/colling system.
2. Air Conditioner (in good, working order) running with ambient temperature above 42F / 6C.
Try not to type in all Capital letters. A lot of us usually ignore subjects written that way. New posters get a break though
Mister Bally is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
PARTING OUT 2002 A4 B6 1.8T Cmmartin23 Parts For Sale 26 08-23-2016 05:44 PM
The Daily Build..My S6, the story and the questions vwleadfoot Audi Original "S" Cars 4 12-24-2015 07:07 AM
temperature dependent O2 sensor iowaan A6 / S6 (C5 Platform) Discussion 17 09-25-2015 02:38 PM
09 Audi A5 A/C and Heat Problem Advice Needed abpuma Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 1 09-17-2015 12:39 PM
Need help finding A/C Low Pressure Valve Port TrailAgent Audi 4000 / Coupe GT Discussion 0 09-06-2015 01:15 PM
Tags
2006, a4, audi, colling, fan, test
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
