Coolant Temp Sensor
Old 01-21-2014, 07:56 AM
Endless0110's Avatar
Default Coolant Temp Sensor
Hi all,
Looks like my first post will be regarding an issue with my TT.
My temperature gauge wildly over reads, and I've checked it with the 49C trick to make sure this is the case.
My question is, if the coolant temp sensor is faulty, would I still be getting correct readings using the 49C trick?
Thanks
Old 02-20-2014, 10:14 AM
Jsmedtx's Avatar
I don't know about the 49c trick but I had to replace my sensor. Pretty easy and only around 10 bucks
Old 03-13-2014, 04:29 PM
Pinot007's Avatar
Yeah, sorry I don't have the answer to this but would love to know the outcome.. i also use the 49c to check and a few other things as well, nice hidden feature.
Originally Posted by Endless0110
Hi all,
Thanks
Old 03-21-2014, 06:29 AM
germanautos's Avatar
I have a similar issue on my 01 tt quattro where the temp gauge is reading high. with the 49C trick, i can see that the dash cluster is about 20 too high. Usually if the temp on the gauge is more than 10 degrees different than your heater control readout then it's a gauge problem, but then usually the fuel gauge reads too high as well (in my experience anyways). You can always run the car with the coolant reserve open and use a thermometer in there to see if that agrees with the gauges.
Old 03-27-2014, 04:51 PM
AudiMick's Avatar
There are known problems with the clusters on TTs. The fuel and temp gauges read wrong usually high.It's due to the needle moving on the shaft.
Check the cluster with a VAG.com for accuracy before you start swapping stuff.
00blackS4
11
01-28-2008 05:04 PM
00blackS4
13
01-16-2008 12:34 PM
eldoj
05-08-2007 07:01 AM
CoupeDude
Pacific Northwest Discussion
02-21-2005 06:08 AM
plexxx
02-04-2002 04:21 PM
Quick Reply: Coolant Temp Sensor
