OBD II Diagnostic Port Blowing Fuses - AudiWorld Forums
Old 05-04-2012, 06:20 PM   #1
Default OBD II Diagnostic Port Blowing Fuses
I have a CEL.on my 2001 TT 1.8T 225 Coupe and ironically (and perhaps related?) the diagnostic port has stopped working and is blowing its fuse. before I bring it to the dealership I thought I'd ask the experts here if they had seen this before.
I read on another forum that the black (vs the blue) colour connector is prone to the pins being pushed back into its housing. Is it possible that the lead that powers the port has shorted with one of the others?
The car is new to me, but has had no electronics mods.
eric_stewart is offline   Reply With Quote
Old 09-19-2012, 06:58 AM   #2
Default OBD II Diagnostic port
Did you have any luck with this problem, I'm getting a " unable to connect " when I attach a code reader to the plug . it looks like it might be the same problem. Also, does the code reader plug have a fuse in line with it ? I asked a dealer that question and they said that there was no fuse.
skylordd is offline   Reply With Quote
Old 09-19-2012, 08:21 AM   #3
Quote:
The dealership wired a bypass to the diagnostic port instead of troubleshooting exactly where the break was as it was going to be very difficult to locate.. This saved a lot of $$ and it works absolutely ok now. They only charged an hour labour.
Old 09-19-2012, 10:56 AM   #4
AudiMick's Avatar
Make sure you don't have an aftermarket radio, many of the harnesses are wired incorrectly and connect 12 volt to the K-line which messes things up.
Check Ross-tech's site (aftermarket radio problem) for how to fix it.
The other two modules that will block a connection are the cluster and the ABS controller.
AudiMick is offline   Reply With Quote
Old 09-19-2012, 02:38 PM   #5
Mine has the factory radio .
Old 09-20-2012, 06:47 AM   #6
AudiMick's Avatar
Unplug ABS and cluster, try it again.
Thread Thread Starter Forum Replies Last Post
Power window issue fluidparkour75 TT (Mk1) Discussion 3 10-16-2015 04:57 PM
Who has Carista App for their B8? Chigger S4 (B8 Platform) Discussion 11 10-07-2015 03:03 PM
1997 A8 Quattro wont Crank gorkyc A8 / S8 (D2 Platform) Discussion 7 10-04-2015 08:00 PM
Horn doesn't work!!! arn560 S4 (B8 Platform) Discussion 1 10-02-2015 07:31 PM
Question about fuses, cruise control and steering wheel havocgb A6 / S6 (C5 Platform) Discussion 5 09-25-2015 05:50 PM
Tags
1998, a4, a5, a6, audi, board, diagnostic, diagnostics, fuse, ii, obd, obd2, port, rs, system, tt
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
