Passenger Window Erratic Closing
Hi peeps,
First time here and thought I'd see if anyone can help!
I have an Audi TT 1.8 2005 model. The passenger side window opens fine, but is having problems closing.
When I first tried to close the window, it wasn't closing at all, I did the reset thing that others have mentioned (turn on the ignition, open windows all the way, close them, then hold the switches in closed position for 5s, and turning off the ignition).
Now what's happening is that the window is closing, but it stops in 2 places on the way up. Each time I have to let go of the switch and hold again to make it go to up. The window stops in exactly the same positions each time too.
This happens if I use the window switches (driver side and passenger side) and also when I do it from the key in the door.
I have lubricated the window 'channels', thinking it might be some friction, but this doesn't help.
If I pull the window by hand as it's closing it goes all the way up (I did this as a test to se if it would work).
So, there's something that's causing it to stop at those points, but not sure what!
Any pointers / help most appreciated!
(As a side note, the window does drop slightly, when the door is opened, and goes back up when closed, which is normal - thought I'd mention in case it's relevant)
Cheers,
Taz
Cheers,
Taz
I'll be interested to hear from others on this, I am having the same symptoms from my drivers window. I am guessing the regulator. Like you I pulled the door card off, and lubed up the channels to no avail.
check the bentley paper manual, which of course I can't find right now. It's not the standard up down hold button thing, it's a process to readjust the pinch mechanism, uses a piece of wood to stop the upward movement to reset it.
believeryes
12-11-2017 09:36 AM
sharkaTT
NY / NJ / CT Discussion
06-13-2008 10:48 AM
