Passenger window won't go down?
Old 01-18-2009, 04:58 PM
New Member
Inimical's Avatar
Default Passenger window won't go down?
Hey guys, for some stupid reason my passenger side window refuses to go down either by the switch or when you pop open the door.
When I hit the switch to put the window down I can hear the relay click like it's trying to, but nothing happens. I'll probably take the door panel off tomorrow to check and make sure it's not just a loose connection.
Any other tips? I don't think this is a known issue I searched around.
Old 01-18-2009, 05:02 PM
ellipsis's Avatar
Default Re: Passenger window won't go down?
Have you try to reset the windows? hold the switches up - release - push up again and hold it for 5 sec.
Old 01-18-2009, 05:12 PM
New Member
Inimical's Avatar
First thing I tried.... no go.
Old 01-19-2009, 05:06 AM
Member
TTGram's Avatar
Had to replace the window motor on mine.
Old 01-19-2009, 06:25 AM
New Member
Inimical's Avatar
How much did that run you?
Old 01-19-2009, 07:45 AM
Junior Member
gregt's Avatar
Default going to be doing mine in a couple weeks ...
$225, haven't ordered it yet<ul><li><a href="http://www.genuinevwaudiparts.com/partlocator/index.cfm?action=getJointLocator&amp;siteid=214407 &amp;chapter=&amp;sectionids=3,2413&amp;groupid=10 005&amp;subgroupid=20044&amp;componentid=62135&amp ;make=2&amp;model=TT&amp;year=2002&am
Old 01-19-2009, 08:02 AM
New Member
Inimical's Avatar
ouch... thanks for the link! Nice color btw
Old 01-19-2009, 02:51 PM
New Member
Inimical's Avatar
If anyone needs it, the Part# for the Right side window motor is 8N8 959 802
Old 03-13-2017, 02:44 PM
Jamie Campbell's Avatar
Default Did you ma
did u manage to resolve this, I have the exact same issue with mine
Old 03-13-2017, 04:03 PM
Mister Bally's Avatar
You could have a broken wire in the pivot point (hinge area) or a break/open circuit somewhere else. A proper diagnostic scan, using the Ross-Tech cable or genuine VW/Audi diagnostic tool is basically mandatory for troubleshooting this. Or, using the vehicle wiring diagram, verify fuse/fusible link/circuit breaker output voltage.
Standard automotive electrical system troubleshooting techniques apply.
heinzboy57
12-02-2008 02:51 PM
Enivel A4
Florida Discussion
06-30-2007 06:48 PM
DRAGON88
10-31-2005 02:36 PM
Badd TT Bone
03-03-2005 05:46 AM
Quick Reply: Passenger window won't go down?
