Possible to remove radio without keys? - AudiWorld Forums
Old 03-14-2007, 03:41 AM   #1
New Member
Default Possible to remove radio without keys?
My flasher relay is dead. I have a new one and I am ready to put it in. However somewhere along the line the headunit in my car has been subject to some unholy abuse or 'shadetree mechainc' and the radio relase tabs are effed. I spent an hour at a local stereo shop trying without sucess to release the headunit with the "official radio removal tool" directly from Audi...
Is there another way to get this out? At this point I don't even care if I have to destroy the factory headunit. But before I do I would at least like to know that if it comes to that, I will be able to remove it. I don't relish the idea of a broken headunit that is also permanantly stuck...
I need turn signals more than I need a radio...help please.
peruski is offline   Reply With Quote
Old 03-14-2007, 03:52 AM   #2
Member
Default I had trouble getting mine out after I knocked one of the release tabs out of alignment.
I would get two thin 1/8" steel strips(so they don't bend too much), cut them as they are on Jeff's DIY radio tool writeup. See if you can torque them hard enough (pushing both makeshift tools away from the headunit so the tips press inwards onto the hu) to get some friction while you pull. This will probably be a huge pita, but if you get it to budge at all, keep at it and you'll get it eventually. I wrestled with mine for 20 or 30 minutes before it gave way.
ttrut is offline   Reply With Quote
Old 03-14-2007, 03:53 AM   #3
Member
Default And here's the link to Jeff's TT site.
<ul><li><a href="http://www.loomknitting.com/auditt/">http://www.loomknitting.com/auditt/</a</li></ul>
Old 03-14-2007, 04:58 AM   #4
Default I had the same problem recently...
Thought my release tabs were screwed up. I tried yanking inward with tools I purchased off eBay.
TTuned is offline   Reply With Quote
Old 03-14-2007, 06:38 AM   #5
Default you can try to take off all the center console craps and then press the tabs on the side to release
the HU. are you sure 100% sure that you're using the keys correctly. Also if this is your first time pulling the HU, you might have to apply a little bit of force. my stubborn HU was putting up a fight for about 2 hours but i finally got it out. my fingers hurt like hell but i come out on top
good luck
Jake
Cruzad3r is offline   Reply With Quote
Old 03-14-2007, 06:59 AM   #6
Guest
Default I took my lower dash out and was able to push the radio out from the back
then again, my arms are pretty scrawny and also ended up finding every piece of sharp, unprotected piece of metal while I was back there, but it worked.
I used Jeff's writeup to make some tools with a pair of wire cutters. I had similar problems with one of the tabs on the radio where it wouldn't respond to the tool.
TTempted is offline   Reply With Quote
Old 03-14-2007, 07:29 AM   #7
Senior Member
Default If you can get a pick or a hook of some sort in the CD/Cassette door and help pull it may help.
Had to do that on mine, needed some extra persuasion.
TT_Nuge is offline   Reply With Quote
Old 03-14-2007, 11:32 AM   #8
TTransport's Avatar
Default Stop by the stealer and ask them if they will unseat it for you.
Drive it home with the radion hangin out by 1/2" and then do your work.
If you've got a good dealer they'll take care of you for no charge.
TTransport is offline   Reply With Quote
Old 03-14-2007, 01:19 PM   #9
I've had Circuit City pop it for me a couple times for free. Now I have the keys.
Seneb is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
:: ECS Tuning :: NEW!! B8 A4 2.0T ECS Baffled Oil Catch Can ECS Tuning-Audi A4 (B8 Platform) Discussion 14 12-23-2016 04:46 AM
Adding bluetooth audio to my new (to me) 2009 Cabriolet with Bose xkahn A4 Cabriolet (B6 Platform) Discussion 3 08-07-2016 06:38 PM
DIY Remote start Q5 IntheQ5 Q5/SQ5 MKI (8R) Discussion 27 06-09-2016 01:37 PM
:: ECS Tuning :: NEW!! B7 A4 2.0T ECS Baffled Oil Catch Can ECS Tuning-Audi A4 (B7 Platform) Discussion 0 09-01-2015 10:16 AM
:: ECS Tuning :: NEW!! B8 A5 2.0T ECS Baffled Oil Catch Can ECS Tuning-Audi Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 0 09-01-2015 09:27 AM
Tags
01, a4, a6, audi, b5, head, key, keys, radio, removal, remove, s4, stereo, tt, unit
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
