Power window issue
Power window issue
Hello, I recently bought a 2001 Audi TT 6 speed 225HP. I bought is knowing both windows didn't work so I was prepared to do some digging into them. Here is what I have got so far; 1) There is power at the motors at the red/green and the black when the key is turned 2) There is no power at either switch (I assume there should be though?) but the switch tests fine with a continuity test. 3) All the fuses and relays are good including the thermal fuse 4) I have pulled the ccm and inspected it and it doesn't seem to have any corrosion or dry solders. I have the wire diagram and saw that several wires ran through here so thought it would be good to check it. 5) I do not know if the motors are good because I don't know how to test them, can they be tested outside the car or anything?
Also other symptoms that I've noticed include, Center dome lights don'r work at all but the bulbs and fuses are good and the fuel and temp gauges are erroneous. Figure I mise well list these too incase they correlate.
Any help would be greatly appreciated!
Sorry I cannot really provide any insight into the window issue. I would rely on others with better electrical trouble shooting experience. Seems like you covered a lot of the obvious.
There has to be a way to apply 12 volts to the window motors themselves to see if the motors are bad, two of them being bad seems like too much of a coincidence though. On my '85 5000s, the cable runs between the door and chassis were bad, insulation on the wiring had failed from movement, pull the boots and examine that too. Actually I've seen the same on several cars I have had, '97 A6 wagon, the rear hatch wiring harness, same frayed insulation, resulting in a dead short, same on a 2002 volvo wagon. So its worth a look.
I will continue to give some thought to the electric troubles.
Hi im having issues with my 2004 Audi A8 both of my front suspensions drop just 2” off the ground I change the compressor a webco bread and nothing happened can it be my relay me replacement the whole time?
ECS Tuning-Audi
Q5/SQ5 MKI (8R) Discussion
11
02-24-2023 12:58 AM
stormchaser1967
09-02-2015 09:26 AM
stormchaser1967
09-02-2015 09:02 AM
stormchaser1967
New Member Welcome Area
09-01-2015 01:29 PM
