Problem passing smog in CA - AudiWorld Forums
Old 03-22-2014, 11:51 PM   #1
Default Problem passing smog in CA
My 2001 tt will not send communicate with the smog machine. Has anyone had his problem or know of a fix for it? I need to get it smogged so I can register it.
Thanks
Mikaere808 is offline   Reply With Quote
Old 03-23-2014, 05:15 AM   #2
Mister Bally's Avatar
Quote:
Thanks
Get your hands on a wiring diagram (Bentley manual on CD) and trace the wiring from the diagnostic port to the main ECU as well as 12 volt & ground lines. Probably a break somewhere or a bad ECU communication circuit.
A good shop visit would probably be best but someone could have disconnected or cut something which is easy to diagnose using standard automotive electrical troubleshooting techniques.
Mister Bally is offline   Reply With Quote
Old 03-23-2014, 11:51 PM   #3
I was also told because the battery died that it reset the ECU. And that I need to drive it for awhile at 55mph or above to get the ECU working again. Is that true? Hopefully that's true cause that will be a much cheaper fix than taking it to a shop.
Old 03-27-2014, 05:47 PM   #4
AudiMick's Avatar
Nothing to do with the battery, you may need to drive it to get readiness codes but the scanner should still work.
Do you have an aftermarket radio?
There's a problem with some harnesses shorting the K-line to 12 volt. It will block communications.
The other common failures that block the K-line are the cluster, ABS module and comfort / alarm module. Unplug them one at a time to find the culprit.
AudiMick is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
P2181...help. No help from Audizine A4 Lemon A4 (B7 Platform) Discussion 3 10-02-2015 10:57 AM
ATTN D3 A8 Owners:OEM AMI Bluetooth Adapters Located! milellie111 A8 / S8 (D3 Platform) Discussion 18 09-19-2015 08:22 AM
Simple question re: oil consumption test. I think dealer is screwing me. audiinnj A4 (B8 Platform) Discussion 6 09-17-2015 09:37 PM
Audi Other Nogaro 2001.5 S4, Tial 605 GT, 6spd in Orange County, CA S4intheOC Vehicles For Sale 0 09-08-2015 01:12 AM
September 13th Sunday - Touge.ca Cayuga TMP track event 5-9pm! #18 of 20+ Events Touge.ca Canadian Discussion 0 09-02-2015 02:30 AM
Tags
audi, check, common, problems, smog
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
