Tech Article- Hardwiring a Valentine 1 (V1) in a TT -Long - AudiWorld Forums
Old 09-03-2002, 04:25 AM   #1
AnTT's Avatar
Default Tech Article- Hardwiring a Valentine 1 (V1) in a TT -Long
The V1 comes complete with a hardwire install kit, but for ease of installation and to cause no permanent changes to the vehicle's wires follow this article's advice. You need a few extra parts that do NOT come with the V1 in order to easily hardwire it in your TT. It won't set you back much, Radio Shack will have everything that you need for less than $4. Here is a list of the tools needed and extra accessories to purchase.
T-25 Torx screwdriver or bit
Flathead screwdriver
Wire stripper
Wire tie or Velcro strap
Needlenose pliers or crimping pliers
1 Package of Automotive Blade-Type Fuse Taps Part # 27-1204
1 Package of Female crimp on quick connect Part # 64-4039
<img src="http://pictureposter.audiworld.com/38950/1blade_tap_box.jpg">
<img src="http://pictureposter.audiworld.com/38950/3tap_and_female_quickconnect.jpg">
Take out the hardwire parts from the V1 and locate the direct power wire (it is red and will have a male spade end with an insulation cap over it). Cut the male end off of the wire and set aside.
<img src="http://pictureposter.audiworld.com/38950/2directwire_set.jpg">
Prepare the wire by stripping off of an inch of insulation and twisting it. Now take the Female quick connect that you just purchased and slide the twisted wire into the female quick connect until it is all the way in (wire insulation up butted against the female connector). Slide the blue insulation piece (from the female quick connect) down the red wire to expose the metal. Crimp the metal to secure the wire and slide the blue insulation piece back over the crimped area.
<img src="http://pictureposter.audiworld.com/38950/4female_crimped.jpg">
You are now ready to go to the car and begin the actual installation!
Open the fuse door panel (using a flat edge screwdriver-be careful not to scratch) and slide the panel out. You will now see all of the fuses. You want to connect the V1 to a switched power source so it will go on only when the car is on and turns off when it is off! I chose to use the blower fuse which is # 24 on the fuse chart.
<img src="http://pictureposter.audiworld.com/38950/24_fuse.jpg">
Using the fuse puller (see picture) pull out #24.
Take out the Fuse taps that you purchased now.
<img src="http://pictureposter.audiworld.com/38950/5fuse_tap.jpg">
<img src="http://pictureposter.audiworld.com/38950/6tap_topview.jpg">
The fuse taps are ingenious and allow you connect an additional accessory to a single fuse. You simply slide the smaller end of the fuse tap over the hot side of the fuse (the left side of the fuse in the TT) and clip the tap into place.
<img src="http://pictureposter.audiworld.com/38950/7tap_slideon.jpg">
<img src="http://pictureposter.audiworld.com/38950/8tap_on_sideways.jpg">
<img src="http://pictureposter.audiworld.com/38950/9tap_connected_fuse.jpg">
Now you can push the fuse (using the fuse puller) back into the slot where it came from. It will be a bit more snug with the tap attached, but with a slight push it will go in. Make sure that the fuse is fully seated and that the tap is still sticking directly out
<img src="http://pictureposter.audiworld.com/38950/10push_fuse.jpg">
Now you can connect the direct power cord that you modified to the fuse tap.
<img src="http://pictureposter.audiworld.com/38950/11connect_female.jpg">
<img src="http://pictureposter.audiworld.com/38950/12connect_direct_cord.jpg">
Next you need to ground the power. The top bolt directly next to the fuse puller is grounded and works perfectly.
<img src="http://pictureposter.audiworld.com/38950/13ground_connection.jpg">
You need a T-25 Torx screwdriver or bit to loosen the bolt. After you loosen the bolt you slide the ground wire prong under the bolt but on top of the washer. Hold it horizontally where the prong points are facing the rear of the vehicle. While holding the wire, slowly tighten the bolt back and bend the prongs to fit between the bolt and washer.
<img src="http://pictureposter.audiworld.com/38950/14connect_ground.jpg">
At this point your connection to the vehicle is complete. Test the V1 by connecting the RJ-11 plug from the detector to the hardwire power adapter. Note: it should be easy to hide the V1's cable along the headliner and down the a-frame, which will lead directly to the fuse box. Turn the vehicle's ignition to the on position but there is no need to start the vehicle. The V1 should turn on and go through its self-check mode if all the connections are secure.
After the test, secure all wires neatly using either an insulated wire tie or a Velcro band.
<img src="http://pictureposter.audiworld.com/38950/15wire_wrapup.jpg">
The fuse box is recessed enough that you should be able to tuck them in without too much trouble. Take the fuse panel door and slide it gently back in between the A-frame and position over the fuse box latch holes.
<img src="http://pictureposter.audiworld.com/38950/16closing_fuse_panel.jpg">
Once the pins are lined up push the wires inward toward the fuses and close the fuse panel door completely by applying pressure on the area where the three pins are located.
<img src="http://pictureposter.audiworld.com/38950/17closed_panel.jpg">
You're done! Drive safely!
AnTT is offline   Reply With Quote
Old 09-03-2002, 04:29 AM   #2
Member
Awesome - Thanks
seaTTym is offline   Reply With Quote
Old 09-03-2002, 04:46 AM   #3
Default Great write up, but there's no need for the fuse tap...
The male spade for the power slides right into the slot for the telephone fuse (I forget which one it is - it's labelled though) - no need for the fuse blade adapter. Wire the ground per your install and you're done, install cost $0.00...
BillK is offline   Reply With Quote
Old 09-03-2002, 05:49 AM   #4
Elder Member
Great doco. Now, about that manicure....
Lone Starr (Ivan) is offline   Reply With Quote
Old 09-03-2002, 06:24 AM   #5
Great...I could have used this a few months ago
SparTTan is offline   Reply With Quote
Old 09-03-2002, 06:50 AM   #6
AnTT's Avatar
But if you have the phone hook-up you need that fuse also!
Old 09-03-2002, 06:51 AM   #7
AnTT's Avatar
Be nice...working on the car hurts the curticles too often!
Old 09-03-2002, 07:39 AM   #8
Tron (///M)'s Avatar
That is an extremely clean install. Thanks very much for that write up.
Tron (///M) is offline   Reply With Quote
Old 09-03-2002, 08:14 AM   #9
Senior Member
Excellent - very neat - will have to re-do mine now - thanks again
TTigg is offline   Reply With Quote
Old 09-03-2002, 08:36 AM   #10
Default Or, alternately, hire Jeff Bipes to do it for you at TT East! Easiest by far!
Worked great on my 16 hours driving last weekend -- saved me at least 3 tickets (or, saved me 2 hours, without it would have driven slower, perhaps avoiding tickets).
JoTT is offline   Reply With Quote
Tags
1998, 2012, 90, 95, a6, audi, box, cayman, diagram, fuse, hardwire, install, map, porsche, quattro, tt, valentine
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
