Tranni problem
Old 10-03-2015, 10:17 PM
unknownjenkins's Avatar
Default Tranni problem
so i i think i blew my tranni but not sure what it could be. so what happened was is i was a t light in neutral and then pushed the clutch in i moved the shifter to 1st gear then let it out and i let the clutch out like normal which would be slow enough to not burn the clutch up but yet slow enough for it to properly grab. then i hear a couple of bangs and then its now stuck in first and i can freely move the shifter to any gear slot including reverse. when the car moves it makes a grinding noise.
1st question is what could have happened?
2nd question is it possible to look inside the tranni without removing it from the car?
Old 10-05-2015, 05:06 AM
lyleswk's Avatar
Probably clutch coming apart. And no, you can't figure it out without removing the tranny. How many miles?
Old 10-05-2015, 07:07 AM
Approximately 145000
Old 10-05-2015, 07:09 AM
But I can still engage and disengage the clutch with no problem.
Old 10-05-2015, 07:10 AM
lyleswk's Avatar
That's a lot of miles if it is the same clutch. Take to a reputable shop with experience on VW / Audi...
awdinut
32
09-03-2016 04:38 PM
ricka057
09-16-2015 09:42 AM
Markilepsy
S4 (B8 Platform) Discussion
09-15-2015 05:04 PM
RTnDL
09-07-2015 11:17 AM
kclee1st
09-05-2015 09:35 PM
Quick Reply: Tranni problem
