TT Adjustable Rear Control Arms
#11
TT/R32 Rear Adjustable Control Arms
Got a lowered TT or R32 ? Then you already know how the camber and toe become completely out of sorts, causing poor handling and expensive tire wear the more its lowered. Don't fret, GruvenParts.com has your solution.
We are proud to release these adjustable upper and lower rear control arms made from indestructible 4340 aircraft steel tubing. These high quality arms include Teflon lined heim joints and bulletproof welds with optional super durable dust boots for extreme environments! Each control arm provides up to 2 FULL INCHES of adjustment ON THE CAR (does not require removal for adjustment of both camber and toe).
We know the economy is tough right now, so we are offering these at prices well under our competition. Buy 2 sets and save !!!
This product fits Audi TT (2001-2006), Audi A3/S3, VW R32 (2004), VW Golf 4motion and 4motion Variant, VW Bora 4motion and 4motion Variant and replaces P/N 1J0-505-323L (1J0505323L) and 1J0-505-323N (1J0505323N).
Want further discounts and more great products from GruvenParts.com? Read on!
TT/R32 Rear Adjustable Sway Bar End Linkages
Got a lowered TT or R32 ? Then you need to be able to adjust your rear stabilizer bar end links to ensure the linkages ride perpendicular to the swaybar and correct the less than ideal handling typical of lowered set ups. The factory set up does not provide any adjustability in the swaybar end links but GruvenParts.com has you covered!
Our adjustable end links are made from aerospace grade 6061-T651 aluminum hex and feature 2 full inches of adjustment ON THE CAR. This makes for very quick and easy length adjustment on both the top and bottom of the linkage to completely fine tune just about any suspension set up. Our linkages utilize high quality greaseable heim joints for many years of smooth and quiet operation. While we recommend using our fully adjustable rear control arms, you can install these end links without them. The main body is show quality powder coated jazz blue to match our control arms, and like all of our parts they are made right here in Atlanta, Georgia by our FAA approved commercial jet aviation machine shop on state of the art HAAS mills and lathes. You wont find higher quality anywhere!
This product fits Audi TT (2001-2006), Audi A3/S3, VW R32 (2004), VW Golf 4motion and 4motion Variant, VW Bora 4motion and 4motion Variant and replaces OEM linkage P/N 1J0-505-466B (1J0505466B).
Please note : This product is sold in sets of 2 (1 for each side) and includes all required spacers and the upper bolt/lock nut. Re-use existing lower bolt.
#12
#13
#14
Sales@AMS
42
08-25-2004 06:14 PM
momotoTTe
01-24-2004 01:54 PM
