VW/Audi G12/G12+ coolant info. - AudiWorld Forums
Old 02-04-2003, 06:03 PM   #1
Default VW/Audi G12/G12+ coolant info.
A while back, I posted that G12 coolant was made by Pentosin.
Just a correction for the record - it appears that G12 is actually made by Valvoline (Zerex), although Pentosin makes a similar, and I believe compatible, coolant.
G12 is Valvoline/Zerex Glysantin G 30, the datasheet for which may be found at http://www.valvoline-technology.com/
It was developed in conjunction with BASF, and more info on G12 is to be found at http://www.basf.de/en/produkte/chemikalien/spezial/glysantin/specification/
The VAG specification for G12 antifreeze is TL 774-D.
In January, 2003, VW/Audi introduced G12+ (part number G 012 A8F A4), an antifreeze with purple coloration. It can be freely mixed with the original pink G12 (part number ZVW 237 G12). The VAG specification for G12+ is TL 774-F. From the information at the above BASF site, Glysantin G 30 meets both specifications. I believe that the only significant difference between the two is the color - changed to help prevent people from thinking that GM Dexcool compatible (typically orange) coolant could be used to top-up the original G12 (pink), which is not the case.
The older, blue-green, VW G11 coolant has VAG specification TL 774-C, and is Glysantin G 48.<ul><li><a href="http://www.valvoline-technology.com/data/valv/prodinfo.nsf/064d8b901e00e75f85256b140058985e/85256ae300727d2bc1256bbf006eae98/$FILE/Zerex%20G%2030%20antifreeze.pdf">Glysantin G 30 spec sheet (pdf)</a></li></ul>
msauve is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Ross-Tech / VAG-COM or the Schwaben VAG glennlindh VAG-COM Discussion 56 04-21-2016 03:23 PM
engine block drain plug poi5on A6 / S6 (C5 Platform) Discussion 9 10-07-2015 09:17 AM
Blown piston? or valve smashed into piston? bigbruggsy 4.2 V8 Discussion 1 10-04-2015 09:57 PM
new to Audi Ryan Mccormick New Member Welcome Area 0 09-26-2015 10:11 PM
Coolant level low js0823 Q5/SQ5 MKI (8R) Discussion 1 09-23-2015 02:25 AM
Tags
2001, 774, 80, a8, antifreeze, audi, coolant, dexcool, engine, fvw, g11, g12, orange, specifications, tl, valvoline
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
