Broken vacuum line? need help identifying
Im not sure if this is a vacuum line but its a plastic tube that both ends are snapped off. Just need help identifying it to replace it. I have the Bently's ooh but not finding it. Thanks in advance for the help.
2003 TT 1.8l 225HP
Red arrow is piece in question between those 2 parts (green arrows)
2003 TT 1.8l 225HP
I think it's 06A133773G.
It helps to use the N249 valve as a reference, that's the greyish valve with an electrical connector at the left green arrow in your picture. In this parts diagram that's #5
If you trace the outputs of the valve at #5 you'll see one goes into a Y split (marked #9) and that all of the associated vacuum lines are also #9. That part # is 06A133773G
I also found this post which has a different part # and possibly a cheaper price. This is a UK form so they have different engine codes than here in the US. I think BAM is the equivalent of the BEA engine in your car.
The Audi TT Forum :: View topic - Cracked Pipe Help
waruibozu
10-24-2010 05:25 PM
goohead
10
04-15-2008 05:56 AM
Quaboosttro
02-03-2008 10:00 AM
GDJT Allroad^2
08-31-2004 07:22 AM
