Choosing between a 2009 and a 2011 model
Hello all,
I will be buying a 2.0 TT very soon. Currently, I am stuck between getting a 2009 TT that I can afford comfortably or a 2011 that kinda pushes my budget limit. Both years have a mileage just over 100,000 Km (below 120,000 Km).
Is there an advantage for getting the newer 2011 model?
Also, anything I should watch out for in these models/cars with this mileage?
Any suggestions are appreciated. Thank you.
2011+ is the best of the base TTs
Hello all,
The Mk 2 has no chronic issues like the Mk 1 had.
Read this FAQ about MY differences and you will choose the 2011. Fourtitude.com - MK2 TT a5 FAQ
I just bought an 09 and love it. Was in a similar dilemma and decided to buy the cheaper car and definitely made the right choice.
I say go with the 09. Being over financed or car poor is never fun. You get a bit more torque with the 2011 but that is about it. You also get a timing chain rather then a timing belt. Problem is the tensioner for the timing chain was built poorly and still needs to be replaced every 75k miles. So regardless what year you need to budget that in if the previous owner has not already done that. It is a big job in america a timing belt replacement is 900-1100 depending what shop you use.
You can make an 09 faster then a 2011 with a safe reliable stage 1 apr tune for $600. The 2011 with same tune will only be marginally faster. I am coming from a slower car so my stock 2009 feels plenty fast and satisfactory without a tune but may do one later on.
These cars are awesome. Sporty and surprisingly practical due to the large amount of hatchback trunk space.
More thoughts
I agree that you should never buy more than you can afford. I also agree that tuning the 11+ seems to provide marginal improvement. I never looked into the pre-11 tune numbers but looking at the APR chip for the 11 did not seem to be worth the investment.
Your enjoyment does depend on what your prior car was. I was coming from a Mk 1 which had more pep than the pre-11 Mk 2. Test drives with the pre-11 Mk 2 seemed to me to lug at times around town if you were not in the sport mode. IMO this is the prime reason why the Mk 2 was a sales failure because there was no incentive for Mk 1 owners to trade up unless they spent the extra $ for the 3.2. By the time they fixed it in 2011, it was too late because the reputation of the Mk 2 had already been forever tarnished. Irrespective of the engine, any version of the Mk 2 is a far superior handling car than the Mk 1.
There have been a few cases reported regarding the timing chain but if you look at the various Mk 2 forums you rarely see it mentioned. Nowhere near as chronic as the Mk 1 timing belt. The Mk 2 timing belt assembly seems to be much improved as compared to the Mk 1 with no reports of premature failures. If you read the FAQ, Audi switched from a belt to a chain during the 09 MY so you need to check the engine code to determine what you have. So all 09s do not have a timing belt.
The numbers show you get more than "a bit more torque" with the non-tuned 11+ engine. A 25% boost according to Audi and a 33% boost according to APR. 0-60 is 6.1 for the 09 vs 5.3 for the 11+, and 1/4 mile is 14.8 vs 14.1. You also get xenon headlights standard, power seats standard, LED running lights standard, split dual tail pipes, rain sensor wipers standard, auto-dimming mirror standard, Bluetooth standard as compared to the 09 which did not even offer many of these items as options.
Don't brake the bank. I love my 2009 TT coupe 3.2. Bought it a few months back with only 43k miles on it, still nice and tight. I'm the 3rd owner. Avoid 2008 models, I had one and it emptied my wallet. Also owned a 2009 TTS coupe a few years back, due to $$, had to sell it, but also a very solid car. Good luck with purchase.
Agree that the 3.2 is a comletely different animal
However, as pointed out in the FAQ, the 2011+ version of the 2.0 is just as fast as the 3.2 in straight line acceleration, has better handling because there is 150 pounds less weight on the nose, and yet gets better gas mileage too.
More info on timing belt & timing chain maintenance
Talked to the service manager at my dealership yesterday to discuss this. He said they are not seeing any premature failures on the Mk 2 base TT and TTS timing belts. However, he said that if it were his car, he would replace the belt early for preventive maintenance at around 75K.
He said he has only seen timing chain issues on higher mileage TTs, starting around 150K, and then only if the engine oil had not been maintained properly at 10K intervals. Then he has seen chain tensioner failures due to oil sludge.
