Engine swap?
Engine swap?
Hello Audiworld.
I come here to ask you a question that may or may not be a silly one. I'm considering buying a used 2008 Audi TT 2.0 TFSI (200bhp) car but one thing strikes me as odd - on the plastic engine cover (or at the side of it - I'm not sure, if it's still a part of the cover or not - see for yourself), I've found a sticker with the date 08.05.10 (8th of May 2010?). Does that mean there were some serious repairs done to the engine or possibly even an engine swap or do they change the part during service (or am I reading the date wrong)? Any info would be much appreciated, seeing how authorized Audi dealers don't particularly enjoy disclosing full service histories of their cars to strangers.
Thank you for your responses.
You're forgetting its likely in European date format, which is typically YYYY-MMM-DD or in this case YY.MM.DD http://en.wikipedia.org/wiki/ISO_8601
I know its hard to tell because its a bit ambiguous with the low numbers.
If the build date on the car's vin stick (likely in the door jam) predates May 2008 then I am not so sure. But if its post or actually May 2008 then you should be good. I think the TT and their engines were all built in Gyor, so its very possible the engine and car have identical build months.
Hello Audiworld.
You're forgetting its likely in European date format, which is typically YYYY-MMM-DD or in this case YY.MM.DD ISO 8601 - Wikipedia, the free encyclopedia
dontbl8
12
10-31-2014 05:11 PM
S4Pazz
15
06-21-2006 02:58 PM
