TT (Mk2) Discussion Discussion forum for the Mk2 Audi TT, TT-S and TT-RS Coupe & Roadster produced from 2007-2014
Installing LED DRLs on bumper
Old 02-01-2016, 10:17 AM
veloman08's Avatar
Default Installing LED DRLs on bumper
I am installing DRLs on my bumper outer grills. I'm asking for help locating an under-hood 12 volt source when the ignition switch is turned on. I tried tapping into the ignition coil fuse by adding a plug-in 2-fuse extender which turns the lights on with ignition but then has to time out to extinguish them. I'd like them to turn on and off immediately with the ignition switch. I had previously done this on my SLK Mercedes and the fuse tap worked fine. Is there someplace else to do this? I am assuming there is a master relay which feeds the fuse blocks because I hear a click when the lights go out.
Any help would be appreciated.
Barry
Old 03-12-2016, 01:36 PM
veloman08's Avatar
Please someone answer this one.
Old 09-25-2016, 07:52 AM
mbell's Avatar
Did you ever figure this out? I would like to do the same.
Old 09-25-2016, 08:42 AM
veloman08's Avatar
Too hot here in Phoenix to pursue right now. Once it cools down I will start again.
Old 09-26-2016, 05:36 AM
mbell's Avatar
Sounds like a good plan. I ended up going to the main fuse box but for future use it would be convenient not to have to do that.
Old 01-12-2017, 11:21 AM
Lambrettalad's Avatar
Default Want to swop?
wish i had your problem blooming freezing here and now snowing
cheers Alex
Birmingham U.K.
Old 08-17-2017, 03:16 PM
CHIO's Avatar
i just ordered the ones you guys are getting cannot wait !
ledzepp2994
04-03-2009 01:37 PM
SINALOAKID
03-09-2009 09:53 PM
SchwarzS6
07-03-2006 12:55 PM
Scott Miller
09-17-2005 11:09 PM
spdrcrpete
10-12-2004 05:48 AM
Quick Reply: Installing LED DRLs on bumper
